Previous in Forum: Flanges Joints Numbers on Welded Gas Transmission pipeline   Next in Forum: Material Mixer Equipment
17 comments
Pound Rating
02/21/2008 4:21 AM
Any one can explain me the background of deciding value of pound rating like 150,300 etc. What does these figures signifies, what they mean for ?
Thanks in anticipation
Re: pound rating
02/21/2008 4:43 AM
The word 'pound' has many meanings in many different contexts.
Could you give us a clue as to which field of endeavour you are applying the term.
A pound of sugar is different to a 'pound per square inch' is different to a 'foot pound' of torque.
Re: pound rating
02/21/2008 5:13 AM
Dear Sir,
Question is related to Mechanical engineering.
Pound rating used in piping industry for presuure temp rating and for flange selection.
Re: pound rating
02/21/2008 6:39 PM
Hi Soheb,
I have often wondered about this too, as when you look at the temp/pressure rating tables, the values listed bear no obvious relationship to the rating on the flange.
I really hope someone can clear this up for both of us!
Vote for something useful this time, vote to repeal the second law of thermodynamics!
Location: Somewhere in the hills of Pennsylvania, I think.
Re: Pound Rating
02/21/2008 11:27 PM
If you're referring to pipe line flange ratings, it refers to the maximum working pressure. For example if you were designing a compressed air pipeline to operate at 100 psig, you would probably select 150 lb flanges, fittings, etc. This might be an over simplification for some, but, you get the idea and can go from here. Check with the manufacturer for ratings at elevated temperatures, etc.
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
Re: Pound Rating
02/22/2008 2:15 AM
The classes 150#, 300#, ... etc. are just considered as a categorization or family name for each group of flanges. The calling up is first created by ANSI under ANSI B16.5 and ANSI B16.47, and starting from 1998 the publications issued under ASME B16.5 (for flanges NPS 1/2" up to NPS 24") and ASME B16.47 (for flanges NPS 26" and larger) for determining what we called Pressure-Temperature Ratings.
Note. 150# Class 150 ≡ Rating 150, all three names are correct, but don't mean that the flange will withstand a pressure of 150 lb/in2 (pound per inch square). The tabulated pressure in which the flange will resist is located from ASME B16.5 and ASME B16.47 which depends on type of flange Material and Design Temperature.
To calculate the max. design pressure of any flange with a such rating, 1st you have to select the flange material and 2nd you have to select the design temperature. Please refer to the following site, it is very nice : ASME B16.5 Flanges
Register to Reply Good Answer (Score 13)
Re: Pound Rating
02/22/2008 5:15 AM
Thanks very much for your info
Re: Pound Rating
02/22/2008 11:01 AM
I was working on an answer, than decided to first read the existing ones.
I saw yours and there was no more a need for mine...
(I have expressed this in giving you an additional "Good Answer"...)
Wangito.
Never trade luck for skill.
Re: Pound Rating
02/22/2008 3:20 PM
My dears wangito and Soheb
Thank you very much and you are welcome.
Re: Pound Rating
03/02/2008 3:04 PM
Gowelding is a Very interesting site, includes vessels, heads, thickness of pipes, ASME B16.5 flanges, ASME suggested forms, welding, design stresses, European codes EN288, WPS, PQR, WPQ, P-Number, preheating, welding symbols, weld failure ... etc...etc ... etc.
Re: Pound Rating
08/03/2009 6:06 AM
wow, it really is, not interesting only but much informative also, thanks.
Re: Pound Rating
01/15/2009 11:58 AM
thanks abdel, this is really informative..regards- rodel
Re: Pound Rating
01/15/2009 1:40 PM
Thank you gabriel.rodel, you are welcome.
Re: Pound Rating
10/21/2009 4:45 AM
Same as using "S" to identify the stainless steel pipe schedules like 5S, 10S, 40S and son on. Cheers, Ash Bandy
You can't save a file naming "Con" - Expert
Re: Pound Rating
02/22/2008 2:38 AM
The desription "pound" is actually a misnomer - the correct description is "class 150" or "class 300". The class of a flange refers to the temperature/pressure ratings that the flange can safely handle - each flange class has a chart that gives the allowable pressures at various temperature, the chart can be obtained from suppliers. To state that a 150 class flange can handle 100 pounds of pressure can be dangerous without referring the specific temperature/pressure chart.
Re: Pound Rating
02/22/2008 3:56 AM
Re: Pound Rating
02/22/2008 10:35 AM
I'm glad you asked the question because at the beginning of my career someone told me what it meant and I've carried that incorrect answer along with me since then without really thinking about. You can tell I don't have to do mechanical design. Here is a link that will provide some history.
http://www.ebaa.com/pdf/pdf/FL-01.pdf
"You can't stop a bird from landing on your head, but you can keep it from building a nest there.".....Mom
Re: Pound Rating
09/11/2009 2:41 AM
It is simple to define that 100 Pounds equal to 7 Kg/Cm2. SO 150 pounds nearly equal to 10 Kg/Cm2 & 300 Pounds Equal to 21 Kg/Cm2
I hope u would have understood about his answer.
Rajakumar
Register to Reply 17 comments
Abdel Halim Galala (4); Anonymous Poster (3); Ash.Bandy (1); dincon (1); FKIA (1); gabriel.rodel (1); Randall (1); Soheb (2); user-deleted-1105 (1); wangito (1); Zaphod2Headed (1)
