Previous in Forum: Boat Construction & Building at low cost   Next in Forum: Vandal proof railroad crossing flashlights
12 comments
Is the train pulling or pushing?
08/28/2007 6:52 PM
I was asked this question today in a discussion of circulators in HVAC/R.
Imagine a model electric train set around a Christmas tree. The tracks are set up in a circle. The trains are assembled upon the track and the train is as long as the circunference of the track. The engine's front coupling connector is attached to the rear coupling connector of the cabose (remember them?). The train is in a circle, chasing it's own tail. The power is turned on!
The question is; Is the engine pulling cabose? Or is the cabose pulling the engine?
Good Answers: 143
Re: Is the train pulling or pushing?
08/28/2007 8:30 PM
Hello HaroldSJS,
If the circumference is exactly so, you could find the answer by putting strain gages on the couplers. You'll find that the gages will generally not indicate zero strain, i.e., as much push as pull. On a perfect track, each car immediately behind the locomotive will have some strain that stretches the coupler (and the car a little). This stretch will add up until the last cars are too close to the locomotive and are then pushed. That push will compress the rear couplers and so on until there is a balance. In the absence of acceleration, you should see half the train pulled and half pushed if all other things are equal.
Tom
Good Answers: 143
08/29/2007 7:15 AM
And, it occured to me later that, since you were talking about air, maybe you need a very elastic coupler. In that case, there will be oscillation.
Tom
Good Answers: 97
08/29/2007 1:43 AM
If the train keeps on accelerating the caboose will be pulling the engine (a sort of a PM machine). Otherwise it would definitely be pushing it.
If pulling the new force on the first truck behind the engine will be Fcaboose + Fengine.
If repeated for a few loops the force would be FcabooseN + Fengine and the engine can be switched of
Ok not quite. (Don't kill me dead!!)
08/29/2007 2:49 AM
i remember years ago someone trying to explain that there is no such thing as pulling!
In a simple hook and eye coupler (say a car pulling a trailer) the face of the hook ends up pushing the inner face of the eye. Look at a chain and ponder the universe.
Does the sky push the moon?
How many stars in the ocean? How many fish in the sky? How many grains of sand in a cup of coffee...
mmmmm
peace above you, peace peace below you.
Del the mystical Cat
08/30/2007 12:14 AM
"no such thing as pulling!"
What about magnetism & gravity?
What keeps the moon in orbit around the Earth etc.?
Popular Science - Weaponology - Cardio-7
08/30/2007 9:06 AM
Del, I thought you weren't going to get hooked on those mushrooms again!
Popular Science - Cosmology - New Member United States - Member - New Member
08/30/2007 8:12 PM
Pull = contraction, push = expansion.
Now, a muscle can only contract (to do work). Hence there is such a thing as pulling Mr. Cat.
I cranked up my chainsaw, stared closely at the moving chain. Funny, I just couldn't seem to ponder the universe. What's wrong with me?
All worthwhile programmers know that constants always vary.
08/31/2007 11:33 AM
Actually, if you follow Cat's analysis of the trailer hitch, the hole of each link is pushing on the pin, and the pin is pushing on the next link. But, that's only possible because the molecules within the link are pulling (attracted to) each other.
Dick
Good Answers: 266
08/29/2007 1:20 PM
The caboose has no power to any thing it is being pulled. Since we are talking about a train there is slack in the couplings. The slack in the couplings from the engine back around to the caboose would be greater then the coupling between the engine and the caboose in front of it. So it would be pushed.
08/29/2007 11:53 PM
Similar question from my youth: Does the piston of a common-design IC engine ever have zero velocity (during continuous operation, of course)? It must reverse direction at each end of every stroke, so it must slow to a stop and then accelerate in the reverse direction, but it's attached to a rod and crank that are in continuous motion!
Canada - Member - New Member
Location: Richmond Hill, Ontario (North Greater Toronto Area), Canada
08/30/2007 1:38 AM
If the effective circumferences are identical, then both. That is to say, the engine is effecting movement directly to both the car in front of it and the car behind it, and subsequently all the rest.
You can have it good, fast or cheap. Pick two.
08/30/2007 2:14 AM
"Is the engine pulling cabose? Or is the cabose pulling the engine?"
As the engine has the only motive force, it will be causing all other wagons to move, thus effectively pulling them all.
The only time the caboose will pull the engine is when there is decelleration, as the engine will act as a brake, and the caboose will have greater momentum than the engine.
Madness is all in the mind
Register to Reply 12 comments
Anonymous Poster (1); Cardio07 (1); dkwarner (2); GM1964 (1); Hendrik (1); Johnjohn (1); Munky (1); ozzb (1); TVP45 (2); user-deleted-1105 (1)
