Previous in Forum: CONDUCTIVE CARBON BLACK   Next in Forum: Inert Gas That Will Not Impact Metal Alloys in Coins
Fusion of Silicium
01/02/2008 1:06 PM
Does anyone have experience of using a customized microwave oven to reach 3000°C in a silicium fusion process ?
Re: Fusion of Silicium
01/03/2008 10:22 AM
Are you trying to make Si from SiO2?
Michael Binder
binder428@yahoo.com
01/03/2008 11:04 AM
yes
01/03/2008 4:02 PM
As you doubtless know, the standard process for reducing silica to produce metallurgical grade silicon is carbonic reduction below 2000OC. So, unless you absolutely need the specific form of silicon that forms under these conditions, this process sounds like mowing the lawn using nail scissors.
More information about your final requirement, please.
01/04/2008 6:12 AM
Dear Guest,
Reducing silica to produce metallurgical grade silicon is one of our goals. We intend to use a new form of microwaves to achieve it at God knows what temperature.
We were wondering if someone did this before with conventional and multimode microwaves. The expected results with our technology are to improve the yield and to obtain a much more uniform temperature distribution throughout the mass.
Cheers,
LS
01/04/2008 12:43 PM
That reads as if you are planning to use maser-driven dissociation at temperature. That means you will need to separate the droplets of Si and the O2 before the mix falls below the recombination temperature. That will be challenging.
From my perspective (I use both ultrapure silicon and silica) the benefit would be if this separation also removes the other impurities, allowing subsequent processing to be simplified. However, I'm not knowledgeable enough to say whether this should be anticipated. Is that your objective (and do you have reasons to expect this)?
04/19/2014 7:13 PM
"... We intend to use a new form of microwaves ..."
New form of microwaves? New form?
You're kidding, right?
You can vary the frequency, the polarisation and the amplitude, each and all of which are done every single day, so what combination comprises the 'new form'? Which one hasn't been done before?
Good Answers: 109
01/04/2008 12:21 PM
Do you know the electrical conductivity/temperature relation?
What is the size of the crucible and melt?
What is the material of the crucible?
These three answers must be known before there is the possibility to give an answer to your question.
3000°C will be very contraproductive, 1800°C will be enough.
RHABE
Register to Reply 7 comments
Anonymous Poster (3); RHABE (1); Selles (2); Theophilus Stark (1)
