Have tried to obtain pro info on my rafter needs but it seems many $$$$$ are reqd to get this info--retired--don't have many $$$$$. Thought someone with structural background would be so gracious to advise .
Have a 16'x36' room with std side wall framing. Want & need atttic space for goodies
have designed rafter/joice sets as follows (wish i could figure how to get dwg here)
ceiling joice-16'- 2x6, rafters-12'-2x6 (8/12 pitch) w/ apx 22" overhang, ridge board is spliced 2x8x38' , rafter are in steel hangers & have ties across the ridge, rafters & joice are tied at the side walls with steel hangers, screwed together & lagged to the the side wall headers' , rafter/joice ties are set in 4' from each side wall giving me an 8' usable attic width. Flooring is 5/8 4x8 osb set perpendicular to the bldg. length. Roofing is 5/8 osb w/ staggered joints & std shingles. Rafter ties in every section set at approx 3' spacing w/ joices tied (screwed) by the flooring.
We have aprox 1000 lb of goodies to put up there, which equates to aprox 3.5 lb/sq'. Although the rafter pitch is substancial, the added weight of the ceiling drywall concerns me when mama starts loading her goodies up there.
Would appreciate an expert/educated opinion!
Al
