Previous in Forum: How Do I Measure The Amplitude of Ultrasonic Vibrations?   Next in Forum: Turbine Meters vs. Thermal-Dispersion Mass Flow Meters
whats difference between DDC, DCS & PLC ?
12/01/2007 5:13 AM
what is the difference between DDC, DCS, PLC ? all controllers are same or any difference. if difference plz explane about all.
Re: whats difference between DDC, DCS & PLC ?
12/02/2007 2:37 AM
plz use google
12/02/2007 1:53 PM
I think it is the size of the box plc small, ddc medium, dcs large.
Support your local Shriners, they have provided FREE medical assistance for over 800,000 kids so far.
Reply Score 1 for Off Topic
05/20/2010 6:08 AM
Are u a technical person or mad ??????????
11/18/2010 8:33 PM
if cant understand you should shut up ur asshole too.....
12/27/2007 9:03 AM
DDC : DDC is a universal controller where both analog and digital input/outputs are combined in one controller card also it is specially designed for the HVAC ( Heat ventilation air conditioning) design which are used for air handling unit. it's cost is lower than compare to PLC and DCS, it uses profibus and modbus as a communication protocol which are very speedy responds.
PLC : plc is mainly design for small applications, cost is higher compare to DDC. it is only one conroller, communication protocols are open so it can connect with any controller, programming language is ladder logic and functional block diagram whcih work on relay logic.
DCS : distributed control system which works on multiple controller, and nos of controller are attached with system, cost is very high. communication protocols are open, mainly used in continuous plant and very highly efficiency plant.
Engineering Fields - Electrical Engineering - New Member India - Member - New Member
12/21/2009 1:05 AM
please go to website www.plctalk.net,& www.control.com & http://cr4.globalspec.com/thread/14677/whats-difference-between-DDC-DCS-PLC & http://tunthai.multiply.com/journal/item/2387/CR4_DDC_Direct_Digital_Control_vs_Distributed_Control_SystemProgrammable_Logic_Controller_DCSPLC
http://www.allinterview.com/showanswers/69909.html( u will get very good answers)
hope these sites may help u
Shrimant Shanbhag, Bangalore, India
12/05/2007 3:27 PM
1.Direct Digital Control refers to the ability to control HVAC devices via programming
2. PLC Simplified with limited logic control for like a machine or simple process with limited interlock logic
3. DCS is concerned with huge multiple logic controllers with >1000 of inter lock for process of power plant or refineries or any process Industries)
In essence they are application specific to different processes but they all operate on the same principle such as programming logic and digital
Anonymous Poster (4); JasBond (1); shanbhag (1); shogun7 (1)
