Previous in Forum: Anti vibration pad for engine alternators   Next in Forum: hydrotest
ASME
04/12/2008 6:23 AM
Dear All,
pls.anyboby can describe the difference between process piping(i.e ASME B 31.3) & Power Piping (i.e ASME B 31.1).According to design & inspection point of view.
Thank you
Re: ASME
04/13/2008 2:11 PM
ASME B31.1 and ASME B31.3 are looks like two countries located at different continents, each of them is populated by a people characterized by their own different languages, different cultures and societies. And the both of countries are governed by a different government, different legislations, rules and laws. So, I think it is not so easy to distinguish between them in few words.
You can take a look at region/territory/province/district such as "Chapter VI, Inspection, Examination, and Testing" in both the countries to see some of differences.
Re: ASME
04/15/2008 12:06 PM
Just a brief overview
B31.1 B31.3
Scope
Fluid
Piping of:
· Electric power generation plant (external to boiler) Pr>15 psig for steam and hot water piping > 160 psig and > 120 degree Celsius
· Geothermal plant
· District heating and cooling plant
· Steam, water, oil, gas, air piping for the above but not limited to this.
Piping of:
· Refinery, chemical and process plants, textile mills, pharmaceutical plants cryogenic plants etc.
Raw material, intermediate products and final products of the above plants including services viz. steam, water, gas etc.
Design:
Categorization of fluid
Allowable for occasional load
No such provision
· 1.2 when duration< 1 hr at a time and < 80 hrs /year
· 1.15 duration < 8 hrs and < 800 hrs/year
D: non toxic, single exposure does not produce irreversible harm to human tissues ( Pr. < 150 psig, temp. -30 to 185 degree Celsius
M: Toxic, single exposure in small quantity can cause irreversible harm to human tissues.
High pressure fluid: when rating of std. component > #2500 lb rating at given temperature and pressure
Normal fluid: water, air etc.
· 1.33 when duration< 10 hrs occurrence < 100 hrs/yr
· 1.2 duration < 50hrs occurrence < 500 hrs/yr
Inspection/ NDE Based on temperature, pressure, NPS and thickness Based on fluid
Re: ASME
04/14/2012 2:28 AM
you can go to www.standardshop.org
there sale a lot of asme aws api standard and so one .can immediately download,and very cheap low price!
Abdel Halim Galala (1); Anonymous Poster (1); jackchen (1)
