Previous in Forum: Electrical CAD Symbols - American Standard   Next in Forum: Wind energy
Selecting Cables for Motors
01/28/2008 5:47 AM
Dear Sir,
I have following concerns when selecting cables for motor applications, Please help me to sort this out.
A) When selecting cables for motor applications what would be the current we should use to calculate voltage drop,
Running Current Or starting current or Both??
B) What would be the safe maximum allowable % voltage drop (from MSB to motor) for motor applications & lighting applications?
Re: Selecting cables for motors
01/28/2008 6:10 AM
Please refer to the current edition of the Wiring Regulations, maintained and published by the Institution of Electrical Engineers.
01/28/2008 8:01 AM
For motors you have to consider the method of starting.If u are using a starter like star delta where applied voltage is reduced, then taking full load current is in order.Direct starting depending upon the load inertia one has to decide which current to consider.If the load is a low inertia load and acceleration time is of the order of 3-4 sec then rated current can be used.If its high inertia load with motor taking longer time to reach the full rated speed then current has to be considered which ensures Voltage drop does not drop below 80%.Most of the motors are designed for acceleration at 80% Voltage.Except for High inertia loads rated current can be taken for Voltage drop calculation as starting current persists for a short time and sizing cable for that may result in over sized cables and extra cost.For high inertia drives normally current values are taken from the graphs indicating Starting Current Vs Time which shows how fast current is dropping.Needs little detailed work and experience.
01/29/2008 9:43 PM
Dear Sir,
Thnkx for your genarouse help. The application what i'm concern has following centrifugal water pump motors,
A) 1 to 4 kW submersible well water pumps with DOL starters.
B) 25 kW High lift lift water pumps with soft starter
C) 55 kW High lift lift water pumps with soft starter
Could you pl assist me to select cable sizes of above motors by advicing me to decide the allowable VOLTAGE DROP?
Register to Reply 3 comments
Anonymous Poster (1); Asitha (1); PWSlack (1)
