Previous in Forum: Vanishing E-Mails in Outlook Express   Next in Forum: c++
Excel Function
12/05/2007 4:35 PM
I am trying to input an excel funtion which will allow me to have a desired cell output the following
LOW if 3<x<10
Medium if 10<x<30
High if 30<x<100
Can anyone help?
Good Answers: 66
Re: Excel Function
12/05/2007 5:07 PM
This should do it:
=IF(A1>100,"Out of Range",IF(A1>30,"HIGH",IF(A1>10,"MED",IF(A1>3,"LOW","Out of Range"))))
Let me know if you have problems.
Aequam memento rebus in arduis servare mentem.
United States - Member - Woohoo Engineering Fields - Mechanical Engineering - New Member
Re: Excel
12/05/2007 5:08 PM
If your data is in column A then you can paste the following formula where you want the words to appear. An alternative would be to use conditional formatting (Format-Conditional Formatting) and make the actual cells with the values or the text be green or red or what ever color you want.
=IF(AND(3<A1,A1<10),"LOW",IF(AND(10&amp;amp;lt;A1,A1<30),"Medium",IF(AND(30<A1,A1<100),"HIGH","")))
PS. I keep previewing this and it scews up my less than signs --i.e. 10<A1. Try fixing it yourself in Excel and it should work.
Self-motivational quote: "If they can make penicillin out of moldy bread, they can sure make something out of you." -- Muhammad Ali
Re: Excel Function
12/05/2007 5:28 PM
Gentelman,
It worked great
I really appreciate your help. Thanks you, and I hope you have a great holiday season.
Take care
Good Answers: 54
Re: Excel Function
12/06/2007 5:40 AM
I don't know if you've tried this but it's a nice touch:
Select Format/Conditional Formatting.
You'll get a dialog box where you can have the cell change format (change color, font, font color, bold, italic, change borders, etc). You can add up to three format changes. In your case you can select, for example:
  • If cell value is between 3 and 10, the cell color is green, font is black, Arial, normal.
  • If cell value is between 10 and 30, the cell color is yellow, font is black, Times New Roman, normal.
  • If cell value is between 30 and 100, the cell color is red, font is white, Verdana, bold.
I did this for my process monitor at my office. It allows me to watch the different processes around the plant from my office (but not control them), and the color changes instantly alerts me to alarm conditions or changes in the process step. I called it Cheap_HMI.xls. That's right, it's an HMI that uses Excel.
Re: Excel Function
12/06/2007 10:41 AM
That worked great....thanks
CSM Engineer (1); Nate (1); PeterR (2); Vulcan (1)
