Previous in Forum: Insert torx screw   Next in Forum: Right angle drawer slide?
How to calculate compressed air requirement for a plant?
01/23/2008 11:54 PM
Hi, we have different kinds of packing machines .Most of the operations in the machine are operated by pnuematic cylinder . we are planning to install some new machines . How to i calculate the compressed air requirement. Is there any formula to calculate the same . Please reply
Re: how to calculate compressed air requirement for a plant
01/24/2008 12:22 AM
You have to go for machine manual, where u get the c.f.m. of each machine, after adding each machine c.f.m., u may look for the manual of air compressors & check for the pressure & c.f.m. required. always buy 10% extra c.f.m. capacity air compressors
or u may look for the book like PNEUMATIC SYSTEM, by S.R.MAJUMBDAR (IN INDIA), the best book for designing of each pneumatic systems
surinder sharma
Good Answers: 53
01/24/2008 8:14 AM
Surinder is correct. You need to check the manufacturer's manual for each packing machine, both old and new. If the manuals don't have this information (or if you don't have the manuals, contact the manufacturer. This would be the easiest method.
If you have flowmeters on your compressed air lines, you can read off of them directly.
If you have lots and lots of time, you can analyze each machine and calculate the consumption of each cylinder at different production rates. Then you just add them up.
Personally though, I'd just make the call. Makes life easier.
01/24/2008 10:28 AM
If you do the calculations, DON'T FORGET TO ADD THE VOLUME OF THE FLOW LINES BETWEEN THE VALVE and THE ACTUATOR. That is required volume each cycle and can be significant when actuators and valves are some distance apart.
Bud Trinkel
Hobbies - HAM Radio - New Member Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member
01/25/2008 9:17 AM
Good point, Bud!
The other "gotcha" to watch out for, especially when using the manufacturers specifications is whether the flow is average or peak. For example, a machine may have several pneumatic devices that work independently as product flows through the machine. A single piece may not trigger all the devices at once, but a constant flow of product (up to the maximum throughput rate of the machine) will keep all pneumatics busy and consuming air pressure. A manufacturer may decide that the duty cycle of the machine normally will be about 50% on and 50% off, and rate the flow based on the average consumption, but in practice the machine may be pushed hard and approach 100% duty cycle at times. The same can be said for multiple machines in a production system. Normally they may consume air pressure at different times, but occasionally their "on" times might coincide, causing a temporary peak in consumption.
Should your compressor capacity be sized for this peak? Well, that depends on how you want to spend your money and what you believe will be the true duty cycle of your overall system. Larger compressors cost more money, require larger main lines, take up more floor space, etc. An alternative, and why you see them mounted on most small compressors, is to use a large reservoir tank. This works the same way a hybrid vehicle with a small gasoline engine, electric drive motor, and a storage battery works. A smaller power source device (engine or compressor) costs less and works more efficiently if it works continuously, rather that starting and stopping all the time. The storage unit (tank or battery) allows the consuming entity (electric motor in the hybrid or pneumatic cylinders in the machinery) to be fed and not starved, during a peak demand period (acceleration/peak production), then be replenished by the source during off-peak periods.
The other nice thing is that storage reservoir tanks can be distributed locally to feed individual machines or groups of machines. This allows the feed lines from the compressor to be kept relatively small, which can make a big difference if the equipment is on the other side of a large plant from the compressor.
When I was a manufacturing engineer installing a new production system, the system builder did not include a large enough reservoir, and underestimated the peak demand. We had product failures because pneumatic screwdrivers would stall out as air pressure dropped during peak usage, and they did not complete the installation of screws to the proper torque. I solved the problem by finding a very large surplus pressure tank (that had once held propane fuel) in our plant's "bone-yard" and had it refurbished. This included totally airing out to remove any residual propane, removing rust (it had been sitting outside), pressure checking and welding shut any leaks, installing new fittings and re-painting it to match the other equipment on the line (from green to dark grey). No more low torque screws!
"What, me worry?" Alfred E. Neuman
Re: How to calculate compressed air requirement for a plant?
01/25/2008 1:34 AM
Nature is unlimited, human's knowledge is limited
Good Answers: 123
01/25/2008 9:52 AM
As stated by STL Engineer , sizing of the storage system can alter the performance dramatically. In my home work shop I would occasionally out pace the air delivery of my small compressor when painting. My solution was to buy a broken air compressor at a yard sale. The storage tank would provide enough air to complete a larger section, or finish the job before the air became too low.
At work we had a different problem. Large air pumps (diaphragm) that are only used when we need to resupply foam concentrate after a fire. The station's air demands for all other times only required a 5 hp compressor. But when the large pumps were needed the air was very quickly depleted. To resolve this, we purchased a twin compressor system. Two 10 hp compressors on a single air storage tank. Under normal conditions, it will alternate between compressors each time air pressure is low. But if the first compressor is already running and the pressure drops lower, the second compressor will also run. We also kept the older 5 hp unit on line. but it will only run if the air drops below 100 psi. At that time all three compressors are running. In general, you can't buy too much compressor. Good luck.
Bob
01/25/2008 3:09 PM
It sounds like you have an existing operation and air compressor. If that is the case, you can monitor the kW of your current air compressor. You should know what the full cfm kW of the existing air compressor is and you can calculate what your current air requirement and profile is. The cfm for each new machine should be on the equipment specifications and as previously mentioned, if there is any new piping, you need to account for this.
With this method, it takes out the tedious work of auditing all the old machines, digging up the old manuals and takes into account any leaks that are in the existing system whcih can be very significant.
Anonymous Poster (1); bob c (1); BudT (1); nam70 (1); spencer (1); STL Engineer (1); Vulcan (1)
