Previous in Forum: Boiler Combustion PLC's/DCS   Next in Forum: Making Alkaline Batteries Out of Old Lead Acid Batteries
Details of Fiber Glass Reinforced Polyamide Required
02/06/2008 11:15 PM
Can any one give me the details of Fiber glass reinforced polyamide. Its areas of application. Its specifications like Yield strength, etc
Blessed is the man who finds Wisdom, the man who gains understanding. Proverbs:3:13
APIX Pilot Plant Design Project - Member - New Member
Re: Details of Fiber Glass Reinforced Polyamide Required
02/07/2008 11:57 AM
Hello Macsimus
The subject of Glass reinforced Polyamide is as vast as the subject of STEEL, and it would not be possible to tell you all these comprehensively through this discussion forum. You may try the following links, which would give you very comprehensive data of all your queries:
1. http://www.omnexus.com/
2. http://www.azom.com/search.asp?q=glass%20filled%20nylon&spell=1&access=p&output=xml&ie=utf8&lr=&client=azom&site=AZOM-ARTICLES%7CAZOM-NEWS%7CAZOM-SUPPLIERS%7CAZOM-BOOKS%7CAZOM-COURSES%7CAZOM-EVENTS
There are many more sites that tell us about the various varieties of Polyamides (Nylon6, Nylon6/6, Nylon6/10, Nylon11, Nylon12, Aromatic Nylon, Polyamide-Imaide such as "Tolon" etc)
It is hoped you are able to get all the info you wished to have
Best wishes
pvhramani
Our values have to be measured by what we could offer to the society and to the world, when a "balance sheet" is drawn up at the time we leave our "foot prints on the sands of time".
02/08/2008 4:44 AM
I am chemical examiner at dry port l Lahore and come across with the testing of glassfiber filled polyamide granules bearing trade name ZYTEL, because in the chemical testing I am concerned with its composition not with its mechanical or other physical properties therefore I can only suggest to visits web-sites relating to above mentioned product, that may help out for obtaining the required data. One of the site is pasted below : ziakhan48@hotmail.com
Zytel
Zytel® is a trademark owned by DuPont and used for a number of different high strength, abrasion and impact resistant thermoplastic polyamide formulations of the family more commonly known as nylon, often with varying degrees of fiberglass, from 13% to 60%, added in for additional stiffness.
Properties
The properties of Zytel® will vary with the specific formulation. Formulation Zytel® HTN 35% Glass Reinforced Resin, consisting of 35% glass fiber by weight, has a tensile strength of around 30kpsi and a flexural modulus of 1500kpsi under room temperature conditions. Zytel® also offers good chemical resistance to common chemicals such as motor oil, transmission fluid, and methanol, and shows little thermal expansion. Other additives or treatments may be used to increase toughness, wear resistance, and temperature tolerance.
Uses
02/09/2008 2:26 AM
Hi Macsimus,
A lot of piping projects using Fiber Glass pipes and pipe fittings were carried out under my supervision in Oil & Gas and water systems. The following sites and ASME code are very interesting :
1. Ameron - Fiberglass-Composite Pipe
2. Ameron Fiberglass - Composite Pipe Div. - Composites SOURCEBOOK
3. ASME code, B31.3, Chapter VII "Non Metallic Piping and Piping Lined with Nonmetals".
Register to Reply 3 comments
Abdel Halim Galala (1); Anonymous Poster (1); pvhramani (1)
