This is probably too much to ask for, but I'm seeking the following:
A self-expanding, non-toxic insulative foam that sets up as a rigid closed-cell structure, ideally something that is derived from organic vegetable matter, such as Ironweed oils and/or Castorbean oils, or whatever, and does not require expensive/complicated equipment to apply.
My application is to develop (hopefully) low-cost shelters, that may be made in a fashion similar to a boat hull, where a form [panels that set a large room shape, say twenty by forty feet by eight feet high] is set, ribs or spars [four inches deep by 3/4 inch wide] are erected over the form three to four feet apart, and this spray-foam material is applied, completely covering the structure to a depth of about four inches or so an surrounding the spars, making a complete air/moisture barrier--apertures for door(s) and window(s) will be set in the form. When foam has cured, the form is removed and set up for the next structure.
One thought had been to use compressed air to foam up a pour-in-place material of Ironweed/Castorbean material, and form panels in the manner of "tilt-up" concrete structures, but we would like to have as seamless a structure as possible.
Any suggestions on materials and/or techniques would be greatly appreciated
