Previous in Forum: drilling machine manufaturers   Next in Forum: TARGETING ZERO LEAKS SYSTEMS DEPT.
8 comments
How to Avoid Taper in Punching - Foam
02/27/2008 7:13 AM
Hi all,
I'm trying to punch a circular disc out of a Polyurethane foam sheet,20mm thick,on a fly press as well as a hydraulic press.i used a wooden die .but in both the cases,i found that the edges were tapered .
I need to develop a tool for punching this PU foam sheet into different shapes,without taper. Can anyone help me in this?
Re: how to avoid taper in punching - foam
02/27/2008 7:36 AM
When you punch something with a punch and die the slugs in this case your part tend to pucker as they are pushed through the die opening, creating a taper. Put a spring loaded pad in the die opening, this should help greatly.
02/27/2008 11:47 AM
considering the material, would a closer tolerance on the punch and die also help?
phoenix911
02/27/2008 12:42 PM
Yes closer die clearence would help.
Re: How to Avoid Taper in Punching - Foam
02/27/2008 11:48 PM
If you can do so without affecting the material, try compressing the foam so that it is flat with a foot through which the punch passes once the material is compressed.
United States - Member - New Member Popular Science - Weaponology - New Member
02/28/2008 12:09 AM
Rather than a punch and die setup, I would think that a steel rule die would work better. Without knowing your application or voulme of production it is hard to say for sure, but you might also try using hot wire, or water jet in order to cut your shapes without deformity.
Men are like steel, if they lose their temper they are worthless.
02/28/2008 1:04 AM
We need to produce them in large volumes. the sheet size is , say 1 m x 1 m . This sheet need to be punched without taper, with minimal waste.
shapes may be rectangular,circular etc
Good Answers: 11
02/28/2008 3:09 AM
I use liquid laser aka water jet for all my foam cutting. Clean lines complex shapes 2d only and minimal wastage. Steve Brown, Jetling Cutting, Middlesborough if you are in the UK. He cuts all my foam and plastic from .dwg files that I email. You can do your own sheet layout if you check water jet width.
Simon
horsepower measures work, ponypower measures pleasure!
03/02/2008 12:16 AM
Dear Guest ,
wE CAN DEVLOP TOOL FOR YOU .PLEASE GIVE US SIZE OF SHEET AND THICKNESS .
Best Regards
Naresh
tag_bros@yahoo.com
India Delhi
Anonymous Poster (1); garyceng (1); mtdmaker (2); phoenix911 (1); raghava.kn (1); rcapper (1); saddlechariot (1)
