Previous in Forum: This concerns Metrology   Next in Forum: Cr2O3 Coating on a Thin Sleeve?
24 comments
Turbine Driven BFP: Better Than Motor Driven?
09/20/2007 1:46 AM
Is turbine driven BFP have some advantage over Motor Driven BFP???
Pathfinder Tags: duindi
Re: Turbine driven BFP
09/20/2007 2:27 AM
Maybe if we all knew what a BFP is we might answer.
I'll bet the BFG knows...
Good Answers: 53
09/20/2007 3:15 AM
Some results from Acronymfinder.com
Burlington Free Press
Bona Fide Purchaser
Body Fat Percentage
Back Focal Plane
Batters Faced by Pitcher (baseball)
Beaver Falls, Pennsylvania (Airport Code)
Bund Freikirchlicher Pfingstgemeinden (Erzhausen, Bundesrepublik Deutschland)
Bureau of Fire Protection (Philippines)
Basic Formula Price
Bid For Power (gaming)
Big Fat Positive
Backflow Preventer
Boiler Feed Pump
Bundle-Forming Pilus
Barbados Free Press (political commentary blog)
This is just the first page. I could get more but I've like to give our poster something to do.
09/20/2007 3:58 AM
Quite. Smart money is on the Burlington Free Press.
Hobbies - HAM Radio - New Member Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member
09/21/2007 12:37 PM
I am thinking that a BFP is a BF Pump, with BF being the same as in BFH (Hammer), BFR (Rock), etc., not to be confused with the BF in "BF Goodrich"! Although Goodrich's competitor, "Goodyear", does fly a BF Blimp!
"What, me worry?" Alfred E. Neuman
09/21/2007 2:51 PM
Sorry STL didn't intend to post the same answer as yours. Didn't see yours 'til after I submitted.
09/21/2007 2:59 PM
OK, sorry for the jab at you in my other post. Didn't see your 'til after I submitted.
I really need to relax a little, working on three projects at the same time!
09/21/2007 3:34 PM
No Problem I have requested that my offensive post be removed.
09/21/2007 2:57 PM
ietech,
Do you even read what someone has posted right above yours, but hours earlier? Did we really NEED to be so F*****g literal? I thought my post was clear enough for anyone who had half a brain without resorting to a censored form of the F-word itself.
But then you probably use a BFH when a more precise tool is what is really needed to do the job.
09/21/2007 3:26 PM
Deleted by poster
09/20/2007 7:17 AM
It all depends on the FO! If the turbine driven BFP is going to create enough FFP then go with that, if not, then use the motor driven BFP. This will definitely give you a good FFP force so long as your victim is standing in the right place at the right time! Personally, I would not use either! I would go for a pneumatic or high-gain hydraulic Multi function masher, normally refereed to as a CICO converter! Then again I could be barking up the wrong tree!
Check out this for a pictorial idea!
Good Answers: 19
09/21/2007 11:23 AM
I hope you ordered express shipping. You could have a nasty pile stack up if it takes too long.
Who is keeping your chair warm while you wait?
09/21/2007 11:52 AM
I'm counting the days....nervously! The new one is snap fit so you can play till your hearts content! Can't wait!
Re: Turbine Driven BFP: Better Than Motor Driven?
09/20/2007 11:41 PM
Oh come on guys, it's pretty clear what he's talking about. Don't be so dense.
Seriously, a turbine driven BFP is far better than a motor driven BFP. The motor drive may be cheaper on initial purchase of equipment, and it may be fine for a single BFP; or perhaps for staging BFPs to a turbine platform.
But if the goal is to get as many Bi-Faced Politician out of the country as quickly as possible, then send them by jet.
Give me Liberty, or give me my Money Back!
Good Answers: 53
09/21/2007 11:24 PM
it's pretty clear what he's talking about...
Perhaps to you. I've been around long enough to be taken out by misinterpretation .
I've been around boilers enough to know a lot of terms but not all of them. I did suspect that BFP might stand for Boiler Feed Pumps but what if it wasn't?
Then again, duindi007 hasn't come back to make any comments to anyone. I don't know if that was him in post #6 (a guest post).
09/20/2007 11:42 PM
BFP stands for Boiler Feed Pumps.
09/20/2007 11:50 PM
A burbine driven BFP is superior except for the lower initial cost of the motor driven BFP. The control system is the challenge for a turbine. The GE MDT-20, for example, can be used but must be modified with a dual element, low DP oil filter. PEPCO filed legal papers in attempt to get GE to fix malfunctioning GE MDT-20. At 6000 rpm, the speed pickup is critical and the gap adjustment important. Obviously, the control valve position and valve control system are critical components for a steam driven BFP. Transtek LVDT position feedbacks are recommended as the low cost, highly accurate method of controlling speed. A Hall effect speed pickup is recommended to accurately detect the speed at both low startup speed and high operational speed (6000 rpm up, 60 + or minus teeth to count at 6000 rpm is 360000 Hz). Not all speed pickups can count that fast without missing a tooth occasionally. Now, if you are from Kentucky, a missing tooth can be expected.
A swinging BFPT can be catastrophic. The big blackout from NY to Mi to Canada was propagated by a swinging GE MDT 20 BFPT at First Energy. First Energy had just fired the engineer for delivering the cost analysis to fix the swinging BFPT. No one else at First Energy could smooth out the BFPT, and ultimately the power swings resulted in almost tripping the entire East Coast. The Fast reaction of an alert AEP operator should be commended for cutting First Energy loose from the system.
Motor driven BFP in multiple arrangements can be made to work by matching load with number of BFP. Most operators run all electrics in man except for the one used for control is placed in auto. Otherwise, expect each to play with the other and swing load. A good I&C control system design can fix this problem but almost every utility is too timid to fix the swinging problem. Electric motors are obviously very inefficient and difficult to operate.
Some plants use the electric for startup and bypass but switch to steam at synchronization speed. At full load, a steam turbine in brought on line for precise efficient control. A special piping arrangement allows for electric and steam to operate in tamden. Clifty Creek has this unusual BFPT arrangement.
Corn Stoves
Good Answers: 58
09/21/2007 1:57 AM
"A burbine driven BFP is superior except for the lower initial cost of the motor driven BFP."
I am not sure that I understand why the lower initial cost option should be inferior. Electric motor driven pumps are far more reliable and have lower maintenance costs. The reason for using steam turbine driven pumps are many and varied but the most important is that while your boiler is running and producing steam you have a guaranteed source of feedwater if you are using a turbine. For electric motor drive you would require it to be fed from a guaranteed power supply. (For "black" start you need an alternative source of boiler feed water). The other reason would be to use the turbine as a letdown station and to use excess steam as a low cost energy source, depending on the steam balance of your plant.
09/26/2007 9:29 AM
Sounds like another case of shooting the messenger because you did not like the message!
Good Answers: 61
09/21/2007 9:53 AM
I have found motor-driven Boiler Feed Pumps to have lower maintenance and better control, resulting in higher availability and fewer forced outages in the long run. As Cornstoves noted, the control system is the critical factor. All turbine-driven BFP's regulate feedwater flow by controlling the speed of the turbine. This necessitates a very precise, usually very expensive, governor control. Conversely, electric BFP systems can be set up to regulate flow in 2 different ways:
1. Use an off-the-shelf variable frequency drive to precisely control motor speed. The VFD varies the motor speed, much like the MDT-20 varies turbine speed, to vary flow.
2. Install a control valve in the recirculation line from pump discharge back to pump suction. For good control, the recirc. line must be able to handle higher flow rates than just what is needed for pump protection and cooling. Feed water flow is regulated by controlling how much of the pump discharge is returned to the pump suction, rather than sent to the boiler. The control valve is usually operated by a pneumatic diaphragm, although I've seen newer systems using linear positioners similar to the damper controls on ID and FD fans. The control air to the diaphragm, or the control signal to the positioner, can be precisely managed by your DCS or other centrol control system to provide excellent response and prevent swings.
The cost of a large VFD usually leads designers to go with option 2. My personal preference is option 2 with a linear positioner. The control system components are small, affordable, and easily maintained. By standardizing with controls for dampers, coal mills and other equipment, spares inventory can also be reduced.
09/21/2007 10:18 AM
I think the major reason for going with turbine driven boiler feed pumps (and turbine driven burner fans) is that the boiler then only needs a minimal amount of electrical power, for the controls, to operate in the case of a power failure. The advantage is being able to get by with smaller emergency generators. Usually the steam driven equipment has electric driven back-up, for the times when the turbines are down for maintenance.
If there is a use for low pressure steam, a back pressure turbine can be significantly cheaper to run than an electric motor. If the turbine exhaust has to be vented, then electric will be cheaper. If there is a condenser on the discharge, the cheaper method depends on the utility rates with electric usually the cheaper way to go.
Small steam turbines used for pumps and fans cannot be started automatically. They have to be started manually and gradually warmed to avoid having a slug of water hit the blades and destroy the unit. For this reason, boilers with combination turbine and electric auxiliary equipment will run on the turbines, even though it would be cheaper to operate on electric.
09/21/2007 9:31 PM
Summarizing:
BFP=BOILER FEED PUMP?
ok.
Then go for 3 running parallel with 200% redundancy with outlet header and check valves:
1>Motor Driven(Its Synchronous speed causes output pressure just less than Turbo driven #3's Output Pressure!
2>Diesel Engine Driven( Governor Controlled low speed-letting 3> do most work, yet ready to take over immediately)
3> Turbo Driven basic workhorse -rated full capacity 24x365
Cost is in a tiny% extra blocked Capital. But look at the Blackouts avoided!!!
09/26/2007 12:59 AM
yes, tdbfp is better than mdbfp...if u consider aux power point of view
01/11/2010 7:06 AM
the overall energy consumption is less in turbine driven bfp than m bfp
01/12/2010 3:14 AM
AEP power plants utilize a single BFPT for each boiler. BFPT speed varies from startup, to minimum load to full load. Clifty Creek has an electric driven startup pump with bypass to the steam driven BFPT at min load to full load. Unit reliability is dependent on BFPT maintenance and reliability. If the BFPT is off line, the unit is off line. Maintenance is minimized because there is only one BFPT to be maintained. Water is routinely drained off the lube oil tank at night or during times of reduced load. AEP BFPTs are highly reliable and obviously never fail. A single BFPT with a reliable variable control system results in highly reliable units with acceptable MTBF. AEP BFPTs are highly reliable and trouble free.
TVA power plants utilize multiple BFPT for each boiler. Each unit will have at least two, probably three, and possibly four BFPTs. Some units have an electric driven startup BFPT with bypass to two or more steam driven BFPTs. Full unit load is dependent on all BFPTs being in service. Unit MW load will be curtailed if a single BFPT maintenance is pulled on line. Typically, the oil tank will be serviced at night, on weekends, or other times when full unit load is not required. The highest maintenance item on the TVA BFPT is the GE MDT-20 control system. GE management will not face TVA workers directly but rather sell their rotten GE-MDT-20 turbines directly to TVA's "out of touch" upper management. Patomic Electric Power has taken court action against GE without being able to technically resolve the GE BFPT control problem. AEP configures and tunes the MCR, CCS and BFPT control circuits in house without outside or OEM advise.
TVA has never figured out how to operate multiple BFPTs without always having only one BFPT in auto at any one time while the other BFPT controls are in hand or manual control. The one BFPT in auto will swing with load while the other manual controls stabalize and prevent swinging. If two are in auto at one time, the two will begin to swing each other and cause MW load swings. Unfortunately TVA control circuits have an independent PID control for each BFPT. The multiple PID control circuits should be reconfigured to prevent BFPT interaction when load changes are made. The requirement is simple but TVA management does not know how to make simple control circuit improvements. TVA is totally dependent on the OEM for simple control revisions including but not limited to the simpliest MCR, CCS, or BFPT PID tuning. TVA operators are to be commended for being capable of operating units with obsolete combustion control software that was reconfiguraded based on original obsolete pneumatic control system hardware.
The Southern Company is fully capable of "all of the above". Full load output is not unusual even during periods of BFPT maintenance. In house control circuit design, installation, tuning, quality control, and improvements are routine at The Southern Company.
As you can see, each utility has a different concept regarding the selection, installatioon, operation, and maintenance of BFPT. The companies that do it all are the most fun places to work because there are no hands tied behind the backs and no time for stabbing in the back. The companies that have their hands tied, must result to the blame game for lack of more attractive options.
Register to Reply 24 comments
andyhorning (1); Anonymous Poster (4); Cornstoves (1); Howetwo (1); Mr. Truman Brain (2); MUKULMAHANT (1); pwr2thepeople (1); PWSlack (1); Ried (1); STL Engineer (4); The Prof (1); user-deleted-1105 (1); user-deleted-5 (3); Vulcan (2)
