Previous in Forum: Boiler Feed Pump   Next in Forum: Open Design in Mechanical Eng.
steelwashers
03/21/2008 1:27 AM
please sent to me the dimensions of steel washers
Good Answers: 230
Re: steelwashers
03/21/2008 2:03 AM
Hello Guest,
I posted the information to you, yesterday.
Kind Regards....
Re: steelwashers
03/21/2008 2:33 AM
where is the answer
Good Answers: 230
Re: steelwashers
03/21/2008 2:52 AM
Hello Guest,
Like the cheque (check if in the USA) It is "in the mail".
Kind Regards....
Good Answers: 15
Re: steelwashers
03/21/2008 7:38 AM
For any size fastener there are several washers that are readily available (at least in the USA).
Even in the 3D cad programs there are several washers for each fastener size.
You could check in Machinery's handbook, if you have access to one.
Do a search in global spec or a site like mcmaster.com
If you're designing something that needs a specific size washer you need to supply a manufacturer's part number for it.
downhill slide to 112 (damn memor.)
Good Answers: 97
Re: steelwashers
03/23/2008 8:05 PM
How interesting...washers for fasteners...what are the washers for?
Is it actually a shim?
Is it to protect the surface of the fastened? Though flat washers are not used with lock washers.
Was it a catch all adjustment feature for use wrong bolt sizes?
Does use of washers effect tension or torsion?
Good Answers: 137
Re: steelwashers
03/25/2008 7:13 AM
What dimensions do you want them to be? Establish that, then you can find out whether suppliers can give you what you want, or something near enough.
Codey
Anonymous Poster (1); bwire (1); Codemaster (1); ddk (1); Sparkstation (2)
You might be interested in: Washers, Spring Washers, Labware Washers
