Previous in Forum: Belt Conveyor Protection   Next in Forum: High Resolution Camera Matrix
37 comments
Not with a PWM
05/07/2015 11:25 AM
Hello!
I am trying to ramp up the speed of a motor without having to recur to a PWM signal.
Motor is 12VDC
Max current is 100A
This is for a Winch application.
When I press the Up/Down the motor starts really fast, I want to eliminate the sudden jolt without using a PWM. Perhaps adding Caps or inductors to the circuit..
Any advice?
Pathfinder Tags: Ramp
Re: Not with a PWM
05/07/2015 1:20 PM
See if this helps.
http://www.electrical4u.com/starting-methods-to-limit-starting-current-torque-of-dc-motor/
Your dc motor is low voltage and draws a lot of current at start up. A series resistor, series inductor, or shunt capacitor would have to be quite large, depending on how long your motor need to get started.
Re: Not with a PWM
05/07/2015 1:43 PM
Thank you very much! It did not since Id have to get inside the windings, but it was very informative and interest.
Re: Not with a PWM
05/07/2015 1:25 PM
What do you dislike about using a simple PWM controller? This will be the easiest and most efficient way to vary the current into an inductive load. I admit that 100 amperes will be a hefty controller but a 1.5 horsepower DC motor is not a little motor.
Re: Not with a PWM
05/07/2015 1:44 PM
Id love to use a micro controller and a couple of Mosfets to handle the current, but that adds cost and complexity to the project. The product manager doesn't want to add any controllers or cost!
Re: Not with a PWM
05/07/2015 2:02 PM
Then let the Product Manager come up with a wanted solution and budget. Walk away from the project and do something more valuable with the time.
Re: Not with a PWM
05/07/2015 4:34 PM
You can't do anything without cost except ask for advice.
Re: Not with a PWM
05/07/2015 5:38 PM
"If you can't get what you want during a negotiation, kick the table over." - Anon.
Good Answers: 804
Re: Not with a PWM
05/07/2015 1:49 PM
  • "The product manager doesn't want to add any controllers or cost!"
So he is looking for a magical solution then?
You had better call this guy...
Re: Not with a PWM
05/07/2015 3:36 PM
The FET is an enhancement mode P channel device.
When you apply the 0V to the input, the gate starts to charge until the FET starts to turn on; as soon as the output starts to rise it applies negative feedback to the input, and, slows the turn on.
R3 slugs the whole thing slightly to prevent ringing.
R2 ensures that it turns off when you remove the switched ground.
C2 ensures that the thing doesn't turn on briefly when you first apply power: probably needs to be bigger (or C1 smaller).
Adjust the discrete components to get the desired turn on time.
The suggested FET is rated at 375Watts max but may need to be bigger depending on the turn on characteristics of the motor. Of course once it's on it's OK.
Re: Not with a PWM
05/07/2015 4:07 PM
I would just add a reverse biased flyback diode parallel to the inductive load of the motor.
Re: Not with a PWM
05/07/2015 5:40 PM
That costs a bit more. Fail.
Re: Not with a PWM
05/08/2015 6:20 AM
Good point thanks.
Re: Not with a PWM
05/07/2015 5:39 PM
That costs. Fail.
Good Answers: 102
Re: Not with a PWM
05/10/2015 4:47 AM
R1 would need to be switched s/c after start interval. 10kΩ continuously in series during run......
Re: Not with a PWM
05/11/2015 5:21 AM
Why do you say that?
The 10K and 100K are only connected to the gate (during steady state operation).
Incidentally the FET is only about $3 from Digikey and the other components will be almost negligible.
Good Answers: 102
Re: Not with a PWM
05/14/2015 12:50 AM
I see that now. "Switched ground" as you say bypasses the arrangement during steady state.
You didn't show the 0V rail.....I looked too fast.
The hefty relay for that switch could cost more than $3.
OP wants (OP's masters' want) a zero cost solution, remember?.....he'll be looking for a while.
Re: Not with a PWM
05/14/2015 6:06 AM
The switched ground is only driving the 10K into the gate of the FET.
Good Answers: 102
Re: Not with a PWM
05/14/2015 7:21 AM
Ok, get it now. I have senior moments, thanks for the patient explanation.
So, $3 plus what ever is used for the switch. Switch would need to be timed and coordinated with the existing "go" button, right?
I have an electric winch on my site truck and the zero cost way I get around the rapid winch drum acceleration is to just not care about it and let the rope/sling-stretch/slip provide a bit of give in the unloaded rigging during the initial inching and loading. Once the winch is loaded its startup acceleration characteristics change too. I think some one here already suggested a brake....
Thanks again. I like your circuit. Simple, but still needs to be made. I don't think there really is a zero cost solution.
Re: Not with a PWM
05/14/2015 2:26 PM
Thanks, I used the circuit years ago to replace the power relays on some of the cards in a 19" shelf because we found that when we turned on a card it sometimes "dipped" the 5V power rail on the shelf enough to cause nearby cards to reset.
I used an SI4463 FET (about 11 Amps max) and the two capacitors were 100nF and 220nF.
I have to admit that I was surprised at how well the voltage on the card ramped up linearly: the blue trace is the 5V rail on the card, and, the black trace is the gate voltage.
The OP will clearly need to slow down the ramp much more than this but I can't see any reason why the same principle wouldn't work.
Good Answers: 97
Re: Not with a PWM
05/07/2015 4:06 PM
You could use a golf cart style step resistor. If this involves a brake system, you might have to take that into consideration.
CRTL-Z
Re: Not with a PWM
05/07/2015 5:41 PM
That costs. Fail.
Good Answers: 804
Re: Not with a PWM
05/07/2015 4:32 PM
But... but... but... those involve adding PARTS, and thereby the dreaded COST!
You violated the edict.
Good Answers: 97
Re: Not with a PWM
05/07/2015 4:40 PM
Even a large bungee cord? Forgettaboutit....
CRTL-Z
Re: Not with a PWM
05/07/2015 5:42 PM
That costs. Fail.
Re: Not with a PWM
05/07/2015 7:10 PM
What about going to the junkyard for a variable speed controller off an old treadmill?
http://www.ebay.com/bhp/treadmill-parts
Good Answers: 109
Re: Not with a PWM
05/07/2015 8:48 PM
You would need a lot of old junkyards if you start the production!
Re: Not with a PWM
05/13/2015 3:13 PM
That costs. Fail.
Re: Not with a PWM
05/07/2015 11:07 PM
Lift only heavy objects with the winch (weight just under design capacity)....
Re: Not with a PWM
05/08/2015 7:42 AM
That's it! Well sort of.
The mechanical load is undersized for the winch so the mechanical load needs to be increased. The OP should take the disc brake from the frugal manager's vehicle (Cavalier?) and bolt the disk to the spool of the winch. The caliper then gets mounted to the winch frame and bingo, an adjustable mechanical load. A little simple mounting of a master cylinder and brake lines from the vehicle and the task is done.
I guarantee if the OP surprises this manager with this modification the problem will be solved.
Re: Not with a PWM
05/07/2015 11:34 PM
You could run the line over a spring mounted pulley that would act as a shock absorber...
Re: Not with a PWM
05/08/2015 2:44 PM
Good Answers: 102
Re: Not with a PWM
05/10/2015 4:57 AM
Why bother with the diversion pulley arrangement? Just install the strut (spring and damper) in line with the load. Or use one of those Snatchem straps.
How about mounting the winch on a sliding sprung and damped cradle mount....easier than a PWM....... NOT!
..but this won't do due to cost.....
Can't be done without any cost.
Re: Not with a PWM
05/08/2015 6:08 AM
you could run it with a lower voltage or use a resistive switch they use to use them on electric forkfifts. limits current through the contacts .
Re: Not with a PWM
05/08/2015 6:18 AM
could cycle the switch really fast... manual PMW
cheap untill switch/relay wears out or it sticks.
Good Answers: 266
Re: Not with a PWM
05/08/2015 12:22 PM
Try a thermistor.
Re: Not with a PWM
05/08/2015 12:36 PM
A series inductor, say 10 Henry, might do it, but finding one that would take 100 amp might be difficult. Also the cost might be more that the electronics suggested. I would suggest a reverse EMF diode rectifier across the inductor & motor to prevent switch arcing.
Re: Not with a PWM
05/13/2015 3:11 PM
That costs. Fail.
Register to Reply 37 comments
Anonymous Poster (1); Chris. (1); delreer (2); IdeaSmith (1); JRaef (2); ozzb (1); PWSlack (8); Randall (5); redfred (3); Rixter (2); SolarEagle (3); StandardsGuy (1); Tornado (1); Unredundant (2); Wal (4)
