i am using CC1100 transceiver IC of TI which has 64-byte FIFO for transmission. However i am unable to write data in FIFO. but i have programmed the registers of the IC successfully. it also has SPI interface. and i am using ATmega16 as master.
if somebody has worked with a similar IC,pls help me!!
