Previous in Forum: Still Doubting Dark Matter?   Next in Forum: Looking for F-F aluminum standoffs
68 comments
Overshot vs Undershot
10/08/2007 3:13 AM
We know that an overshot waterwheel is more efficient than an undershot...but does the sme apply to which way you hang your toilet roll?
Re: Overshot vs Undershot
10/08/2007 5:50 AM
Opinions vary.
Looking at free-running holders first: with the roll configured to unroll from the rear and the free end hanging downwards, any mismatch between the internal diameter of the roll spool and the external diameter of the spindle will produce a turning moment that pushes the roll away from the wall, resulting in freer-running paper than if the roll were to be mounted the other way round. This is the preferred orientation at these co-ordinates.
With the roll configured to unroll from the front, there is a tendency for the roll to move closer to the wall. If there is insufficient clearance then the roll, and there is a greater risk with a full one, will come into contact with the wall, resulting in more force being needed to continue unrolling. In the limit, the friction force between the roll and the wall may be sufficient to overcome the strength of the perforations, resulting in a piece of roll smaller than may be required becoming detached. In the limit, this can become a frustrating experience, requiring more time to be spent unrolling paper.
Some roll holders are configured for the roll to be in contact with the wall, or another part of the fitting, at all times regardless of the length of paper remaining on the roll. With this type, unrolling from the back is certainly the preferred arrangement, as unrolling from the front causes a wedge-type action to be set up between the roll-holder and the wall, increasing the chances for a shorter-than-desired piece of paper becoming detached.
10/08/2007 5:59 AM
Surely a bit of 'wall friction' helps the on handed jerk-tear manoeuvre?
10/08/2007 8:34 AM
Left-handed or right-handed?
10/08/2007 11:51 AM
The pre1886 undershot was, and quote me if I'm wrong, an unmistakable breakthrough in pantechnology. Using wall friction to deliver the correct amount of paper with the correct force applied! This was due to an 8yr research program funded by Albany Purrfurated wrappings to produce the purrfect purrfuration! Developments in the late 1960s changed the philosophy to the overshot when it was noticed that a new trend of tiles emerged! The moisture on the tiles after a shower would leave the paper prone to dramatic failure with instances of premature breakages at the central load zone! Hence to keep the sheet off the wall, the roll was reversed! For further protection against this unfortunate occurrence, we have seen the invent of the full flap cover which operates using the patented (9044 8878 938B) tangential tug'n'tear technology!
hope this helps with your investigation
10/09/2007 12:22 PM
Yes the friction coming off the top is a good thing. In addition, if it is un-rolled from the back you have a good chance of using the wrong side of the paper.
10/08/2007 5:57 AM
Don't you nail squares of newspaper to the door ? What about 1-ply/2-ply/3-ply/more-ply, tracing paper type, quilted,scented, re-cycled, anti-septic, moistened-wipes,different dispenser types,...... And what about the colour ?
Anyway, what's wrong with your litter tray ? Do we have to stick to mechanical efficiency, or can we divert to green-issues and other stuff ? I'm going to anyway. All that bleached white paper can't be good can it ? Or maybe it's better than using dyes though ? Sooo many questions. What did Henry VIII do ?
10/09/2007 11:20 AM
He got married to the widow next door,
She's been married seven times before, . . . .
10/09/2007 11:43 AM
Something tells me that...
I just found out that Jimmy Page worked as a session musician for Noone and Co . Gor blimey guvnor.
10/09/2007 12:01 PM
I just couldn't resist the Herman's Hermits reference. It'll get stuck in everybody's head and there will be a collective mental breakdown.
It is very interesting to find out the different gigs folks worked as session musicians. Some are very well known like Eric Clapton and the Beatles and others much less so.
10/09/2007 12:24 PM
It's true about 'unknown' session musicians.... but even more darned true about songs that won't leave your head once they enter. I've got a sing-along riot occuring inside my head, and worse still I've got the visuals. Aggghhhh !
10/11/2007 3:59 AM
In days of old
When knights were bold
And toilets not invented
They dug a hole
In the middle of the road
And sat there quite contented.
10/15/2007 3:44 PM
he had somebody wipe his arse for him, what did he care?
Good Answers: 97
10/08/2007 6:00 AM
I would think that undershot is more efficient on toilet rolls.
o - Changing from overshot to undershot later will waste energy.
o - The perforation works better.
o - It matches with my open lid & seat policy.
o - It clashes with my wifes closed lid policy.
o - I don't like to see the characters or flowers printed on the paper before I rub their faces in the mud.
10/08/2007 6:05 AM
Aw, how cute. Better than those scavenging Andrex puppies. Here's some stuff on the dilema. And some history.
10/09/2007 12:30 PM
Kris, Very informative and entertaining links --- Hey someone stole your avatar.
10/10/2007 3:38 AM
The avatar is in rehersals, but will be back very soon. I just can't decide which one.
10/10/2007 3:49 AM
Glad you liked the links - here is an update from a TV documentary I just saw. Nobody was sure of Roman toilet habits for a while. Excavations revealed rows of marble seats (nice and cosy) with holes and a gutter containing fresh running water in front. A hand or leafs/moss was the assumed method, until written records showed otherwise. A gladiator who didn't want to fight supposedly made an excuse to nip off to the john. There he suffocated himself by forcing a sponge down his own throat !
10/15/2007 3:49 PM
and who do you think was supposed to have written that down while he was busy with his sponge?
Was it a used sponge?
Sorry but that story has too many unanswered variables in it to sound anything like the thruth.
10/15/2007 4:07 PM
If you prove Kriss wrong.... he'll feel so disgraced he will fall on his own sponge!
10/15/2007 4:14 PM
Expect it would take uncommon fortitude, and determination to suffocate oneself. Mind you I've been in some public places and thought I might succumb involuntarily.
10/15/2007 4:22 PM
I bet the smell did not help? OH...you did not mean that sort of a place, sorry!
10/16/2007 12:38 AM
...'TV documentary'.....nobody was sure'.....'assumed'....'supposedly'...
Ahhh ! I don't know who might have recorded this matter, but the sponge probably fealt very used. If only Ridley Scott had told us more.
10/16/2007 1:33 AM
Oh dear, more guilt to deal with.
10/16/2007 2:07 AM
PMSL. I think they used nice furry cats for the job. Squrrels just run about too much.
10/16/2007 11:41 AM
I thought it was Rabbits that it doesn't stick to?
10/16/2007 12:01 PM
I have a real story about a rabbit that got broke. Believe me, I'd get banned if I told you. It weren't nuthin to do with the fact that way back in the 60's people traded rabbits !
10/16/2007 12:34 PM
Quick note on the new aviator Kris!
10/16/2007 12:48 PM
Oh , but Mr T.B, I only put it up by request. Por old Nick wasn't widely liked. Nutkin is fun, but I thought I'd do the real deal. Is a change in order ?
10/16/2007 12:57 PM
Kris, you know I only have your best interests at heart when I say ! But if he makes you feel better, then I am all for it! You fill ya boots kid!
10/16/2007 2:51 PM
NOW YOU GUYS GOT ME INTERESTED......
Please tell us I will even share your ban with you if that is what is going to happen to you.
10/16/2007 3:34 PM
No one has lived to tell the tale...but I've heard that your Avatar is paraded around the streets of Salem and then burned alive....
In reply to #59
10/16/2007 4:18 PM
I was early worried there, cos I thought he was talking wedding bans or something like that. Anyhow, in the film didn't they put big rocks on the blokes chest ? You couldn't really get a trianguilar head like that. Leastways not if it wasn't some cultural head-boarding thing or a bad Floyd trip. Keith could cook in my kitchen any day of the week. I never liked it anyway, and the insurance would come in handy. Oh no, Ive gone off topic again..... the shame of it.....
In reply to #60
10/16/2007 5:57 PM
borderline - over-shat
10/16/2007 6:05 PM
Priceless ! I think people are designed the way we are - so we can balance on the fence. Ever noticed how politicians seem to have extra advantage in this area ?
In reply to #59
10/17/2007 2:44 PM
cool, my avatar has come to life....only to be burned alive!?
Now we can't ask what it thinks of under or over!
It will have to remain a mystery, I hope you all are happy.
In reply to #63
10/17/2007 3:14 PM
Keep on shining man !
In reply to #64
10/17/2007 3:27 PM
here on cr4, i think we are always on fire.
In reply to #65
10/18/2007 10:33 AM
We can put out your fire! Is the bucket full yet?
In reply to #66
10/18/2007 12:23 PM
The bucket has been full! That's why we're on the fence. Mind your balance, or the over/under won't matter.
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
10/08/2007 6:05 AM
Words fail me <wheeze>.
Essex jobs for Essex yobs! <Burp>.
10/08/2007 6:10 AM
Hey, you've moved your box Pete. All those bits of paper that flutter down aren't toilet paper, they're receipts that the rich gits drop from the ATM.
10/08/2007 6:55 AM
<Splutter, cough.>
Good Answers: 38
10/08/2007 9:55 AM
With Cats in the house you always hang the flap to the rear. This makes it harder for them to roll it off and stop up the toilets.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Good Answers: 266
10/08/2007 1:05 PM
Still takes the same amount of sheets so I say no.
10/08/2007 3:22 PM
A friend used to argue with his wife about everything. One day he called me up and was just bent. Apparently they could not agree to the issue we are discussing now: over or under. He went on this lengthy diatribe about the need of it to be over (or under) and how only an idiot would have it otherwise. They were at each others throats over this very important matter.
As I let him unwind I just laughed. Ha Ha Ha.
Mark, I asked. Why don't you just flip it over? Just flip it over and be thankful she changes the damn thing at all.
I was told that that was not the point. (I guess I never did get the point)
I prefer it over. Heather does not care. I just quietly flip it over, being thankful that we can afford the stuff and further thankful that she puts the stuff on at all.
After all, she is a Blessing!
cr3
10/08/2007 11:28 PM
Talk about efficiency, here's a thought...how do you use both sides of a toilet paper?
Good Answers: 101
10/08/2007 11:48 PM
Best person to ask that question would be Sheryl "Single Sheet" Crow..........
Good Answers: 120
10/09/2007 4:16 AM
the makers should prepare rolls that have 3-4 turns one way, and 3-4 turns the other way with some progressive change of 11 degrees or so to prevent any lumps. Then those maroons who have a directional preference would be aggravated. husband/wife teams on opposite sides of this situation would fight, etc.
Per Ardua Ad Astra
10/09/2007 4:22 AM
Ahah!
What about a dual-width roll dispenser fitted with two rolls, arranged so that one roll can be undershot and the other overshot? The user could then take his/her preference and any arguments would abate.
By voting one way or the other, preferences can then establish the need for the roll to be overshot or undershot as the need arises.
10/09/2007 5:07 AM
How about making a hinged bracket to hold the thing. It could be swiveled horizontally 180o to suit under/over shot preference. Might need an end-piece to stop the toilet roll falling off, and a click-stop to keep it in desired position. I can't be a.. bothered to make a prototype, but I will accept royalties for this idea.
©Kris
10/09/2007 7:04 AM
All bow to the Kris....
Nice one.... can we manufacture under the 'KrisDel' trade name pleeeeeaaase? Can we can we?... a few more good ideas and we'll have enough for a Chritmas catalogue..(we can even put a hole in the corner so it can be hung up and used for....)
10/09/2007 7:13 AM
I hereby bestow exploitation rights upon you Del, subject to my usual cut. 'Flogging a dead horse' is more my thing.. I will try and dream up more for the x-mas catalogue though. Just recently I paid 8 quid for a credit-card sized metal underground map ! Well it might come in handy for the occasional Scotch-Egg impulse purchase, the bank are getting annoyed with me for ruining plastic.
10/09/2007 11:24 AM
Cat-alogue <groan>?
Good Answers: 123
01/01/2008 8:25 PM
Wait! Two rolls, one in front of the other. Back one overhand, front underhand. Now both ends hang from the middle. This allows you to grab two sheets at the same time. And as a bonus your family can place bets on which roll is longer.
Bob
10/09/2007 5:29 AM
Ahah #2!
Turn the spindle 90deg so that it is perpendicular to the wall. The terms overshot and undershot then are not applicable. Problem solved!
Might have to worry about the Coriolis Effect instead...
10/09/2007 5:47 AM
Hang on a mo, you just modified my idea at #whatever with an extra click-stop position.
Pay up, or the Andrex puppy gets it !
10/09/2007 5:49 AM
Cor! No-one messes with Kris!
10/09/2007 6:47 AM
PMSL. I wouldn't really harm the poor puppy, I was just playing with your points. The puppies are kind of soft and hand sized if you see what I mean. Washable as well.
Don't get in a spin;
10/09/2007 7:06 AM
What the f*** is that weird loco thing!!??????
And I use the term 'loco' in all possible interpretations!
10/09/2007 7:15 AM
PWSlack may well tie you to the tracks for such blasphemy ! I ain't sayin' nufink.
10/11/2007 4:00 AM
Wouldn't dream of it. The RSPCA would be alarmed, for one thing.
10/11/2007 4:41 AM
...and it would probably have an adverse effect on traction (Unless it was Winter and Del was frozen there). "Services may be delayed due to Dels on the tracks".
10/09/2007 7:25 AM
Brilliant link ...cheers.
Only had a quick shufti...I shall savour it later.
10/09/2007 7:28 AM
I've never even heard of that before.... thanks for the link very interesting...
John.
Good Answers: 38
10/09/2007 8:04 AM
Looks like a great Idea for rich railroad buffs with limited room in their backyards. They could ride around in circles all day.
10/09/2007 8:38 AM
Quite.
It can be done for rather less expenditure, too.
Good Answers: 25
10/10/2007 7:16 AM
Never purchased a newspaper in a roll, so never
needed to study the issue; only read the small print.
jt.
There's more on http://www.mfnb.at
10/15/2007 12:55 PM
The printing is on the top, so OBVIOUSLY, it's overshot. ;)
Register to Reply 68 comments
Anonymous Poster (2); aurizon (1); Bob B. (4); bob c (1); Brave Sir Robin (2); case491 (7); charsley99 (2); DVader1000 (1); Electroman (1); Hendrik (1); jt (1); Kris (20); Mr. Truman Brain (4); ozzb (1); PWSlack (8); sda1950 (1); Stinky Pete (2); TexasCharley (1); user-deleted-1105 (6); user-deleted-5 (2)
