Previous in Forum: Air Conditioner - Solar Powered   Next in Forum: How To Understand Enclosure Format 2U 3U etc
26 comments
Stored Energy In a Watertower
02/04/2008 9:22 PM
Hi Guys,
Could someone show me how to calculate the horsepowers stored in a watertower.
in a small community watersupply system.
eg. 100 000 gal. elevated on a 100 foot tower structure.
I'm trying to figure out how much energy is actually stored in a watertower.
If a hydrolic motor was connected to the discharge port at the bottom, how would I
calculate the horsepower that I could possibly derive from such a system.
Don't get me wrong, I'm not trying to steal energy.
And by the way I don't have a clue, as to how much energy, it took to fill the tower in the first place.
All the best from Jens
the Electronics man.
Good Answers: 918
Re: STORED ENERGY IN A WATERTOWER
02/04/2008 9:42 PM
The formula is:
Wf = -∆PEf
Where ∆PEf is the change in potential energy.
So, the change in gravitational PE (Potential Energy) = PE = mgh
m = mass
h = height
g = 9.8 m/s/s the gravitational constant.
The problem you have is that the water is not a point mass, but some form of column. So the water at the top of the column has a higher potential energy than water at the base of the column. The average is the midpoint of the column if the column is symmetrical in shape.
Since you stated a volume you can calculate the mass by looking up the mass of 1 gallon and multiplying by 100,000.
It's up to you to climb up the tower and measure the upper and lower heights of the water.
You can find more details in Wikipedia on the Internet.
02/04/2008 9:53 PM
Thanks a million Hero
best regards
Jens
02/06/2008 1:35 PM
Also the HP will depend on the amount of water being discharged at any given moment, am I right?
Location: Somewhere in the hills of Pennsylvania, I think.
02/06/2008 1:47 PM
Yes, you are!
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
Good Answers: 246
02/06/2008 1:52 PM
Yes. In fact something that AH did not mention is that the original question might better have asked how many horsepower-hours (or, more commonly, kilowatt hours) are stored. Horsepower is, obviously, a measure of power -- the rate at which work is being done. Horsepower-hour would be a measure of energy -- the capacity for doing work.
So, an average water tower could supply thousands of horsepower for a short time, or a couple horsepower for a very long time.
Hobbies - HAM Radio - New Member Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member
02/06/2008 3:59 PM
In theory you are correct, since this is a very general statement. However, according to my calculations, for the example given by Jens in his question and with a pressure regulator set to the minimum head when the tank is near empty, a couple horsepower, let's say 2.53 hp, would drain the tank in roughly 16.7 hours at about 100 gpm, not a very long time to me, but perhaps to a housefly it would seem forever! <grin>
BTW, several thousand horsepower, say 2,530 hp, would drain the tank in about one minute, a VERY short time indeed. However, you would need piping and other equipment that would accommodate a flow of 100,000 gpm! As a comparison, the flow rate of Big Spring, near Van Buren, MO, purportedly the largest natural spring in the world, boasts an average flow rate of only about 200,000 gpm (443 ft.3/sec., to be more precise).
"What, me worry?" Alfred E. Neuman
Good Answers: 243
02/06/2008 4:03 PM
There is a heck of a gap between intheory you are correct and In the real world (my post 6).
Good thinking anyhoo.
milo
02/06/2008 4:31 PM
I don't disagree with your "real world" assessment, however, that was not how the question was asked. Perhaps Jens does have a grand plan to subvert the water distribution in his community for his own evil purposes, BUWAAHAAHAAHAA!
Jens himself says, "Don't get me wrong, I'm not trying to steal energy.", but do we believe him?
Obviously, with mechanical and electrical inefficiencies, it takes more energy to pump the water up than you could possibly get back. However, as a large energy storage system, it could make economic sense. Years ago the Union Electric company (now Ameren UE) leveled off the top of a mountain and built a ring reservoir to create the Taum Sauk Power Station, pumping water from a nearby river up at night, during off-peak power usage and reversing the flow to turn the pumps into turbine-generators during the daytime, when energy usage peaked. How was this economically feasible? Energy rates were lower at night during off-peak hours and raised dramatically during peak usage. Essentially, the plant bought energy at a very low price and resold it (less the efficiency factor) at a later time for a much higher price!
Too bad the Dam Engineers didn't prevent a rupture in 2005 that destroyed nearby wildlife, at least one family's home (sending several of the family to the hospital), and a nearby park facility, the Johnson Shut-ins.
Good Answers: 243
02/06/2008 4:39 PM
"the Dam Engineers!"
milo
Popular Science - Weaponology - Scapolie, new member.
02/06/2008 4:25 PM
Hi STL Engineer.
Here in the UK we made use of water towers to power a lot of machinery from 1880 to 1955. Before the Tower bridge in London was driven by electricity, the bascules were raised by water power from the inbuilt towers, the bascules were raised within 2 minutes! There used to be a huge steam engine that pumped water into the towers, I believe this steam engine still exsists.
In Glasgow in the 1980s they pioneered hydraulics to work Mills, Trams, lifting Bridges and whole factories, I can still remember some of the old water towers when I was 6 or 7 years old.
Nothings new, as the Romans were experts at utilising hydraulics 2,000 years ago!!!
Spencer.
02/06/2008 4:35 PM
Yes, the awesome power of water flow has great capacity (pardon the pun) for Good or for Evil. For the latter, see my reference to the rupture at the Taum Sauk reservoir in post #11 above.
Good Answers: 246
02/06/2008 6:04 PM
Time... it's all perspective. Right now I have to get up to go to the bathroom, so 16.7 hours seems like forever, and even one minute seems pretty long.
02/06/2008 4:54 PM
I don't think "The average is the midpoint of the column if the column is symmetrical in shape"
If you want to calculate the potential energy more accurately you can use the integrated formula:
If the water tower is a cylinder
E=g*p*S*(H1^2-H2^2)/2
Here
p: density of water (1t/m^3)
H1: the height of the top water level.
H2: the height of the bottom water level. (the height of the cylinder h = H1-H2)
S: the base area of the cylinder.
Good Answers: 243
Re: Stored Energy In a Watertower
02/06/2008 2:32 PM
From a real world point of view, The stored energy in the water will be less than the energy used to pump all the water into the tower. The harvesting of this energy will be akin to parastic load, and will subvert the delivery of the water.
milo
Re: Stored Energy In a Water tower
02/06/2008 2:49 PM
AH gave you the means to calculate the stored energy in the tower. However, I believe you also asked what horsepower would the system be able to generate, right?
AH was quite correct in relating the energy storage formula to the height of the CENTER OF MASS of the water (neglecting, of course the small amount in the down pipe). In a similar fashion, you can calculate the average horsepower, or the maximum (when tank is full) and the minimum (when tank is almost empty), assuming again that we neglect the water in the down pipe. I would think you would NOT want to run the tank completely out. Horsepower would drop off rapidly as the down pipe began to drain.
Generally, in a static or slow moving hydraulic system such as the water tower you want to examine the head pressure. We will neglect dynamic flow forces due to kinetic energy of the moving water which is mainly relevant to the acceleration of the hydraulic motor, not its steady state. Fortunately, in the English system, a common measure of head pressure is directly related to numbers you should already know. Head pressure can be expressed in "feet of water", or "head feet" (hd.ft.). In the case of the tank sitting on the top of (if I interpret your scenario correctly) a 100ft. tower, the minimum pressure is 100 hd.ft. and the maximum is based on the height of the tank itself. So if the tank is 20 ft. high, the maximum pressure (when the tank is full) is 120 hd.ft.
Since power is energy per unit of time, it is related to Pressure (P) and flow rate of the water. To demonstrate this we will convert to units that will work with each other.
Power = P (lbs./ft.2) X flow (ft.3/min.) = lbs.-ft./min or ft.-lbs./min.
Using conversion factors:
1 Foot of water = 62.43 lbs./ft.2
1 HP = 33,000 ft.-lbs./min
1 gal. = .1337 ft.3
And choosing a flow of 1 gpm (gallons per minute) = .1337 ft.3/min.
Then minimum available horsepower would be:
HP = (100 x 62.43 x .1337) / 33,000 = .0253 horsepower
Let's say we put a pressure regulator on the discharge so that we never use more than the minimum available. In that way we get a steady pressure from full to empty.
So say we need about 1/4 horsepower to replace an electric motor, then we have to increase the flow rate to 10 gpm to get .253 hp.
At 10 gpm, you would drain the 100,000 gal. tank in 10,000 min.= 167 hours or a little less than seven days, or one week. For those of you trying to get a feel for how much flow is 10 gpm, visualize a 10 gallon aquarium that has a hole in its bottom large enough so that the tank takes just one minute to empty. That's 10 gpm! (For you purists, I know I of course neglected the change in flow due to the change in pressure as the aquarium empties!)
You can adjust your flow rate for other tasks requiring higher horsepower and you will of course drain the tank proportionally faster. However, be sure your piping is sized correctly to handle the flow rate, there are no other pressure drops, and there is nothing in the system before the hydraulic motor and its flow control valve that acts as a flow restrictor or you may not actualize the desired horsepower.
02/06/2008 4:39 PM
A very good read, STL. You should be a teacher -- oh, I just checked and I see you have taught some classes.
I just wanted to add that the flow in a pipe is constant anywhere in the system, but the pressure may vary. It is just like current and voltage in an electric circuit. Jens, you should consider this when designing your system. What you are concerned with is the pressure drop accross the hydraulic motor, not just the pressure head at the base of the tower. Use that in your horsepower calculations. Where will the outlet from the pump discharge to? If it goes right out onto the ground, then STL's response is satisfactory because there is no backpressure. If it goes back into the municipal water supply, then the back pressure will be a big issue. Subtract the outlet pressure head from the inlet pressure head to get the head for STL's formula. Using 100ft is an assumption that there is no backpressure. In either case, you would need to ensure the motor is not contaminating the water supply.
02/06/2008 10:48 PM
Thanks STL,
I think I can go on my own from here,
And thanks to everyone, who contributed.
All the best from
Jens
Now I just want to design a hydraulic motor to extract the HPs.
But it's not really from a watertower, (I'm not about to steal energy)
but I used it as an example to make it clear to for you guys to see my problem.
However it's a very similar situation.
Now I'll do some thinking and calcs, and come back for some more help.
Again all the best
from Jens
BTW if I can help anyone with electronics (40+ years experience; retired)
I'll be happy to help out.
Hobbies - CNC - New Member
02/07/2008 12:18 AM
Horse power is a rate of energy consumption and is 550 ft-lb per second.
If you have water in a tank you have potential energy given in ft-lb. Basically if you know the weight of the water (in lb) and the hight above the point of use (in ft) you can calculate the energy you have available.
The horsepower can only be calculated if you know at which rate you will be using the water (lb per second).
I hope this answers you question.
Johan van Niekerk
02/07/2008 8:10 AM
Thanks Johan
Jens
Good Answers: 93
02/08/2008 6:34 AM
This may have been mentioned already as I have only skipped through the posts but don't forget about the efficiency of your hydraulic motor, you won't be able to extract 100% of the energy available in the water.
12/06/2008 11:31 AM
First off, you have the WRONG terminology at hand. You are asking about Potential
Energy not Horsepower. Horsepower involves some type of motion taking place by a
set amount of force over a given amount of time. 1 Horsepower is 550 foot-lbs. per 1
second or 746 Watts = 1 Horsepower. 1 Watt is equal to Force times Distance divided
into Time. In terms of Mechanical Horsepower not Electrical Horsepower, not
Indicated Horsepower for Piston Engines, not Brake Horsepower for both Piston
Engines & Electric Motors. But just straight forward Mechanical Horsepower, 1
Horsepower is equal to a Force in lbs. times Distance in feet divided into Time in
Seconds, then divided into 746. The Metric equivalent to that would be Newtons in
Force times Meters in Distance divided into Time in Seconds, measured as Joules per
second, instead of Horsepower. Whether it be Mechanical Horsepower, or Piston
Engine Horsepower or Jet Engine Thrust Horsepower, you NEED some type of MOTION
in order to calculate Horsepower. Whether it be speed, RPM, forward vehicle speed,
etc. etc. You are wanting to know how much Gravitational Potential Energy exists in
that Water Tower, not Horsepower. Because NO HORSEPOWER exists in that Water
Tower filled up with water. ONLY Potential Energy exists in a Water Tower NOT
Kinetic Energy. Kinetic Energy is the Energy of Motion such as speed or velocity.
Potential Energy is the Energy of Rest, such as inside a Water Tower. I needed to tell
you this, because your question makes absolutely no sense. You are meaning to ask,
'How much Potential Energy exists in a Water Tower, with a Height of 100 feet filled
with 100,000 gallons of water?' In that case, sure, your question can be answered by
the following:
Use the Graviational Potential Energy Formula, which is: Ug = mgh.
But first the mass of the water needs to be calculuated.
1 Gallon of water weighs 8.34 lbs. at 60 Degrees F.
100,000 Gallons of water x 8.34 lbs/gallon = 834,000 lbs.
Ug = Graviational Potential Energy.
Ug = mgh ===> mass x gravitational acceleration constant x height.
mass = 834,000 lbs = [(834,000 / 2.2)] = 379,090.91 Kg.
g = 32.2 feet per second sqaured = 9.8 meters per second squared.
h = 100 feet = [(100 / 3.28)] = 30.49 meters.
Ug = (379,090 Kg.) x (9.8 meters per second squared) x (30.49 meters) =
113,272,850.18 Newton-Meters or Joules of Potential Energy Found in Water
Tower.
For the Standard Conversion For Joules that would be Foot-Lbs.
To get Foot-Lbs. of Gravitational Potential Energy just multiply Joules times
0.737562 ===> 113,272,850.18 x 0.737562 = 83,545,749.92 Ft-Lbs.
The Water Tower Has 83,545,749.92 Foot-Lbs. of Potential Energy Within It.
If there was any motion of the water as in Kinetic Energy as in the water was
coming out of the Water Tower, then Horsepower in Foot-Lbs Per Second or
Watts could be calculated. But as long as there is no motion of the water and it is
static or resting within the Water Tower, there is no Horsepower involved. But
however, you have a great deal of information now about the Potential Energy this
Water Tower has, as in a Water Tower which is 100 feet high loaded with 100,000
gallons of water will have 83,545,749.92 Foot-Lbs of Potential Energy.
Lastly, with the given information, BTU on a Potential Energy basis could also
be used too. Because 1 BTU = 778.26 Foot-Lbs. The BTU Potential is
way to measure the Potential Energy of a Water Tower which is 100 feet
high filled with 100,000 Gallons of water. 83,545,749.92 Ft-Lbs / 778.26 Ft-Lbs =
107,349.41 BTU Potential Energy within that Water Tower.
- Airframe & Powerplant/Propulsion Engineer -
Good Answers: 246
12/08/2008 11:35 AM
If ever there was a long and meandering incorrect answer to a simple question...
As AH points out in the first post, 100 feet is probably not the correct height to use for calculating potential energy because water is not a point mass. The base of the tank could be at 100 feet with the center of mass at 120 feet, or the top of a columnar tank might be at 100 feet, with the center of mass closer to 50 feet, etc, etc. etc. So clearly we cannot calculate the PE to 10 significant digits.
I needed to tell you this, because your question makes absolutely no sense.
Everyone else seemed to have no difficulty in answering his question. The question made abundant sense, particularly since is was titled "Stored energy in a water tower". That he asks about how much "horsepower" does not make the question nonsensical... it simply means he was little loose in his terminology. Given that he is asking about stored energy, one could easily assume he is asking for an answer in horsepower-minutes, (or watt-hours, etc, etc.) Certainly, the best we can do is to point out, as AH did, that we'd need the height of the center of mass. Then the calculation is simple as can be: If that center of mass is 100 feet we can round 100,000 gallons to 800,000 lbs, and say that the energy is about 80 million foot lbs. As you can see from Johan's concise answer, 1 hp is 550 foot-lbs per second, so this potential energy could be expressed as: about 145,000 hp-seconds.
That means about 100 hp for 1450 seconds, 10 hp for 14,500 seconds, etc.
How does the OP benefit by being told "you have the WRONG terminology" or "you NEED some type of MOTION" or "NO HORSEPOWER exists in that Water Tower"... Every response from the OP seems to indicate that he is appreciative and that he "gets it" already. No need to talk down to him or shout.
10/17/2009 3:11 AM
really stupid question but how many kw per hour would you get.
Good Answers: 246
10/17/2009 12:57 PM
There are no stupid questions.
I'm guessing that you meant kilowatt-hours (kilowatts x hours) rather than kilowatt per hour (kilowatts / hours). I think the latter would be a rarely used concept in this connection: it would be an acceleration, telling you how quickly the kw output changes over time.
If you want to know how long you could power a house, for instance, kilowatt-hours will tell you this. If we assume that the tower is as described above (10 hp for 14,500 seconds) we could first convert the hp to kW: then we'd have about 7.5 kW for 14500 seconds. 14500 seconds is about 4 hours. So if your house draws an average of 7.5 kW you could run your house for 4 hours. If you bought electricity from a utility company a 10 cents per kilowatt-hour, then this amount of energy would cost you about (7.5 x 4 x .10) $3.
More typically, this much energy would be spread out over about two days, unless you heat with electricity. (If you spend about $50/mo on electricity [500 kWh at .10 per kWh] then your average consumption is about 16.7 kWh per day, whereas 7.5kW x 4h is 30 kWh).
10/17/2009 5:09 PM
Thanks Blink, for your answer.
Jens
10/14/2016 8:48 PM
Figuring out how much energy potential is straight forward. Energy potential in watts can be calculated by knowing the head (height of the water) and how much water can be delivered in GPM. There is all sorts of limiting criteria but a good rule of thumb would be HeadXFlow/10=watts. However, the only real reason to pump water up to a tower is to pressurize that water for later use, like what comes out of your faucet. Remember the 1st law of thermodynamics, energy can not be created or destroyed. So if you pass all that water through a generator you are robbing it of its energy (pressure). You are left with a dead pool of water that would not have enough pressure to pass through your faucets. Also, you will never reap more energy than it took to pump up in the first place, you will use more energy than you produced. Even if you used solar, wind, or some other free source to pump the water you are still left with a dead pool of water that cannot be easily used.
Register to Reply 26 comments
Anonymous Hero (1); Anonymous Poster (4); Blink (4); FKIA (1); Jens (3); Johan van Niekerk (1); Milo (3); Nigh (1); Scapolie (1); STL Engineer (4); vishmayor (1); WSSmith1963 (1)
