Previous in Forum: Pressurized Argon Ionization Chamber - 10CC Volume   Next in Forum: ZEN Building at SUNY Polytechnic Campus
22 comments
Tiled Armour Science - Trispokedovetiles - Three-spoke Dovetailing Tiles
11/22/2016 10:23 AM
Trispokedovetiles: Three-spoke dovetailing tiles
I've programmed a webpage using Javascript to display an animation which shows a range of different trispokedovetiles, each of which can be specified by a "CIRCLE" percentage, which is the ratio as a percent of two parameters -
  • A "HEXAGON" parameter length - always nominally "100%"
  • A "CIRCLE" parameter length - the animation varies this between 100% and 135%, though values up to 150% can be drawn.
You can also use the webpage to specify a "CIRCLE" percentage and click to "Draw TRISPOKEDOVETILES" to generate an image of a tessellation of a particular shape of trispokedovetiles.
I've tested the animation in Chrome and Internet Explorer browsers and it works fine for me but it is not working in Firefox for some as yet unknown reason.
I've named the shape "Trispokedovetile" which is a contraction of "tri-spoke dovetailing tile".
  • "tri-spoke" because the shape is similar to a 3-spoke motorcycle wheel with three bites taken out of it.
  • "dovetailing" because the tiles interlock like a dovetail joint
Possible application to tiled armour
One issue with hexagonal or square armour tiles is that such simple shapes don't interlock naturally, as do jigsaw puzzle pieces.
Whilst a little armour tile movement normal to the armour plane is useful in absorbing the kinetic energy of a ballistic impact, such as from a bullet and better than the armour tile absorbing the same kinetic energy by shattering, on the other hand, tile movement tangential to the armour plane leaves most unwelcome gaps in the armour.
So armour tiles shaped like jigsaw puzzle shapes (or some hexagonal variation such as these trispokedovetiles) could perform well in this application.
Pathfinder Tags: armor Armour tiles
Re: Tiled armour science - trispokedovetiles - three-spoke dovetailing tiles
11/22/2016 10:31 AM
The design seems unique and should be useful in certain applications....nice work
I suggest a simpler name....tri-lock
11/22/2016 10:55 AM
QUOTE "The design seems unique and should be useful in certain applications....nice work"
Thanks!
QUOTE "I suggest a simpler name....tri-lock"
"Tri-lock" would be a simpler but neither a descriptive nor a unique name as would befit a unique design.
"tri-lock"- 1,000,000 google search hits
"trilock" - 365,000 google search hits
There are a number of arty tessellation images that are similar and helped provide me with some inspiration.
Also the image search term "tetrapod vector" finds some similar images.
But the "tetrapod (structure)"
WIKIPEDIA "In coastal engineering, a tetrapod is a tetrahedral concrete structure used as armour unit on breakwaters."
- isn't an appropriate name for a flat tile shape and neither is "tripod".
I wondered if such a tile shape had already been named by mathematicians and I did ask in some maths forums but no information about that has been received and consequently I am sticking with "trispokedovetile" for now.
Good Answers: 109
11/22/2016 9:31 PM
You better call them: TriS Dow Tiles!
11/22/2016 9:49 PM
I'm still trying to find a woman who will allow me to name her "Mrs Dow" as my wife, after Condoleezza Mona Lisa turned me down (by default, she's never actually communicated with me in any way).
11/22/2016 10:43 AM
Works fine with Firefox on both my Win7 and XP laptops.
11/22/2016 11:08 AM
QUOTE "Works fine with Firefox on both my Win7 and XP laptops."
I tried uninstalling and downloading the latest version and reinstalling Firefox and it worked for a while but afterwards Firefox wouldn't work on any webpage - it just hung showing a blank page - and it didn't give me any useful error messages either, which is a pain.
I am not sure what has caused my Firefox to stop working - it could be something else entirely and a coincidence that it stopped working around about the same time. Firefox had worked fine on my windows 8.1 for many months if not a year or so.
Diagnosing this issue with my Firefox installation on my PC is not a priority for me, but if you say my webpage works for you using Firefox then that's good news.
11/22/2016 10:47 AM
Interesting, It is like a plate chainmail that can distort to absorb energy and spread it over a large area. Only problem I see is this would go good behind something that is hard enough to transfer the energy of impact from a projectile.
I like the design, it incorporates a failure mode that breaks in stages increasing the duration of failure. It will bend before it breaks thus increasing the likelihood of an incomplete failure.
Drew K
11/22/2016 11:53 AM
Thanks Drew but I'm only claiming credit for suggesting this class of trispokedovetile shapes for design use in tiled armour as an improvement upon say the hexagonal tiles already used by armour manufacturers today.
I am certainly not claiming any credit for, nor inviting any discussion about, the long established practices and principles of tiled or the similar scale armour.
11/22/2016 11:08 AM
Interesting.
Well, the design could have it interlock on one side, and for use as armor, that is what your would need.
11/22/2016 12:00 PM
QUOTE "Interesting."
Thanks!
"Well, the design could have it interlock on one side, and for use as armor, that is what your would need."
I'm not clear what you mean there, sorry.
11/22/2016 12:32 PM
Ok, I'm looking at this as a brainstorming session. And I'm putting this on the table.
I did a quick sketch, lots of gaps, but good for visualizing.. its not detailed but just to get my point across.
but you have plates on one side (circular ones shown) so to as giving it one way mobility,
doing so one could use some type of clevis linkages to get flexibility
even thinking about it even farther, if one would flip every other one over and assembly may happen if it was assembly with a twist, this may lock in.... also unlock,
like I said,.... interesting.....
Interesting little project for a 3D printer for proof of concept.
11/22/2016 9:09 PM
Well now that's a lot clearer as to what you meant. Thank you.
But we are talking about different directions of interlocking altogether because when I talked about -
"One issue with hexagonal or square armour tiles is that such simple shapes don't interlock naturally, as do jigsaw puzzle pieces."
I meant the interlocking in the direction that prevents jigsaw pieces separating one from another.
There's no "interlocking" other than gravity which holds jigsaw pieces down on the table or stops them floating upwards (up and down is the direction "normal" to the table surface) and so I was in no sense banging on about interlocking against movement of armour tiles in the direction normal to the armour plane, in the direction of a bullet.
Whereas a jigsaw puzzle with simple hexagon-shaped pieces could be slid apart along the surface of the table easily enough because hexagons don't interlock side to side.
So the trispokesdovetiles interlock successfully, completely, with no bother and no more discussion needed as do jigsaw puzzle pieces to prevent sideways movement that would cause unwelcome gaps in the armour between tiles which had moved sideways.
Whereas you have changed the subject from my quote to discuss interlocking against movement in the normal to the armour plane, in the direction of a bullet. That's important but quite a different issue which presumably has already been solved for the existing manufactured tiled armour using hexagon shaped tiles.
So you are likely trying to reinvent the wheel with your suggestions there.
However, your images have inspired me to offer some suggestions as to how to make a 3D representation of trispokedovetiles. Here's a simple method I came up with.
Step 1.
Create a line image using my webpage, this is for CIRCLE = 120. Right click save image as.
Step 2
Use a image editing program such as paint.net
Crop the image to suit and use the paint bucket tool to fill the tiles you want to make 3D with another colour, I chose red.
Step 3
Use the magic wand tool with option flood mode global to select all the red area and then copy and paste the red area into a new image
Step 4
Use paint bucket tool to colour the tiles black
Step 5
Upload the black and white image to selva3d.com with option "Logo/text", adjust the height and rotate the image to suit and right click to save the image.
11/29/2016 9:43 AM
Now to consider the important issue of interlocking trispokedovetiles against movement in the direction normal to the armour plane, in the direction of a bullet.
BILAYER TRISPOKEDOVETILES
I propose that the unit armour tile be comprised of 2 joined trispokedovetiles with matching HEXAGON parameters but with each with a different CIRCLE percentage.
For example, suppose we choose trispokedovetiles with CIRCLE = 100% and 121%.
The reason for choosing C100 for the outer layer of the armour is because its 120 angle corners would be more robust.
The reason for choosing C121 for the inner layer of the armour is because CIRCLE = 121% offers the largest percentage where the neck attacking the outer part rings is at least twice the thickness of the ring, attempting to balance the robustness of the ring parts to the robustness of the neck versus tensile stresses.
Stacking and joining those together forms a bilayer trispokedovetile, "C100+C121".
Drawing the 2 layers semi-transparently we can see how the bilayer trispokedovetiles would interlock in the normal to the plane.
2/3rds of the tiles can be slotted together, either the yellows and the blues or the yellows and the purples or the blues and the purples.
However the final 1/3 of the tiles would not simply slot in and would have be inserted by joining the two halves of the bilayer trispokedovetile in situ.
Re: Tiled Armour Science - Trispokedovetiles - Three-spoke Dovetailing Tiles
11/23/2016 5:05 PM
Very nice, overlapping circles and radial lines. It might make interesting floor tiles as well. Thanks, I like it!
11/23/2016 6:52 PM
Thanks Rixter!
Trispokedovetiles: CNC code to cut tiles
12/05/2016 7:30 PM
For Computer-Aided Manufacturing of trispokedovetiles, I'm publishing today my new Javascript web-page -
Trispokedovetiles: CNC code to cut tiles web-page G-code generator
- which generates Computer Numerical Control (CNC) code which I've tested with CNC Simulator Pro but not on a real CNC cutter as yet.
12/10/2016 8:42 PM
12/18/2016 7:57 AM
TRISPOKEDOVETILES ROUTER CUTTING
My trispokedovetile CAD-CAM webpage now offers an (X,Y,Z) option for router cutting using rotary tool paths between spaced out tiles -
I've simulated the CNC router code -
06/28/2017 6:21 AM
Have you thought of putting a matrix laminate between the tile layers that allows some flexibility whilst still remaining intact (to a point) this should allow the tangential movement without the gapping effect and when it does give then the energy used will reduce the projectile velocity.
I looked in to a similar effect in the past for a novel body armour that used the damage tolerance of Nacre that uses 3 different mechanisms for body armour that amalgamate together well and are similar in design to yours.
I like this design though and definitely worth keeping an eye on as I have worked in body armour for a while now.
06/29/2017 2:09 PM
Thank you for your thoughts and suggestions.
What I have suggested is a bilayer trispokedovetile meaning a single composite tile which is comprised of two trispokedovetile halves firmly fused, welded, brazed, soldered, riveted, screwed or otherwise joined together to create one single rigid tile.
In order to ensure that the tiles when assembled have overlapping edges, it is unacceptable for the two halves of a bilayer trispokedovetile to move with respect to each other, tangentially in the armour plane or in any other direction.
That is not to say that one could not have multiple layers of such bilayer trispokedovetiles and some matrix laminate between the layers. It is merely to say that each single layer be assembled of tiles, each being a whole and indivisible "bilayer trispokedovetile".
There is the complication that 1 out of 3 of the bilayer trispokedovetiles requires to be joined in situ but once joined it functions as a single piece.
There is the further complication that there may be an advantage to using different materials for each half of the bilayer trispokedovetile.
For example the exterior-facing half, the C100, where hardness is the most important property, could be made of ceramic - silicon carbide for example.
and that would be joined to the interior facing half, C121, where tensile strength is the more important property which may be made of a tough metal, titanium perhaps
But in operation, even though the two halves be made of different materials, the two halves should be firmly joined together to make one tile.
That is my concept but I've not proposed this design with the "body armour" application in mind.
06/29/2017 12:27 PM
BEWARE my dead "scot.gcehosting.com" links in my earlier posts above!
I lost my website hosting in January. I was not "hacked" but the gcehosting administrator seems to have gone out of business and the hosting company he was using (godaddy) is serving various spurious adverts whenever anyone clicks one of my old links.
I have got the following pages back on-line with a different hosting company now so try these links instead.
Trispokedovetiles: Three-spoke dovetailing tiles by Peter Dow
Trispokedovetiles: CNC code to cut tiles by Peter Dow
Trispokedovetiles Gallery
I can't edit my earlier posts to correct the old links, sorry.
I've not done anything with this project since January.
06/29/2017 6:33 PM
Ask Admin to intervene.
Register to Reply 22 comments
Drew K (1); IdeaSmith (1); JohnDG (2); MTJB-Engineering (1); Peter Dow (13); phoenix911 (2); Rixter (1); SolarEagle (1)
