Previous in Forum: Problems with Spindle Drive   Next in Forum: Instrument Earthing Resistance
10 comments
PLC Program Problems
01/14/2008 2:16 AM
We face a problem in our new oil machine,
Please note that we are in big trouble as this machine is working in one of our big s/s and the machine stop suddenly after competing the vacuum process in one T/F.
We sent our maintenance and calibration engineer to check this case, and he suggests that the PLC has some problem.
We would like to inform you that we purchased a oil filtration plant 10,000 liters ( S.O. 38786)from your good company before few months (We have also old machime 6,000 litre ( S.O. 33098). Before one month we face a problem in the PLC for this new machine the problem is that the PLC lost the configuration file and we ask to solve the problem and they already sent PLC programmer who download the configuration file again and he informed that the PLC lost the configuration file due to may be supply problem during switching and he said that this may be will happen again. again this problem happened in another site which have a another power supply and as this is first time we are facing such problem as in old machine we never face same problem, we asked you to try to find out some solution for this problem. Actually this machine it is designed to make oil filtration and normally the supply for this machine will be by GENERATOR, if this problem happened due to the supply problem, the manufacture must think in some solution. One of these solutions is to put a AC/AC UPS to supply the PLC .PLEASE SUGGEST..
Good Answers: 53
Re: PLC PROGRAMM LOST
01/14/2008 2:50 AM
we purchased a oil filtration plant...from your good company
Whoa there!
CR4 does not supply anything. We're an engineering forum not a manufacturer.
You must have the wrong address.
Reply Score 1 for Off Topic
01/14/2008 4:33 AM
Many PLCs have an energy storage device that maintains the PLC's memory in the event of a power interruption. The user manual will give change intervals for batteries. Has the simple preventative maintenance task of changing the battery for a fresh one at regular intervals actually been carried out?
Technical Fields - Technical Writing - Validation Specialist-Medical Devices United States - Member - From the Big Apple! Hobbies - Model Rocketry - Rockets should go nuclear! Fans of Old Computers - PDP 11 - Studied computers at W.H.Taft H.S., Bronx, NY. Popular Science - Cosmology - Radio Science Observing
01/15/2008 9:59 AM
I totally agree!
Check your battery...
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
04/09/2025 5:27 AM
Invitation declined.
Re: PLC Program Problems
01/15/2008 12:22 AM
Can you define which model and make of PLC you are using
01/15/2008 6:02 AM
I had a similar problem with a PLC on a dredging boat. This boat had 2 generators which they switched daily, however they didn't turn anything off and they were not very good at synching the 2 generators to do a smooth transfer. The long and short of it is they had about 3 PLC's go bad in relatively short order (there were 3 on the boat and the failures were not consistent to one location). The PLC would lose its program, I could reprogram it and it would work but the program was only in RAM the EEPROM could not be written to. I felt that it was probably due to the generator switch over as we also had some HMI issues so I was leaning towards power glitches. I put in 3 relatively cheap UPS's, the kind used for computers, around 500VA or so, to run the PLC's, they didn't have another failure after that. It also had the side benefit of keeping the PLC's powered up even if they dropped power during the generator switch so it was kind of a win-win.
Shawn
Fans of Old Computers - Commodore 64 - New Member United States - US - Statue of Liberty - New Member Engineering Fields - Control Engineering - Process Control Engineer
01/15/2008 2:20 PM
You are right on. The generator that "guest" is using no doubt is less than a perfect source of power. The UPS's are a good idea, smooths out power and carries you through the switchovers. The only caveat is that they run on batteries and they will need to be replaced every couple of years. Many of the UPS's have monitoring software so you can check your supply voltage and check battery life and log power events.
It is impossible to defeat a fool in an argument, he wil bring you down to his level and beat you with experience.
01/15/2008 1:24 PM
Dear GUEST,
You seem to enjoy working anonymously. Come on! give your name and location - that simplifies lot of issues.
I am sorry, but I can make out that you are not able to understand the basics. You happen to be in a position which is probably forced on you, 'or' you have accepted due to compulsions and it is very clear that you are not enjoying it.
Any PLC will conk-off if power is interrupted and if its back-up (memory) battery is gone. This is especially true with certain branded old PLCs like S5 or S7. You end up loosing the whole program.
Just change the memory battery and get it reprogrammed once again.
It is a different issue that you have to ascertain how proper change-over from supply power-to-generator and vice-versa is affected.
B +ve
Good Answers: 21
01/15/2008 3:17 PM
It doesn't sound like this system is old enough to be losing the battery on the PLC. Most of the lithiums last so long now you forget about them being there unless you have them on a PM sheet.
If he is getting ugly spikes and transients on the line it will definately cause issues in the PLC.
As suggested above you can try an UPS...just put battery replacement on a regular PM annually. Also, I would stick in a 1:1 isolation xfmr. Do the normal clean power stuff. If still an issue go to a little sola or equiv DC supply and change out the PLC rack supply to run on DC.
Certainly, unless your warranty expressly forbids, your engineer ought to have a copy of the program and the software to deal with it.
Speed doesn't kill. Sudden stops, brick walls, and old ladies in Buicks do.
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
01/20/2008 1:17 PM
I suppose all given advices won't deliver desired result. Simply your company deals with not good supplier. Either "good supplier" its turn had been supplied bad PLC decision.
As was said at forum --- EEPROM and NVRAM both are securing enough time span (for years) to be assured that all stored data won't be lost in any worst case. You've told that PLC loses config file. Be honest it's simply should be practically impossible event for certified PLC being designed for industrial application. Its might be suspended, some wrongdoing but even as though it loses config data it should restore default factory data. Though "should" or "would" just is not the same and depends of "developer's" conscience.
BTW to blame Power supply interrupts (or blackouts) is lovely excuse of any "bad" developer (though it is impossible notion as developer simply can't be bad).
There are a lot of program techniques to shun such casualties. WatchDog timer (when PLC reset itself compulsory), storing data in energy-independ memory and so on.
AND There are a lot of ways (unfortunately) even having used known brands like Siemens or Omron download there code full of not-fixed bugs which could play their bad role for memory write/read operations.
You said that had been experienced the same problems for other machine. It's bad sign and trend. So I think even a wagon of UPS' won't bring remedy.
Here there are whether bugs-full codding either bad designed architecture of PLC or both of ones. Concrete type of employed internal PLC power supply is significant as well.
If I were you, I would demand to fix this problem immediately. If needed a metric tone of ups to resolve bug. Your "good supplier" should deliver one for free.
AccuDave (1); AKSASEE (1); capri (1); caramba (1); PWSlack (2); ronald (1); Shawn33 (1); Switchman (1); Vulcan (1)
