Previous in Forum: Can Anyone Suggest Best Engineering Websites For Free Study Materials ?   Next in Forum: Progressive Cavity Pump
What Should Be the Capacity of Steam Boiler to Run a Turbine to Produce 1MW
12/01/2015 6:01 AM
To produce 1mw electricity what will capacity of boiler and steam turbine?
To produce steam what will need input temperature of boiler?
Thanks in advance
Best RegardEnamul
Re: What should be the Capacity of Steam Boiler to run a Turbine to produce 1MW
12/01/2015 6:22 AM
A1) A boiler and a team turbine is not needed to produce one milliwatt of electricity; a simple thermocouple will do that.
A2) The temperature and pressure of steam is information widely distributed in the public domain in the form of Steam Tables. A Google search on that topic will yield many hits. The input temperature has to exceed the saturation temperature for the selected pressure, otherwise there will be no heat transfer into the boiler and the pressure will fall. Google boiler design for more information.
12/01/2015 6:54 AM
Sort it like this one. If you don't know still, get a subject in Thermodynamics (1&2).
12/01/2015 8:11 AM
I thought the size, design and specification of the steam turbine would determine all of this.
One must also be very meticulous in doing any engineering work. Between 1mw and 1MW there is a difference of nine orders in magnitude.
Even with the larger power unit, this seems like a small amount of electric power for any utility steam turbine.
Good Answers: 122
Re: What Should Be the Capacity of Steam Boiler to Run a Turbine to Produce 1MW
12/01/2015 9:16 AM
The capacity of the boiler & turbine must be greater than 1 MW.
Power Out = Power In - System Power Losses
or;
Power In + System Power Losses = Power Out
You must first convert the needed electrical energy units into BTU or Joules so that an energy conversion equation can be developed.
Then you must design or purchase a boiler and steam turbine that is capable of producing the required magnitude of energy plus enough energy to overcome inefficiencies and heat losses caused by system dynamics.
Finally you must factor in additional energy required to offset power losses due to wear and tear over the expected operational lifetime of the system.
The input temperature of the boiler is dependent on required steam flow and boiler design which in turn is determined by turbine design requirements.
There are a lot of factors that must be taken into consideration when designing or purchasing a 1 Megawatt generation system which this forum cannot address.
I suggest you research and identify your energy needs then contact several steam turbine manufacturers for their competent input and advice.
Before making a final decision on equipment I would suggest you research the different types of systems as well as different manufacturer's reliability and maintenance cost performance.
Good luck
Good Answers: 137
12/02/2015 12:45 PM
The capacity of the boiler & turbine must be greater than 1 MW is something of an understatement. The efficiency - shaft power out/steam power in is likely to be something like 30%, depending on design steam pressure and temperature. The 2nd law of thermodynamics puts a limit on it, even without friction, heat loss etc.
Good Answers: 122
12/02/2015 5:07 PM
Yes I agree. I wonder if the OP is working as a design engineer for a boiler or steam turbine production facility or if he is trying to double-check a submittal from a supplier on specifications?
12/01/2015 12:44 PM
1mw = 101.93 boiler hp
1 Horsepower (boiler):
The energy rate needed to evaporate 34.5lb of water at 212 °F (100 °C) in one hour. Equal to 33,475 BTU/h. Approximately 9.810657 x 103. A boiler horsepower is more than 13 times larger than mechanical horsepower (~engine output).
http://www.kylesconverter.com/power/megawatts-to-boiler-horsepower
https://www4.eere.energy.gov/manufacturing/tech_deployment/amo_steam_tool/equipTurbine
Register to Reply 7 comments
Codemaster (1); Mr. small (1); PWSlack (1); redfred (1); SHOCKHISCAN (2); SolarEagle (1)
