Previous in Forum: What the Whole Meaning of Word "Gear" is?   Next in Forum: Sun Lightning
87 comments
It's a Visual Thing for Me!
02/28/2008 7:25 AM
Afternoon team,
I know there are many people here who are far more intelligent than me so if my question warrants a slap, then slap away, but at least point me in the right direction when you aim your slap!
I'm an electrician by trade with experiences in HT down to 12V LV lights in houses. I've installed HV transformers, rigged and pulled HT lines up pylons, repaired wells, industrial 3 phase to domestic single phase. My problem is I want to start experimenting with basic electronics, things like motor controls and the like! I've looked at many web sites that deal with 'beginner electronics' and after the first few pages, it starts getting cloudy, I'm having difficulty visualizing what is going on! My visualization as of now is a fluid that follows a path, but after that I'm in no-mans land! Anybody care to either slap me or point me in the right direction, a web site with animated graphics or how you visualize the circuits would give me a good start!
I have always made things using the knowledge I have attained through my life and I find electronics a very large stumbling block! If I could grasp it, I truly think it would open up a whole new era of ideas for me! My future (what is left of it!) has hit the electronics wall! Anybody got a big hammer?
Good Answers: 918
Re: It's a visual thing for me!
02/28/2008 7:48 AM
Look up Circuit Cellar on the web.
Also, Digikey and Mouser are great places to get supplies.
You are on your way!
Good Answers: 143
02/28/2008 7:51 AM
No slap for you! That's not a dumb question. I was actually the other way. I had trouble with fluids till I started treating fluid flow like it was electricity and then it made sense.
In my first electronics class (in the Army), there was a guy who both knew his stuff and who could do vocal effects and he could imitate an electron flowing, then straining through a resistor, oscillating in a tank circuit and so on. A real hoot, but when we were studying at the local beer hall, it was a great aid.
I don't know if you're far enough along for something like PSPICE to be effective, but that works for some people. I'll see what else I can remember (I'm at that age where it takes me as long to remember as it does to go to the bathroom).
Hobbies - Musician - New Member United States - Member - New Member
02/28/2008 7:55 AM
02/28/2008 8:03 AM
JScott13, That looks like a good starting block! I'll take a look at that now. Cheers
Good Answers: 143
02/28/2008 8:48 AM
JScott13 posted the one I was trying to remember. Maybe 10 years back (?), I got a couple modules for a tech I hired who had "exaggerated" his resume and I thought they were good.
02/28/2008 8:53 AM
This looks like the sort of thing I'm after! It looks basic from the first lesson but that's a good thing! I need to start from scratch and get it in my head!
02/28/2008 9:11 AM
You had mentioned being a visually oriented person, that's what made me think of them. Very reasonable price for very well animated course. Circuits are "seen" working which helps bring home the concepts.
02/29/2008 8:25 AM
You hit the nail on the head there Scott, cheers again
02/28/2008 8:01 AM
Even the word 'electronics' sends shivers down my spine! Cheers AH (don't know why just yet but cheers anyway) TP45, I'm a first step begginer looking to get off on the right step! I'll take a look at that PSPICE and see if I can gleen some info from it, cheers!
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: It's a Visual Thing for Me!
02/28/2008 8:40 AM
Would you please take a look here. Electronics Workbench is so good software for education.
02/28/2008 10:06 AM
There's some thoroughly readable book(s) called, "The Art of Electronics". Others have enjoyed them, and recommend them.
Good Answers: 19
02/28/2008 10:31 AM
What do you want to do with your electronics? If you want to learn a language you can either start at the bottom and learn the vocabulary, rules of grammar, correct sentence order, collocation and so on. Or you can use the phrase book approach, where you learn useful phrases to communicate in particular situations.
If you consider your intended application(s) you could play with standard circuits that do a particular part of that application, build them and see what happens, a slightly different application a different circuit, eventually you spot a pattern. Even the best designers cut and paste circuits, why re-invent the wheel? If you haven't already invest in a breadboard for experimenting. I apologize if you know this already http://en.wikipedia.org/wiki/Breadboard Digital logic is the easiest for immediate results and works immediately, but LEDs going on and off is about as visual as it gets, analogue electronics is where it gets a bit tricky, again consider what you want to do, and good luck
02/28/2008 3:06 PM
I'd suggest playing with logic chips first, these will be easy to visualise using the 'gate' analogy or seeing them as valves/water or relays or a mixture of all 3. The great advantage is you can use switches as inputs and leds as outputs and you can use a simple battery supply and a multimeter.
The next project I'd suggest is multivibrators using transistors or a 555 timer, however you really need a 'scope at this point....
If you have a scope then move onto single transistor audio amplifiers.
Then design anti garvity, perpetual motion and time travel... (PS I show you how to build that last one in 10years time )
There was a thread a while back askingf about good electronics text books.
'The Art of Electronics' was recomended by several including me.
Have fun.... if you need a hand we will be gentle with you.
02/29/2008 8:29 AM
But Del, you showed me the time travel circuit 10 years ago using the over unity ball up a slope trick method!
02/28/2008 10:58 PM
Are you looking for a useful analogy to visualize electricity? This could help:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/watcir.html
02/29/2008 12:09 AM
You are an experiential learner. You learn by the experience of doing it. That is different from a reader or a listener, or a discusser. I'm sure that you use those other skills in your learning, but number one, you are a doer!
So, I suggest the following, and it may seem a little silly, but I'm not kidding.
First, go to a "Teacher's Store." There, you will find grade school level books on electricity, and believe it or not, they will help you visualize what is perplexing you.
2. Look at your community college or technical training schools, and sign up for a course. The two main branches which you will want to look at are:
Motors and Controls (fairly small stuff, but still mostly "mechanical" in nature.)
Radio Electronics / Integrated Circuits / Other such names (really small stuff)
If you can't do that, do buy a book. A website is okay, but nothing beats a book, you can carry it around with you, have it on the dashboard of your truck and read it when you take a ten minute break, every day. Don't rush it, just keep reading and eventually it'll start to make sense.
Buy an AM Radio kit. Read all about the parts and try to figure out "what" a part does. A resistor "resists," but at what level? Look at the circles of paint around the resistor, it is a code which tells you exactly the resistance.
Build the radio from scratch. You will learn a lot.
Perhaps one simple explanation will help you a bit, to get started. ( I had the benefit of a father who was trained by the Navy in radio electronics FIRST, then learned motors and controls, then learned line voltage stuff, and finally high voltage transmission. So, his experience and knowledge was incredibly valuable.)
Line voltage is quite simple, until you get to three phase. Then you MUST take into account the three different waves.
Radio electronics is just that, except that the waves are not 60 cycles per second, (60Hz) they are 5,000 cycles per second up to ??? 50,000,000 cycles per second (or that could be light - but then in a few years they will actually be building computers running on light waves, so there you go!)
The high cycles per second create the possibility to manipulate the electricity which is being pushed through the device at a VERY low voltage. It is the manipulation of the stream which gets our attention.
You can still imagine the circuitry as a set of pipes, filled with water, being pushed by a pump, BUT the pump is being turned on and off thousands of times a second, so the "juice" is VIBRATING through the pipes, and because of the vibrations, different devices come into play to "MODULATE" the flow, not just cut it off, turn it on.
Anyway, BEST OF LUCK! You are a curious person, and I can assure you, you will find many adventures in your travels.
I also want to share one story with you.
My father got a service call, as a "line electrician" to a school which was having several false fire alarms every day. The technicians from the alarm company could not work out the fault. My dad had a reputation for solving unique problems.
Where did he start? At the beginning, of course! He went to the panel that fed the alarm system to begin the search. And while he had his ampmeter on the line, he noticed a sudden surge in power. So he traced the feed wire on it's journey to the fire alarm box. Eventually, he opened a box and noticed an extra wire, joined to this one. It was feeding a small exhaust fan in one room near that box. Every time the fan cycled on, it drew "too much current" in a rapid fashion, which the fire alarm box "saw" as the power failing, so it send a general alarm, before the possible 'fire in the line' feeding the alarm system rendered it completely useless. Of course, it had a battery back up system to send the alarm to the fire department.
But since there was no actual disruption of power, no one else found the fault.
THAT is why, WHAT you are seeking to learn will be so invaluable. YOU will truly understand what happens when a mico-electronic circuit is giving instructions to a line voltage system and all of the errors which can occur.
Good Luck!
tomfranpat
02/29/2008 2:41 AM
Good point about the books...
the 'Ladybird' books are still seen as a very good introduction to electronics/computers/'levers,pulleys and engines' is agood one
There is a good one on how a car works, very good for new learner drivers...it's amazing how many people drive the damn things without the faitest idea of how it works.
02/29/2008 2:26 PM
Guest has a lot of good suggestions of places to go for materials, books, etc., and looks at some of the high frequency things done with electronics.
I would add to what he (she?) says by suggesting the following: start by understanding discrete electronics (which is distinct from integrated circuits - or ICs, commonly called chips). When you have a basic idea of how resistors, capacitors, inductors, diodes and transistors work individually you'll be ready to explore how they work together in circuits. You'll also be ready to begin understanding motors and motor control.
You mentioned using water as an analogy - that one's good, but sometimes other analogies from the physical world are more useful. Here are some that I hope will be useful for the discrete items I listed above:
Diode: this is like a one-way flapper valve. With flow in one direction the flapper is lifted by the flow; with attempted flow in the other direction the flapper is pressed against its seat and blocks the flow.
Resistor: this is like a narrow pipe. Imagine water flowing at 1ft per sec through a pipe. A big pipe will carry a lot of water at that (linear) flow rate; a small pipe, however, will carry a smaller amount of water - although the water is still flowing at 1ft per sec. If you want the same volume of water to flow, you'll have to apply more pressure (higher volts, for a resistor) to push the water through the pipe faster.
The resistor analogy above introduces a really useful correspondence between electicity and water: volts correlates with pressure, current correlates with flow rate.
Transistor: The actual behavior of transistors (at the semiconductor level) is bizarre; thankfully you don't need to understand it. There are two common types of transistor: junction transistors and field effect transistors.
Junction transistors are like levers: a small movement on the short end of the level matches a long movement on the long end. This matches the small current into the 'base' of the transistor causing a proportional current to flow into (or out of) the 'collector'.
Field effect transistors are like the garden hose. The more you step on it, the less water can flow through it. Applying a voltage to the 'gate' junction of the transistor (voltage here === your weight on the garden hose) affects the current that can flow through the transistor.
Capacitor:A capacitor is like a water storage tank. If it's nearly empty (matching a low voltage) it will cause only a gentle flow (low current) out of a hole at the bottom. It its full, however, the weight of the water (pressure; volts) pushes a gusher (high current) out of the hole.
Alternatively, a capacitor is a bit like a spring - compress it and it's ready to push, the more compressed it is the more push it has.
Inductor: Imagine pushing a heavy object on a smooth surface. Being heavy, it takes a lot of push (volts) to get it going (current); once it's going, however, it takes a lot of push in the other direction to stop it.
To an electronics engineer, a simple DC electric motor can be modeled as if it is made out of discrete components and a voltage source (you may have heard of 'back EMF'). There are three key concepts:
A. The more current you put through a motor, the faster it speeds up and the more torque it can apply to its load.
B. The faster the motor is running the more back EMF it produces.
C. The actual current through the motor is inversely proportional to the applied voltage minus the back EMF (i.e. the difference between the two). This means that the faster the motor is running (causing more back EMF) the less current you can push through the motor for a fixed driving voltage - which ultimately governs the motor's top no-load speed for a given driving voltage.
To control a DC motor, therefore, you want to be able to control the current - which controls the torque and therefore the acceleration of the motor - and voltage - which correlates with the speed.
If you want to know about controlling AC motors, I don't remember enough of that to help you. But you'll want to know enough to control DC motors first, since you'll learn a lot of principles along the way.
Chris
02/29/2008 5:45 PM
Cheers Chris, Some good visual stuff there! My version of a variable resistor was a lock gate that you could raise or lower, and the diode was a like a pea valve but I guess they are what makes sense to us the best! I'm going to keep on pushing on with the web course and do some experimenting too so I'm keeping my fingers crossed I don't blow something up in the process! Then again don't ya just love the smell of burning resistors in the morning!
Good Answers: 54
03/01/2008 8:20 AM
Good post Chris!
I'd like to offer a hydraulic analogy for the field-effect transistor...
My old teacher told us that you could think of it as a flow controller (hydraulic analogy). Instead of you controlling the flow with a knob, the flow (current) is controlled by the water pressure (voltage) from somewhere else.
The junction transistor is a bit more difficult to find an analogy for since the output current is determined by the input current, not voltage.
03/01/2008 7:57 AM
I forgot to say thanks Tom! I hope you stay around to tell us more stories
02/29/2008 4:09 AM
For analogue stuff: always remember to go back to Ohms law: V=IR (volts = current times resistance). It gets you quite a long way.
Then to make sure you don't burn things out P = IV (power = current times Volts)
I'll get in trouble for this off the real analogue guys, but, forget all the phase relationships and complex maths treat capacitors and inductors as frequency dependent resistors.
RC = 1/(2*pi*f*C) and RI = 2*pi*f*I
For digital stuff 1s and 0s are highs and lows, and, logic is: well, just logic. But, pay attention to the power supplies.
02/29/2008 4:27 AM
I like to envisage electronic circuits as a playground with children running about. The boys are the electrons and the girls the positive counterparts, called 'holes', which move in the opposite direction. The battery or power supply is the entrance to the park, with queues of kids (full of energy!)
Resistors are narrow passages that the kids have to squeeze through.
Inductors are turnstiles or roundabouts that don't change speed or direction easily.
Capacitors are footpaths along opposite sides of a canal that the boys and girls line up opposite but can't cross.
Transformers are roundabouts that are geared together.
Diodes are one-way gates.
Transistors are special gates that allow large groups of children through when one child appears at another entrance.
I hope this helps to envisage some of what's happening in some circuits. As you've hinted, there's analogies in the world of plumbing but some things are harder to visualise with water.
If you never change your mind, why have one? — Edward deBono
02/29/2008 4:28 AM
And have you seen anyone about this?
Australia - Member - New Member Popular Science - Cosmology - New Member Hobbies - Fishing - New Member
02/29/2008 5:14 PM
You don't know where i can get the drugs he's taking do you?
If you don't laugh, you cry.
Canada - Member - New Member
Location: Richmond Hill, Ontario (North Greater Toronto Area), Canada
02/29/2008 5:10 AM
I had the same problem. Back in the day, (WAY back), I attempted to study electronics, but once it moved beyond my ability to also liken it to the flow of water, I was lost.
So I went for aptitude testing, and discovered, to my surprise, that I have a strong mechanical aptitude and exceptional ability to visualize in 3D.
So I got into mechanical design, and haven't looked back since. Except I do think I could make use of a stronger electromechanical knowledge base.
Perhaps this would be a field where you could transfer and apply your skills and knowledge.
But when I find myself wanting in this regard, I call in a few reps from the right companies and pick their brains! They fill in the blanks for me, and in return they get the sale.
Sometimes you have to play to your strengths.
You can have it good, fast or cheap. Pick two.
02/29/2008 6:23 AM
The trouble with electrons is that you cant see them but you can if they are turned into photons and all you need is an LED to do that. Further trouble though because an LED needs a certain forward voltage before it starts to conduct, think of it like a concrete step into a building, the step must be overcome with a potential equivilent to the band gap in electron volts of the material thats makes up the LED.
Once the step is overcome current floods through the LED and if not limited by a resistor will PoP the LED.
I have developed a device called INDI-LINK that solves most of these problems and so to your own in visualising the dynamic operation of an electric circuits. Sadly I cant find anyone prepared to exploit this development in the UK and I find myself £60,000 poorer with the cost of Patents.
Im just about exhausted trying to recoup my savings but it was born of the same problem you have posted.
It has a current range of 3mA to 3-10 Amps AC or DC while requiring the minimum of forward volts (0.35 V) to produce a light signal. Its enough for the potential difference between a small Copper electode and similar Zinc to energise the device, yet you can place it in series with a 220 volt AC 10 amp electric appliance whereby it produces more light in proportion to the current level.
Anyone over the pond like to help me commercialise this product? because the UK community seems to be dead from the neck up as far as embracing invention.
INDLINK's in the photo are 0.003 to 3Amp types but this can be easily increased, A CT is also usfull if currents in the 100's of Amps are of interest.
INDI-LINK makes 'Light' of 'Current' events, a veritable window into wiring.
Popular Science - Cosmology - New Member United States - Member - New Member
02/29/2008 7:08 AM
"Anyone over the pond like to help me commercialise this product? because the UK community seems to be dead from the neck up as far as embracing invention."
Maybe KrisDel™ could help.
All worthwhile programmers know that constants always vary.
02/29/2008 7:37 AM
< scampering sound of cat and squirrel exiting stage left at the mention of £60,000 >
03/05/2008 8:43 AM
Where's Clive Sinclair when you need him!?!
Good Answers: 122
02/29/2008 9:15 AM
docrobar,
Great idea! This would be a Godsend for the field electrical Instrument & Electrical technicians troubleshooting tools. It would provide the much needed "at-a-glance" visual that could/would cut troubleshooting downtime by a large margin. There are several companies that might be interested.
Try contacting: Phoenix Contact Ltd.
P.O.Box 4100
Harrisburg, PA 17111-0100
www.phoenixcon.com
Ph: 717-944-1300
Fax: 717-944-1625
or
TURCK INC.
3000 Campus Drive
Plymouth, MN 55441-USA
Ph: 763-553-7300
Fax: 763-553-0708
www.turck_usa.com
Good luck!
02/29/2008 8:10 AM
If you have the time and desire you may want to get involved in what this site has to offer:
http://ocw.mit.edu
Over 1800 courses recorded at MIT! Amazing to me that this is available to all.
Support your local Shriners, they have provided FREE medical assistance for over 800,000 kids so far.
02/29/2008 8:24 AM
Thanks ever so much everybody, I have a good understanding of electrical circuitry when it comes to industrial or domestic stuff ie 415V three phase and 230V single phase, even down to 12V control circuits because I can follow the wires to there destination, so all that lot is mostly ingrained now! It's the stuff I can't follow around that foxes me!
I started the course yesterday on the net as suggested and up to now, it's just been stuff I did years ago at college! I'm going to go through it all if I can! My other problem is I live in Spain so Spanish colleges are out for me because I only know basic Spanish!
I'm going to see if my sister in England can send me over the Ladybird book of basic electronics to see if that can help also!
I'll let you all know how I get on and Cheers one again
Good Answers: 12
02/29/2008 11:33 PM
and don't forget Truman, you ALWAYS have the electronicers here when things don't make sense.
Bill
03/01/2008 3:23 AM
Bill, it's a great comfort to know that if I get stuck I can always ask you guys for a bit of help without getting slapped about too much!
03/01/2008 10:33 AM
"I'm going to see if my sister in England can send me over the Ladybird book of basic electronics to see if that can help also!"
Also have your sister get in touch with Del for an introductory copy of "Deltronics".
Incidentally, the link to MIT open courseware by JasBond is a good one.
-John
03/01/2008 10:59 AM
LOL I'm going to look at the MIT site while I wait for a reply from Twisted Sister Pair and of course the reply from my sister about the ladybird book! Do you refer to the Deltronic book of easy circuits for the use in Over unity and Time travel systems 'as seen on TV' ! I've read the reviews, Mrs. Jones from Cumbridge Barton said and I quote, 'Now I've discovered the secrets to unlocking the awesome power of the Over unity space time warp drive, I have so much more time in the day to do the things I never had time to do before. A must have for any modern girl'. I think it's a god send that Del wanted to share this research with us, don't you?
03/01/2008 7:22 AM
On the subject of student help...
My student efforts are not what I had hoped. It seems as though much of the math I took for granted has flown the coop. I am faced with simple problems in this beginners course and yet can not find a good source for remedial help.
I need to be able to deduce a formula given a specific circuit analysis problem. Any circuits that require straight forward applications of well known formulas don't seem to be a problem, but when I need to manipulate the formula to suit the specifics I seem lost.
Any suggestions? (thanks in advance)
03/01/2008 7:51 AM
I've just finished the first course and got 100%! I took 3 attempts repeating the course from start to finish until it sunk in! The first time, I was a bit baffled so I did it again and again until it finally clicked! Put it down on paper, ie draw the circuits and fill in the missing info using ohms law until you have the info you need! Be careful with the units. I'm so pleased with myself, that I'm going to buy the rest!
03/01/2008 12:01 PM
At the risk of getting castigated...
Electronics requires very few formulae unless maybe you are into RF. All the Thevenins teorems and the like are fine in theory...but I've never used 'em.
You seldom have fancy networks, and when you have, they can generally be simplified, rationalised, approximated, tested empirically or simulated.
Ok you need to understand the stuff so that you recognise how to rationalise to,.. say a constant current source or a voltage source and a resistance...but it's more about understanding than maths. Also most circuits are designed around standard values such that ratios rather than absolute calculated values are more important.
This maybe viewed as heresy..I'd be interested to see what the other electronics guys think.
03/01/2008 12:33 PM
Maybe I should qualify my previous post..
You need Ohms Law, and the ability to work out a potential divider.
A lot of the rest is knowing stuff....like,
'I can ignore the base current if I make the current through the potential 50 times greater than the base current'... it's that sort of approximation that makes it work...
and the understanding that the emiter resistor will provide the DC stability at some where near the calculated point.
If you can bias a single transistor common emiter circuit and understand it you are a looong way towards knowing your stuff .
(Ducks rapidly in anticipation of floods of derision)
03/01/2008 12:41 PM
Though I fully appreciate what you're saying about likelihood of using this math, at this point I just have to know.
In brief my problem is :
I am trying to solve for the resistance of a resistor in series. I have been given the source voltage and the resistance of two of the three resistors. I have also been given the voltage dropped over the mystery resistor. I need to solve for total circuit current, resistance of the unknown resistor and power consumed by the circuit.
Given that I can't calculate current without total resistance I was stumped. Knowing the voltage over the mystery resistor was 4.5 volts and that the applied current was 20 v I thought that:
4.5=20(Rx/Rt) solve for Rx
However that provided an incorrect answer.
03/01/2008 12:50 PM
Isthis a real problem or a paper problem?
If it is a real problem...you measure the voltage drop (V) across one of the known resistors (R)... this gives you the current (I) through the chain of resistors I= V/R
You then measure the voltage (u) drop across your unknown resistor (x).
x= u / (V/R)
If it is a paper problem...we need to see the whole problem...
(I'm assuming it's a DC circuit)
Dunno if this is of any help?
03/01/2008 1:00 PM
For the paper problem...
If the prob is 3 resistors in series with just one unknown.
Say 100ohm, 220ohm and unknown R. With a 20volt supply.
Current (I) down the chain of all 3 resistors is I= 20/ (100+220+R)
(from re-arranged ohms law I=V/R)
If you know the voltage drop across unknown R...
R=V/I ......you know the volt drop V....we've just worked out an expession for I (highlighted)
So plug the numbers into the expression and solve for R...
If you need help doing that, I'm sure we can show you step buy step.... but it will be easier if you give us the relevant figures.
03/01/2008 1:29 PM
Information provided regarding this series circuit (and yes dc is assumed)
R1=4.7k
R2=1.5k
Voltage over R3= 4.5V
Total applied voltage = 20V
Using what I know about ohms law I deduced-
Voltage over R1=11.75V
Voltage over R2=3.75V
My confusion arises from the fact I only have voltages. I have no resistance to work ohms law for R3 and I can't figure total current with total resistance (an assumption I'm beginning to understand must not be true).
Good Answers: 12
03/01/2008 1:24 PM
I first see a major contradiction "the applied current was 20v". Current is not measured in volts. Now if it should be "the applied voltage is 20v", this we can work with.
So we have 3 resistors in series... Lets call them R1, R2, and Rx. Lets assume they are in that sequence with Rx being on the ground side.
Lets first lump the two known resistors into one and call it RA. RA=R1+R2. The voltage across RA would be 20v-4.5v=15.5v. The current through the string would be I=15.5v/RA. This same current flows through RX so RX=4.5v/I. Total power would be 20v x I.
03/01/2008 1:35 PM
Ha... you sound like you know what you are doing... but this is begining to sound familiar...
A guy I work with (we shall call him Mick...'cos that's his name) has been doing a correspondence course in electronics....the exercises were full of missprints, missing information and barking mad questions which bore little resemblance to real electronics.
To add to the problem ..his 'tutor' was an imbecilic Scotsman who appeared to be illiterate, drunk or both...
I helped Mick by reviewing his work before he sent it off for marking and nudging him in the right direction...one lot came back marked 'D' despite being near perfect... he sent it back with a nasty letter...it came back an 'A' after re-marking.!
Be carefull you may find questions with silly units and missing information. Questions with resistors in ohms and currents in amps are generally unrepresentative of real electronics where kΩ and mA are the norm
Any how...good luck with the course... feel free to drop me a Private Message if you wish..
03/01/2008 1:39 PM
Thank you! and yes, I meant applied voltage (sorry bout that)
I did add the two known resistances to find the current. And I did know that current over the two knows would be the same current over the unknown. But for some reason this all didn't come together until just now.
Thank you all for being so patient with me as I reacquire long lost knowledge!
Man I feel a lot better now!
Good Answers: 12
03/01/2008 2:15 PM
Now that we have numbers, I=2.5 mA
RX=1.8KΩ
PT= 50mW
I must admire whomever came up with the problem because they use real world component values. Even R1 + R2 is another standard value (6.2K).
WANT SOME MORE FUN??
I have a 10 volt power supply and 3 10K resistors. I need a resistor network such that I get 3.3 volts out. There are actually 2 solutions to this problem. Can you find both of them?
Bill
03/01/2008 2:25 PM
zzzzzzzzzzzzzzzz... thud <cat slumps to floor>
03/02/2008 7:10 AM
well the first solution would be for the three resistors to be in series
VRx=Va(Rx\Rt)
for the second...
Oh, this will require some thought... "I'll be back"
03/02/2008 7:51 AM
And am I right with the math here, all three in parallel will yield 3V? Not an exact answer, but within the tolerances I'm accustomed to. Forgive me but I only just began learning the math respecting parallel circuits.
03/02/2008 8:18 AM
I can see you getting hooked on this like me! I've just managed to download the 27 video courses on the MIT site. I've been doing a whole load of examples, and it's clicked into place now. That first lesson was only about series resistors, so we've got a long way to go before we're making 'remote controlled, with web cam vision, automatic pest shooting peashooters connected via internet to the webpage of your choice'! circuits!
03/03/2008 8:02 AM
Yes, it is bit of an addiction. And as you mentioned, the more I satiate the need for information the more understanding I accumulate. Or more succinctly... studying works! The MIT link is fantastic! Hard to believe all of that is openly available to the public. I will have to go over what's there once I get some more free time.
Good Answers: 12
03/02/2008 4:14 PM
Your right on the first one. Topologically it is the same as your problem... and with 20K to the power supply and 10K to ground, you would have 1/3 the supply voltage or 3.33 volts.
The second solution is a wee bit tougher. Two equal value resistors in parallel have an equivalent resistance of 1/2 the value of a single resistor so in our case, 2 parallel resistors = 5K. So we run 2 parallel 10K resistors to ground... and the 3rd 10K resistor to the power supply, and we still get 3.33 volts out. The second solution does draw twice the power from the supply though.
I could go on and on with this, but I think I had better be good and quit for now.
Have fun
Bill
03/02/2008 8:32 AM
You only have 15.5 V! The resistors split the voltage so the other two resistors must share 15.5 V left, so now you can use the V/R=I 15.5/(R1+R2)=I to give you the circuit current! Then you can work out the VR1 and VR2 and the resistance of R3 and also the power used by all!
03/03/2008 7:39 AM
I wrote this reply before I noticed that there were several other replies. Apologies if I've covered the same ground.
--------SNIP end of edit--------------
That looks right to me.
4.5=20(Rx/Rt)
i.e. 4.5Rt = 20Rx
so 4.5(Rx+R1+R2)=20Rx
OR 4.5Rx + 4.5(R1+R2)=20Rx
So 15.5Rx = 4.5(R1+R2)
Or Rx = 9(R1+R2)/31
Did you mean like this?
Or perhaps it's easier if you just see that Rx/(R1+R2) = 4.5/15.5
03/03/2008 7:56 AM
Yes, that's the circuit. And no problem on the late entry. Every one of these explanations reinforces the concept and bolsters my understanding. I can not thank you all enough.
03/04/2008 3:38 PM
Resistors in series all see the same current flow, and their individual voltage drops add up to the total voltage across the series.
Your problem gives you the total voltage applied to the series, and the voltage drop across the mystery resistor - so by subtraction you can get the voltage drop across the pair of known resistors. Using Ohm's law you can get the current flowing through them.
The current in the mystery resistor is the same as in the others, and you have the voltage across the mystery resistor. Use Ohm's law again to calculate its resistance.
In reply to #60
03/04/2008 4:11 PM
That's what I said in post #55(ish). I'm glad you agree, I've just started the same course and I feel very at ease with resistors in series! Can't wait to do something a little more complex like resistors and a light bulb but as yet, I have had no reply from Twisted Pair or the recently published Deltronic book of easy circuits for the easily distracted so I am in limbo. What I don't want to do is go rushing in like a nutter and miss stuff out! I tried to get to grips with Electronics twenty odd years ago but couldn't get my head round it, this time I intend nailing the beast!
In reply to #60
03/04/2008 7:53 PM
Hi Odessey2001,
-John
03/05/2008 9:32 AM
If you can visualise this one you'll be doing extremely well, especially if you can do it quantitatively!
Qualitatively, you can envisage a system of pipes with water flowing through and if you get it right you can 'see' which direction the water flows in R5.
To visualise it quantitatively, use the scheme I outlined earlier using people. (There's no need for both boys and girls here, they only become necessary when you delve into semiconductors.) The rules of the game are:
* the people move through each resistor in one minute
* the space taken up by each person is dependant on the value of the resistor, eg, in the 100Ω resistor, each person lengthens the queue by 100mm (or use inches or whatever unit you like)
* the length of queue in each resistor is dependant on the number of people and the space that each takes
* people cannot 'disappear' or appear from nowhere, ie, everyone coming out of R1 must go into R2 or R5
* the length of queues must be equal at each junction
The current is then the number of people moving through the system each minute and the voltage is the length of queue.
Now envisage 16 people going into R1 (giving a queue length of 1600mm); one of those people splits off and goes into R5 (with a queue length of 400mm) and the remaining 15 go into R2 (1500mm). Meanwhile, ten people go into R3 (2000mm {=1600+400}) and join with the person coming out of R5 so that 11 go into R4 (1100mm {=1500-400}). There are therefore 26 people {16+10 or 15+11} per minute flowing through the system and the total queue length is 3100mm {1500+1600 or 1100+2000}.
The final step is to use Ohm's law (V=IR; R=V/I; queue length is the number of people per minute times the space that each takes) to calculate the effective resistance, viz, 3100mm/26 people per minute =119Ω (plus a little bit, almost a quarter).
Have fun!
In reply to #64
03/05/2008 10:16 AM
Excellent post Andy.
-John
Good Answers: 75
In reply to #64
03/05/2008 10:57 AM
Fascinating, Andy. I studied Electronics (component repair and troubleshooting, designing and building with discretes) in the US Navy, and have used the plumbing analogy many times in explaining electronics. Now I have a new model. Plumbing as a model never developed to the level of detailed logic yours reaches. I'll use it (with your permission, of course. But then, this IS a public forum, so I guess the idea isn't well protected, either, is it?) whenever I am teaching physics and general science students about electron flow, and electronics theory. Thanks for a great, and detailed, analytical tool.
Micah
In reply to #67
03/06/2008 4:30 AM
Micah
No problem to use the model; I'm glad you find it helpful. As I say, water is great for getting a qualitative feel for what is happening but is harder for quantitative analysis unless you are very familiar with working with flow rates and pressure drops. The marbles idea mentioned below also works on the same principle. It's fun thinking through the analogies; effectively it's looking at what is happening on the electron level and you can analyse even very complex systems and components with the tool.
Enjoy
Good Answers: 54
In reply to #64
03/05/2008 10:46 PM
One old teacher of mine used marbles instead of people but the learning was the same.
In his lecture, the speed at which the marbles moved was constant but it was the number of marbles that varied. Packing in the marbles more tightly represented more current. If you over-pack the marbles (exceed the current rating of the wire), you run the risk of bursting the pipe (burning the wire).
It was a nice analogy which really helped us understand things.
Good Answers: 12
03/05/2008 10:23 AM
Oh Jeez!!!
I believe this requires a technique called superposition (which fits in between series/parallel circuits and Thevenin). I studied that stuff way back in 1966 and would have to dig out the old textbook to solve it. I can see the textbook on the shelf but I would need a ladder to get to it so I will pass for now.
Bill
Good Answers: 12
03/05/2008 1:28 PM
This is probably not the most elegant solution to the problem, but it should work.
Lets assume that we apply a voltage E at point A. We don't care what E is as we will get rid of it later. This will result in 3 currents in the network... I1, I2, and I3.
Using Ohms law (I = E/R)
I1 = E/200 (200 = R1+R2)
I2 = E/300 (300 = R3+R4)
I3 = E/700 (700 = R1+R5+R4) {I noted that current flow would be in this direction because voltage at the junction of R1& R2 is greater than at the junction of R3&R4}
Total current I = I1+I2+I3 = E/200 + E/300 + E/700
the least common denominator in the above equation is 4200 so
I = 21E/4200 + 14E/4200 + 6E/4200 = (21E + 14E + 6E)/4200 = 41E/4200
I/E = 41/4200 thus E/I = 4200/41
Of course E/I = R so R = 4200/41 or R = 102.43 ohms.
The above utilized Kirchoffs current law which you probably havent gotten to yet.
What say John... am I right??
Bill
Good Answers: 12
In reply to #68
03/05/2008 1:54 PM
I was not correct...
I3 = E/600 not E/700
Total current = I1 + I2 + I3 = E/200 + E/300 + E/600
LCD is 600 so
I = 3E/600 + 2E/600 + E/600 = 6E/600 = E/100
I/E = 1/100 and E/I = R = 100 ohms
Bill
In reply to #69
03/06/2008 4:55 AM
Bill
The reason why this doesn't give you quite the right answer is that I3 is also flowing through R1 and R4, increasing the voltage across those resistors and upsetting the balance of things. To do the full, mathematical analysis, I suggest the following:
Let the current through R2 be I1; the current through R3 be I2; and the current through R5 be I3.
This gives the currents though R1 to be I1+I3 and that through R4 to be I2+I3.
The voltages across the resistors are therefore:
R1: 100 (I1+I3)
R2: 100 I1
R3: 200 I2
R4: 100 (I2+I3)
R5: 400 I3
We can then pull out a couple of simultaneous equations about the voltages at the top of R1 & R3 and that at the junction of R1, R2 & R5:
100 (I1+I3) + 100 I1 = 200 I2 + 100 (I2 + I3)
100 I1 = 100 (I2+I3) + 400 I3
Using standard mathematical methods to simplify these, you get:
I1 = 15 I3 and I2 = 10 I3
The total voltage is therefore 3100 I3 and the total current is 26 I3. The overall resistance is therefore 3100 I3 / 26 I3 = 119.23076923Ω
Apologies to those for whom algebra makes them queasy.
Andy
In reply to #68
03/05/2008 2:03 PM
Note this is a reply to 68 not 69 which you posted while I was composing.
----------------SNIP end of edit ----------------------------
I don't think so:
Look at it from the point of view of R5 initially. Looking to the left it sees R1 and R2 in parallel to E/2; looking to the right it see R3 and R4 in parallel to E/3.
Altogether that gives you 50 + 400 + 67 (well 66 and 2/3) Ohms across E/6.
You now have the current (and hence voltage) across R5 (which are different to the values you got I think). You gave me the clue I needed to get going (Thevenin!).
In reply to #70
03/05/2008 2:50 PM
If I said that the total resistance was between 100 ohms and 1000 ohms, would I be close? (I didn't see this problem in the ladybird book!)
In reply to #70
03/05/2008 6:55 PM
Okay class, try it with a slight modification as shown here:
-John
Good Answers: 12
In reply to #72
03/06/2008 12:33 PM
This one can be done solely by observation. Given voltage E at point A, voltage at R1,R2 is .5E. Similarly voltage at R3,R4 is also .5E. With no voltage difference between the ends of R5, there is NEVER any current flow through R5, thus it is not necessary to the circuit. We thus have (R1+R2) in parallel with (R3+R4), or 200 in parallel with 200, and R= 100. R5 is open.
Now to take the opposite extreme, lets make R5 = 0. We will short that sucker out.
R1 and R3 are in parallel as are R2 and R4... each with an equivalent resistance of 50 ohms. Because R1||R3 is in series with R2||R4 (|| indicates parallel), the total resistance is still 100 ohms.
Believe it or not, the above circuit does have application in the real world (ignoring R5 for the moment). Lets say that I need a 100 ohm resistor that can dissipate 1 watt of power. All I have is a handful of 100 ohm 1/4 watt. I can plug them in to R1 through R4 and I now have my 100 ohm 1 watt resistor.
Let me take this one step further, then I will quit. Lets use 1 watt resistors for R1 through R4, and build an identical circuit next to it. Now, if we connect the two circuits in parallel, we have a 50 ohm resistor which will dissipate 8 watts. If we use carbon comp resistors (low inductance properties), we now have an excellent dummy load for a hand-held transciever. Transcievers typically put out no more than 5 watts. My Dad built this in a spam can many many years ago, and I still use it today.
Sincerely
Bill
In reply to #76
03/06/2008 5:36 PM
In reply to #76
03/07/2008 1:57 AM
Try this one: construct a cube using twelve 1 Ohm resistors as the edges. What's the resistance between (any) two diagonally opposite corners.
In reply to #70
03/10/2008 8:29 AM
I decided to work through this problem to a result (mainly because Andy's answer was so close to the total resistance if R5 wasn't there i.e. 120 Ω). I've changed the values of the resistors (temporarily) and put 186V at point A to make the arithmetic (especially in this editor) easy. In each case, for example: R1 is the "name" V1 is the voltage across the resistor and I1 is the current through it.
As I said before, look at it first from the point of view of R5:
To the left it sees 93 Volts through 3Ω, and,
to the right it sees 62 Volts through 4Ω
Total resistance 31Ω, and, total Voltage 31V
So V5 = 24V, and, I5 = 1A
Now V2 = V4 + 24
V1 = 186 - V2 = 162 - V4
V3 = 186 - V4
ITotal = I1 + I3 = (162-V4)/6 + (186 - V4)/12 = (510-3V4)/12
Also ITotal = I2 + I4 = (V4 + 24)/6 +V4/6 = (4V4 + 48)/12
Clearly these two are the same so V4 = 66V
So V1 = 96V, V2 = 90V, and V3 = 120V
And now ITotal (either of the two above) = 26A
So RTotal = 186/26 = 7.154Ω
Divide by 6 and multiply by 100 to get back to the original problem gives 119.231Ω
In reply to #84
03/10/2008 9:20 AM
I'm going to have a bash at this one myself! I think I'll need a few attempts at it but nothing ventured, nothing gained! What I really don't want to do is get beyond myself! This happened last time and as a result, I lost focus, got dis-heartened and couldn't find my way back! I'm going to start part 2 of the course in the next few days (work permitting) I think it's about resistors in parallel (easy for you guys I know) but I'm after a good base to work from so bear with me for a while.
I looked at the other circuits and tried to visualize what was going on, and to a degree, I could follow but not in a quantitative manor!
Thanks to all for your input and wish me luck, I'm going in!!
Good Answers: 12
#86
In reply to #85
03/11/2008 1:04 PM
Keep the faith Truman...
I concede that alot of our playing here is a bit beyond series and parallel circuits so no one expects you to understand it all yet. If it is confusing now, that will change... the muddy waters will clear. Especially with all our handsome features (good looks).
Sincerely
Bill
In reply to #86
03/11/2008 7:48 PM
"Especially with all our handsome features (good looks)."
And someday all of us will be parallel to ground.
Good Answers: 12
03/07/2008 3:03 AM
I found a novel way to solve this circuit using delta-wye conversion. First I will redraw the circuit emphasizing the delta portion.
Rx, Ry, and Rz are the designators in the delta Wye conversion equations which are:
RA = Ry*Rz/(Rx+Ry+Rz)
RB = Rx*Rz/(Rx+Ry+Rz)
RC = Rx*Ry/(Rx+Ry+Rz)
The conversion results in the following circuit:
RB+ R3 = 157.143 ohms
RC+R4 = 128.571 ohms
(RB+R3)||(RC+R4) = 70.714 ohms (|| means in parallel)
This result added to RA = 114.286 + 70.714 => RT = 185 ohms
My other attempt at this particular problem was definitely FUBAR (bad).
Bill
In reply to #79
03/07/2008 4:13 AM
Bill
An excellent approach to this problem (even if it is dependant on somewhat esoteric knowledge). There's also a confusion of RA and RC in the scheme as you've labelled them. This is where visualising the circuit can be really helpful in checking that the maths is in order. Of the three resistors in the delta configuration, the smallest value is R1 or Rx. In the star (or wye?) configuration, the smallest two resistors (RB & RC) should be between the same two legs. If you look at the equations, there should be a symmetry there.
If you run through the rest of the calculations with that correction made {R = 28.571 + (57.143 + 100) || (114.286 + 100)}, you will come to the same result of 119Ω derived above.
Well done for identifying a good approach to this problem.
Andy
Good Answers: 12
#81
In reply to #80
03/07/2008 5:36 AM
THANK YOU ANDY!!
The print in the book I got this from has shrunk horribly since I bought the book in 1966. Maybe I managed to wash it in hot water some time over the years. After getting a set of glasses, I see that I transposed Rx and Rz. It is 02:30 am here so I am going to get some sleep and I will recrunch the numbers in the morning.
Sincerely
Bill
Good Answers: 12
#83
In reply to #79
03/07/2008 1:13 PM
As I mentioned to Andy, I accidentally transposed Rx and Rz. Here is the corrected version.
RB+R3 = 157.143 ohms
RC+R4 = 214.286
(RB+R3)||(RC+R4) = 90.659 ohms
This result added to RA = 90.659+28.571 => RTotal = 119.230 ohms
This agrees with Andy's results.
Sincerely
Bill
Good Answers: 54
03/01/2008 8:00 AM
Slap, slap, slap, slap...
Hey Truman! Everyone's given good answers here and I can't offer much in the way of additional help. So, I just gave you a massage.
'Dya like it?
Just ask, chief. I'll be here to help you if you need it.
03/01/2008 8:08 AM
You got me there Vulcan, I was looking the other way! It's going to be a long road so get your boots shined up and ready mate!
03/07/2008 8:03 AM
Another fine option I've just discovered:
Electronics and Computer Math
Seventh Edition
By Bill Deem
and Tony Zannini
I got the text for $7 (delivered) from Amazon. It contains a "study wizard" on CDROM that is worth five times the price. However, there is also a website dedicated to further study and it's available to all (buy the book or not).
http://wps.prenhall.com/chet_deem_electronic_7/2/644/164962.cw/index.html
Register to Reply 87 comments
AndyinHawick (5); Anonymous Hero (1); Anonymous Poster (3); caramba (1); docrobgar (1); geomech (1); HUX (1); JasBond (1); Johnjohn (7); JScott13 (11); micahd02 (1); Mr. Truman Brain (17); Munky (1); Odessey2001 (2); PWSlack (1); Randall (5); Sciesis2 (12); SHOCKHISCAN (1); TVP45 (2); user-deleted-1105 (10); Vulcan (3)
You might be interested in: Medical Electronics Connectors
