Dear All
In the most operation manual of vendors are stated the following activities to be done while start a simple centrifugal pump. Assume the commissioning activities have been carried out.
- check for bearing lubrication- observe oil level in bearing housing.
- check the gland lubrication supply is turned on
- prime the pump
- open wide the suction valve
- crack open the discharge valve
- start the pump
- open the discharge valve.
The centrifugal pump is started against a closed discharge valve as load on the motor is reduced, but only for a few moments.
The indicated above rules are stated without to specifying if the header is pressurized or not. I am agree if the header has not pressure to start the pump with the discharge valve close. But if the header or discharge line is pressurized, assume we start the stand by pump and the main is in operation, how to perform this start? With the discharge valve fully open or does not matter? What about motor load when the discharge header is pressurized? Will be electrical load affected or not?
My opinion is possible to start the centrifugal pump with discharge valve fully open if the discharge header has normal operation pressure. The stand by pump will go direct to operation point of pump curve.
Please post your comments
Best Regards and thanks to all
