Previous in Forum: Sticky MC   Next in Forum: Standard Electrical Panel Size
difference of 50 hz and 60 hz machines
03/14/2008 5:50 AM
hello friends,
i have known about the size difference about the machines which have difference hertz operation conditions since my lessons from the university, but i do not exactly know the why 60 hz machines size smaller than the 50 hz machines size?
for the same plate values
if anyone knows i will happy friends:)
Pathfinder Tags: electric machines frequency
New Zealand - Member - New Member
Re: difference of 50 hz and 60 hz machines
03/15/2008 4:24 PM
At 60 Hz, the iron required is lower than at 50 Hz. This is due to the flux constraints of the iron.
Best regards,
Mark Empson
http://www.LMPhotonics.com | http://www.LMPForum.com
03/17/2008 12:49 AM
Voltage have a ralation V=4.44*Φ*f*P, in case of higher f, Φ requirement is less for same voltage . where pole remains same. Flux requirement less means you require less cross section of core. Thus Machine size reduces.
BNDas
Register to Reply 2 comments
