Previous in Forum: Holes on the Street of Indonesia   Next in Forum: Question about concrete.
14 comments
Good Answers: 16
Human Effort Engineering - Any More Suggestions?
05/16/2015 2:33 AM
Doing the rounds ....
"Something to cheer up the Engineer in you.
Just to put you in the picture and keep you up to date with the latest developments.
Below is a link to a short video of a Pakistani pile driving construction technique!
The chant is also catchy!
Now, let's analyse the Engineering here: 6 men x 180 lbs = 1080 lbs static force.
Jumping up and down will create a 3 times dynamic effect = 3240 lbs/jump = 1.6 ton thumps
If the pile is tapered to 2 in x 2 in, cross section at the tip = 4 sq. in.
then dynamic pressure/thump at pile tip = 3240/4 = 800 psi.
"Add a man" feature will increase to 950 psi, so buy the option!
Increase the chant and dynamic force goes up to 5 times
to bring max pressure
/ thump to 1600 psi for a 7 man team.
Quite good, and will penetrate hard clay and sandy soil
(but not hard or rocky ground!) Pretty ingenious.
Oh, the Supervisor is the guy on the tambourine.
https://www.youtube-nocookie.com/embed/cFb0nLCKypg?rel=0
DY
Re: Human effort engineering - any more suggestions?
05/16/2015 1:22 PM
Hey, don't knock it. It gets the job done!
Canada - Member - New Member
07/31/2015 4:02 PM
And,,, it employs people. Reminds me of consulting days in Bangladesh. No cranes or lifting devices at all, so the "yard crew" consisted of 35 men. They moved everything with levers and ramps off of and onto rail cars. Best one I saw them do was an old shaper, must have weighed in at least 10 tons.
Never stop learning
05/16/2015 1:55 PM
You'd think they could at least construct a Roman type pile driving apparatus....
Good Answers: 16
05/17/2015 2:36 AM
Wasn't it the Romans that built the sewer system and other infrastructure ....
how could they do it then, and we seem to be dragging the chain a bit these days?
http://www.rome.info/ancient/aqueducts/
DY
Good Answers: 97
05/18/2015 12:16 PM
CRTL-Z
05/16/2015 4:36 PM
Simple is good.
Excellent use of resonance too.
I'me sure some smart ar$e with CAD could complicate it to the point of uselessness.
Good Answers: 97
05/16/2015 5:48 PM
There were two more guys, but they already had piles.
CRTL-Z
05/16/2015 7:02 PM
Nope. It takes aliens with anti-gravity technology to drive a pile. Just ask this guy:
Good Answers: 102
Re: Human Effort Engineering - Any More Suggestions?
05/17/2015 5:49 AM
Take a closer look at that video and you will see the spoils of the holes that were hand bored first before these columns/piles were slipped down into the holes. There a few of the post hole digers that were used to create those holes propped around the scene too.
So it's not driving piles to a specified resistance at all. It is core lining only. Light load wet piling?
Here they use various rigs that actually do drive piles to resistance. Some have manually lifted pile hammers, some use winches to lift the hammer.
Bigger sites use contemporary powered equipment.
But I will remember this technique, I'm sure it will come in handy one day.
Good Answers: 97
05/17/2015 8:43 AM
Pogopiledrivers Instructions: 1. Put sharp end in ground. 2. Start tambourine. 3. Give movement to bottom. 4. Continue.
CRTL-Z
Good Answers: 16
05/17/2015 9:19 AM
Adding to the instructions .....
The English all weather inspiration ... and support for the tambourine man
DY
Good Answers: 97
05/17/2015 10:47 AM
That British chap has a serious medical condition, caused by chronic spousal headache.
CRTL-Z
Good Answers: 16
05/17/2015 11:21 AM
A bit like this I presume .....
DY
06/01/2015 8:03 AM
Ancestors pumped water,threw projectiles,driven piles,even pedal powered boats.
pnaban
Register to Reply 14 comments
Don from Oz (3); Kevin LaPaire (1); Kilowatt0 (1); pnaban (1); Rixter (1); SolarEagle (1); Unredundant (4); user-deleted-1105 (1); Wal (1)
