Previous in Forum: Arc Flash and IP Rating   Next in Forum: Form 4A — LV Panel — Rotary Handle
Emergency Light Fixture
06/01/2026 10:04 AM
For emergency light fixtures,
1) Combining both the power cable and the charging cable in the same cable (Multi core) acceptable? (refer magenta line in the picture)
2) Taking power for charging from the separate circuit breaker acceptable? any disadvantage in it? (refer yellow line in the picture)
Pathfinder Tags: emergency Light fixture
Good Answers: 105
Re: Emergency Light Fixture
06/01/2026 11:42 PM
1. Why is there a separate charging cable?
2. Without a diagram of the fixture, there is no way to tell if the circuits have common elements.
3. Why would you assume that all emergency light fixtures are identical? How about providing the manufacturer and model number, the target application, the expected safety coverage conditions expected for its primary application, you know, that sort of detail. There is a lot that we can't see from here, if I may quote a respected contributor...
06/05/2026 12:27 AM
In my experience, those lighting fixtures which are designed as emergency lighting contain their own back up battery or super capacitor with a regulation guaranteed operating time once mains power is removed.
These are set up in the same way as a standard fitment with a single power cable.
Why make life more complicated than it needs to be?
Madness is all in the mind
06/05/2026 3:34 AM
Agree fully with your sentiments as all the emergency light fittings I have ever maintained have a single supply, unswitched by normal means, but isolated in a distribution board with a marked circuit. The fittings have either an internal SLA battery or a NiMH battery.
Hare today, goon tomorrow!
06/05/2026 1:52 PM
Let's not reinvent the wheel.
We wire in the emergency light as it comes from the manufacturer. It already has all of the required components including the battery.
This goes for both the passive and active lamp types.
Are you attempting to turn an existing light fixture into an emergency light?
If so, it's cheaper, more efficient and safer to buy and install a prepared emergency light.
CARPE CRUSTULORUM!
06/12/2026 10:36 AM
You could always use some of these:
Calnet42 (1); GM1964 (1); not so smart (1); rwilliams (1); Stef (1)
