Previous in Forum: dry curing   Next in Forum: acid gold plating and PGC
10 comments
Corrosion in SS 316 Pipe in Copper Sulfate + Sulfuric acid solution
02/24/2008 9:22 AM
We are electrorefining copper by Electrolysis process. We use Copper sulfate + sulfuric acid solution as electrolyte. About 50-50 mgpl Cl ion is also present in electrolyte. There are four tanks. But in one tank after every two months one pipe (10 inch) gets corroded near the flange joint. The piece looks like a mesh & all material is eaten away. Pl suggest
Good Answers: 143
Re: Corrosion in SS 316 Pipe in Copper Sulfate + Sulfuric acid solution
02/24/2008 3:07 PM
Is the flange welded on? If so, look to the weld for the problem. The solution will be a lower heat weld, non-weld joint, or different material. I have no idea why in only one tank, but sulfuric acid and -Cl ions are tough on 316.
Good Answers: 12
02/24/2008 10:52 PM
Look to see if there is a stray voltage potential between the pipe and tank or other areas of the system. You could easily be EDMing your own pipe. The irregular metal at the joint would be a natural location for discharge of ions. It would also explain why it is happening at one site and not others.
Good luck
A robot must risk his neck for his brother man, and may not cop out when there's danger all about. - Isaac Hayes' First Law of Robotics
02/25/2008 1:18 AM
Dear Devendra,
Your location semms to be in India. Would you please mail us your company details at
my mail id ruchakent@hotmail.com
Regards,
Jayesh Shah
Ruchak Enterprise
098250 34887
02/25/2008 5:52 AM
I think that the piece of pipe (10 inch) were replaced before by another grade of stainless, may be TP304 not TP316. Please check that the new piece of pipe shall be TP316.
Hobbies - DIY Welding - pipewelder
02/25/2008 2:03 PM
This sounds like your problem to me as well, could it be that someone welded the wrong pipe into the system. It all looks the same in the pipe yard and it would explain why it is only happening in the one tank. I have seen once where we bought 316 pipe and we got 304 that was mistakenly marked 316. it wasn't until we had paid for a chemical analysis test that we found what had happened. the pipe supplier was happy to pay for the test and supply a new pc. of pipe when we had the proof.
Once I replaced a section of a carbon steel tank with a ring of 304 stainless steel and in about 1 year the stainless had corroded badly in the HAZ area from galvanic corrosion. If you have dissimilar metals in the system you may need some type of isolation to keep the 2 metals from contacting each other. On smaller bore pipe we use a Di-electric union that prevents this galvanic corrosion. Just a guess but would be worth checking.
pipewelder
pipewelder
03/01/2008 5:58 PM
• "I have seen once where we bought 316 pipe and we got 304 that was mistakenly marked 316"
Really, it is a serious problem.
• "the stainless had corroded badly in the HAZ area from galvanic"
That is true, because the HAZ is the weakest zone due to heat input during welding and it becomes sensitive to galvanic.
Sometimes the corrosion in the HAZ is due to changing of microstructural of Cristal's at these area due to excessive heat input, although you weld a similar metals. That happened to 10" stainless steel pipe TP304 at 1987, where and after 5 years of construction we found the corrosion started at all HAZ and weld beads. Also, I think that there is another reason to corrosion for that pipe due to using a contaminated wire brush which used before for cleaning carbon steel weldment.
02/26/2008 1:36 AM
You can proceed a chemical analysis for the old piece of pipe to prove/insure that suspecting of being TP304.
Also, be sure that the new piece of pipe is TP316 and that grade is stenciled/marked on pipe itself.
02/25/2008 2:06 PM
Devendra,
I previously worked in a copper electorefinery were we used the same solutions. There were no corrosion problems using 316 Stainless Steel as long as all of the proper precautions were taken.
All welded materials must be 316 L grade (low carbon content). If you weld 316 chromimum carbide is formed which allows corrosion to take place.
The steel must be protected from stray electrical currents as a previous post suggested. All of our SS 316 tanks and pipes were electrically isolated from ground.
The other possibility as previouly posted is likely the one pipe that is corroding is a different grade like SS 304 or even SS 316 rather than SS 316 L.
The LOrd gives and the Lord takes away blessed be the name of the Lord.
02/29/2008 10:48 AM
I have seen stainless steel corroded by sulfates in the past, but its usually at the vapor/liquid interface. If you have sulfates in the gas phase, these tend to scavenge the oxygen in the corrosion layer of the stainless steel (the corrosion layer protects the underlying metal from being oxidized, keeping stainless steel stainless). Once these are exposed to the liquid phase, corrosion occurrs. Probably not what is happening in your application, but it may be something to look at.
03/01/2008 1:34 PM
sorry but what are the materials involved?
S.
Register to Reply 10 comments
Abdel Halim Galala (3); drobertson (1); HaroldB829 (1); healybj8 (1); pipewelder (1); ruchakent (1); strider6 (1); TVP45 (1)
You might be interested in: Lead Acid Batteries, Electrolytes, Reserve Batteries
