Hello all, I had a strange occurrence today and have been scratching my head about it. Perhaps someone could help me out. I was working on an RF based receiver antenna which is powered by 24V DC. During an alarm condition, the onboard piezo receives a dc signal which sounds the alarm, Additionally, voltage is sent through a 2 conducter in a metal pipe to another board which contains leds in series. This voltage is pulsed so as to cause the leds to light off and on. I noticed that the leds were not lighting during alarms and tested the voltage going out. There was a strange dc voltage which jumped around alot. I was surprised that when I tested for AC, I found a pretty steady 10-15V. (There is ONLY 24V DC going in) I noticed the same readings at both ends, and while testing noticed that there WAS some power running through the leds, but they were so dim, that they were hardly noticeable. I couldn't figure it out and decided to wrap everything up. However, as I was putting together the parts, a part of the circuit board contacted the metal pipe and the leds burned brightly for a second. The metal pipe is nothing more than a housing for the antenna wires, and carries no current whatsoever. I tried using various jumpers at different points on the board and saw no change. I should also note that when the leds burned brightly, it was not an alarm condition, and no power should be through the wires.
After coming home and relaxing, a few things occured to me. Is it possible that there was a problem with the ground? By touching the board to the pipe, I may have inadvertently grounded it and saw the bright leds. But again, there was no alarm condition and so power should not go to the board. Second, I thought perhaps there is very minor short between the wire and inside of the pipe. Perhaps the leds are very dim because the pipe is drawing the power and not enough is getting to the board. This might also explain the inadvertent lighting of the leds.
Any ideas and thoughts would be greatly appreciated.
