Previous in Forum: Hyperspace Star Polytope Slicer   Next in Forum: Heathrow Terminal 5
10 comments
Mini Puzzle
04/02/2008 2:12 AM
I posted this as a comment to another thread, but, thought it could benefit from a larger audience. It is an old problem so please don't post the answer if you've seen it before.
You have a chess board with two diagonally opposite corners missing, and, 31 dominoes. One domino exactly covers two squares of the chess board. Can you cover all the 62 squares with the dominoes without cutting any?
Here's a template you can print out to try it.
Pathfinder Tags: Challenge chessboard puzzle
Re: Mini puzzle
04/02/2008 3:10 AM
Yes
You see things; and you say, 'Why?' But I dream things that never were; and I say 'Why not?' George Bernard Shaw.
Good Answers: 137
Re: Mini puzzle
04/02/2008 4:22 AM
No. I've heard it before so I won't give the game away. Clever solution.
Codey
Good Answers: 54
Re: Mini Puzzle
04/03/2008 2:27 AM
I give up. What's the secret? ffeJ
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Re: Mini Puzzle
04/03/2008 3:51 AM
Place the dominoes in diagonal fashion starting from top left to bottom right and remain on the edge. In effect place dominoes only on top and right edge of the diagram.This will require 13 dominoes.
Once you do this you will notice a perfect square of side of six boxes.
This will leave 36 squares which will hold 18 dominoes.
Cheers.
He must be very ignorant as he answers all the questions he is asked. Voltaire
Re: Mini Puzzle
04/04/2008 9:43 PM
Randall is right, it can NOT be solved.
If you have a solution please post the diagram. Following your directions the vacant square end up either one row up or one row left of the corner square which is occupied by 1/2 of the last dominoe.
Re: Mini Puzzle
04/04/2008 10:17 AM
OK, those of you who've tried it probably know now that it is impossible. So the real puzzle is to prove it.
Hobbies - Musician - guitar fan Greece - Member - Engineering Fields - Software Engineering -
Good Answers: 18
Re: Mini Puzzle
04/08/2008 4:31 AM
This puzzle is impossible. I have devised a fast proof, which I post here for revision. I don't claim is the best or even correct, but I'm quite busy to spent too much time on it. So here it is:
Let vi be the dominoes positioned in a vertical position, starting from row i and extending down to row i+1.
It is clear that the number of dominoes that are in a vertical position in the first row with the 7 squares width, must be odd, in order to allow the rest horizontal ones to fill the row. Therefore, v1 is odd. The dominoes now that are vertical starting in row 1 (which has a width of 8 squares), are V1+v2 (because V1 ones have their "feet" and V2 have their "heads" in row 2 respectively) must be even, so V2 must be odd. Continuing in the same manner, we see that all vertical dominoes starting from all rows 1-7 downwards are odd. (Obviously row 8 has no vertical dominoes starting from it.) So the total number of dominoes positioned vertically must be odd, as V1+v2+...V7 is odd (sum of odd number of odd numbers!) Consequently the dominoes positioned horizontally must be even, as the total number of dominoes is 62/2=31.
Now turn the figure 90 degrees to the left or right, and repeat the above analysis. You will reach to the conclusion that the vertical ones must be odd again. But these ones used to be horizontal before and should have been even. Oops!...
tkot
Re: Mini Puzzle
04/08/2008 5:29 AM
Brilliant,
I'm pretty sure your proof is sound, but, there is a much simpler one.
As a clue: I threw a bit of a curved ball by supplying the template instead of letting people cover two opposite corners of a real chess board.
Re: Mini Puzzle
04/09/2008 5:30 AM
SOLUTION
First: clearly the answer is no.
To prove it: simply observe that the diagonally opposite corner of a chess board are both the same colour; wherever you place a domino it covers one white and one black square; when you have place 30 dominoes you will always have two squares left of the opposite colour to those removed, and, these clearly cannot be adjacent.
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
Re: Mini Puzzle
04/09/2008 11:04 PM
Just in case someone besides me is wondering if you could get the dominoes to fit if you started with a 9 x 9 grid instead of 8 x 8:
... it still doesn't work. From this we can see that no matter what the original dimensions of the grid are, if you remove 2 squares from diagonally opposite corners, you cannot cover the grid with dominoes.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
Register to Reply 10 comments
3Doug (1); chaterpilar (1); Codemaster (1); ffej (1); irelandeng (1); Randall (3); Stirling Stan (1); tkot (1)
