Previous in Forum: seam less   Next in Forum: FORK LIFT TRUCKS
33 comments
Does water get freezed under vacuum?
04/16/2008 1:14 AM
Please let me know if water get freezed under vacuum by vacuum rate and its time. If yes, I feel there is a loss of water vapours but can not calculate. also tell me at what condition subblimation starts?
Good Answers: 101
Re: Does water get freezed under vacuum?
04/16/2008 11:10 PM
Water vaporizes in a vacuum. The greater the vacuum pressure or water temperature, the faster it vaporizes. Ice will sublimate in a vacuum.
04/16/2008 11:28 PM
add: the faster it vaporizes, the lower the temperature. Yes, water will freeze in a vacuum, and oddly, it will be boiling when it does.
04/17/2008 3:29 AM
Its true.In Yarn conditioning machines steam is generated in Vacuum conditions and is produce at55Deg Instead of the usual100Deg.C
Popular Science - Weaponology - New Member Engineering Fields - Aerospace Engineering - New Member Hobbies - Model Rocketry - New Member United States - Member - New Member
04/17/2008 8:57 AM
You are correct, Guest.
DVader, ice can certainly sublimate if under vacuum, but will remain solid ice under a certain temperature, which I can't remember off the top of my head --> Comets are stable chunks made largely of ice and begin to sublimate and make a tail of gas as they are heated by solar radiation when close enough to the sun.
To the poster, if you are putting a little bit of water in a vacuum chamber, chances are it will all boil off long before it solidifies. If you want ice in a chamber, you'll need to cool it and/or start with enough water/ice that it can cool itself down through evaporation enough to solidify at whatever pressure you are pulling down to, and not be able to pull significant energy from its container (very well insulated, and very cold container). If you are using a cryo pump to pull a hard vacuum, you'll probably want to start with VERY cold (cryo cold) ice rather than water. If you don't, the water vapor form evaporation/sublimation will be fairly considerable and will coat the cryo pump surface enough that it won't be effective (easy to fix, just heat it back up while under vacuum while running the roughing pump, but your test will be shot).
04/17/2008 3:58 PM
Comet tails may not be the water as the ice in them is a mixture of helium, hydrogen, nitrogen and ammonia with sometimes water.
04/17/2008 12:07 AM
Kindness knows no boundaries.
Good Answers: 50
04/17/2008 12:53 AM
It's the old thing that's printed on any food that contains water, needs to be cooked, and might be used in camping... They cut the time down for cooking if over 5000 feet altitude because the lower atmospheric pressure makes things boil at lower temperatures.
Good Answers: 37
04/17/2008 1:35 AM
"They cut the time down for cooking if over 5000 feet altitude..."
I believe that cooking time INCREASES with higher altitudes, because the lower temperature at boiling point means that less thermal energy is being provided per unit of time. Pressure cookers, which effectively lower the altitude by increasing the pressure inside, cook foods faster than (normal / standard) atmospheric pressure.
" Ignorance and arrogance have more in common than their last four letters. "
Good Answers: 11
04/17/2008 1:44 AM
You got it, again, Ron.
04/17/2008 7:16 AM
The fact is you better go read the cook book again, water does boil at a lower temperature, but you need increased time to compensate for the lower temperature.
Good Answers: 18
04/17/2008 8:43 AM
Yes, this is necessary because the time to deactivate (kill) bacteria is temperature sensitive. For example, if you want to destroy most bacteria in water, it is desireable to boil for 5 minutes at sea level (ie: 212F). I am lead to understand this can also be accomplished by maintaining the water at 160 F for 8 hours. If you increase your altitude, the temperature at which the water boils is reduced, so the time to kill bacteria is increased.
04/17/2008 9:01 AM
I believe it is the pressure that enables water to boil at lower temperature and not the time.
PV/T=C (constant); assuming V (volume) being constant, the only variables are P, pressure & T, temperature. Increase P then T must go down to satisfy the equation.
Good Answers: 37
04/17/2008 9:53 AM
"PV/T=C (constant); assuming V (volume) being constant, the only variables are P, pressure & T, temperature. Increase P then T must go down to satisfy the equation."
Try it with numbers to see why this is incorrect. Let V = 1 to simplify (and meet your constant volume assumption). Suppose that P = 6 and T = 2; then C = 3. If P is increased to, say, 9, then T must INCREASE to 3 to satisfy the equation.
Or rearrange terms: let PV = TC (that is, we've multiplied both sides by "T"). With V and C both constants, if P increases, so does T, and vice-versa. Q.E.D.
Good Answers: 128
04/17/2008 11:37 PM
JMSK,
That equation is from the "ideal gas law" and does not apply to the topics of liquid boiling or solid sublimating (two phases present instead of gas phase only). To boil, the temperature of the liquid must be high enough so its vapor pressure exceeds the surrounding pressure of the gas above the liquid. At standard atmospheric pressure (760mm Hg) this is 100 deg-C. As the pressure of the gas above the liquid decreases, the required vapor pressure also decreases. Thus, it boils at 50 deg-C and 92.5 mm Hg, or 10 deg-C and 9.21 mm Hg. Below 0 deg-C, the liquid phase disappears, to be replaced by the solid phase (ice). At -10 deg-C, it will sublimate at 1.95 mm Hg, and at -40 deg-C it sublimates at 0.10 mm Hg.
However, if the gaseous phase is a mixture of gases (such as N2, O2, H2O), etc. then equilibrium conditions will have the partial pressure of the water in the gas mixture equal to the vapor pressure of the liquid or solid phase in contact with the gas at the same temperature. At 100 deg-C, the partial pressure of the water vapor is the standard atmospheric pressure, so the vapor is called steam and has no N2 or O2 or other gases. At lower pressures, the water will evaporate (or the ice sublimate) until its partial pressure is equal to the vapor pressure of the water at that temperature (which is the definition of equilibrium).
In the real world, this means that if the temperature of the air is changing from a very cold night-time low to a warmer but still below freezing daytime high, your sunlight-exposed snow or ice will sublimate and actually disappear over many days without ever melting. And at night, additional ice crystals or frost will be deposited in areas which are the coldest (such as in shade).
In the comfort conditioning world you can reduce the humidity (and have condensate draining from an air conditioner) because the cold coil will condense water from the air until the partial pressure of the water vapor in the air is in equilibrium with the water liquid on the coils (this is the "dew point"). Then, when this air is mixed back into the air in the building, the total water content of the air is lower and you feel more comfortable. Look up the differences in definitions of "relative humidity" and "absolute humidity" and see if you can explain this using these terms.
--JMM
Good Answers: 50
04/18/2008 1:18 AM
So this is why when I don't use my ice cubes very often, they simple disappear from the ice trays?
Good Answers: 128
04/19/2008 11:50 AM
Vermin,
Yes. Since the refrigerant coil is colder than the ice, the partial pressure of water in the air at the coil is lower than that at the surface of the ice. So over time, you see these cubes shrinking (and rounding a little as they shrink in size). This is also the cause of "freezer burn", which happens in a sealed container with air present inside. When our children were young, we had no clothes drier, so all went onto the line outside. In winter, they would freeze then dry, so I joked that our clothes were "freeze-dried".
--JMM
04/21/2008 5:07 PM
Partially so - if you have a frost-free freezer, it has a heater that kicks in periodically and raises the temperature to where the hoar frost on the freezer walls will melt and be drawn out as condensate. Some of the ice cube surface will also melt and over weeks, they...will....go.....away......
Good Answers: 50
04/21/2008 11:43 PM
But where do they go away to??? And who is seducing the ice right out from under my freezer???
04/22/2008 8:03 AM
Shhhhh... They're sneaking out into the room with you - as water vapor in the very air you breathe. And the who is you...Cindy Lou...
Good Answers: 50
04/24/2008 2:26 AM
That flick got panned as a real POS!!!
04/24/2008 10:54 AM
Yeah, I guess it was a real sleeper, but the BOOK was a real keeper!
Good Answers: 50
04/25/2008 1:36 AM
I couldn't put it down for days! I wanted to find out how it ended... That, and I had Crazy Glue on me fingers.
04/25/2008 7:45 AM
Where's my Depends? - DNPMSL!!!
Good Answers: 50
04/17/2008 6:24 PM
Somewhat higher West of the Mississippi.
Popular Science - Weaponology - Cardio-7
04/17/2008 10:09 AM
Ah, Vermin! Because the water boils at a lower temperature with decreased atmoispheric pressure, as up on mountains or increased elevation, that means that the water temp never reaches 212 F (100 C), which means that cooking times are longer. Ever try boiling potatoes at 3,000 meters altitude?
Good Answers: 50
04/17/2008 6:26 PM
No. I was too busy flapping my arms and trying not to die.
Good Answers: 11
04/17/2008 1:32 AM
If you can get your hands on a book called "Modern Airconditioning and Refrigeration" it covers this topic well. Briefly it is a real problem when trying to dry systems out as the water can easily freeze under vac, either lots of time or applying heat can help. The other method used is vac then flush with dry nitrogen, vac, flush until satisfied.
04/17/2008 10:19 AM
I once put a beaker of water into a vacuum chamber with no boiling. I finally realized (after I started the vacuum pump and it still didn't boil) that the high heat of vaporization of water causes it to evaporate quickly, but not boil as we expect. It does not bubble up from the entire volume, but quietly disappears.
A heat source would change this quickly.
04/17/2008 11:26 AM
You are Right.But if some heat is applied steam is generated at lower temp.Good commentsand interesting discussion.
04/17/2008 11:38 AM
Many interesting branches in this discussion. But to answer your questions:
1. Yes water will freeze under a vacuum. The equilibrium for water at 32.018 deg F is 0.08859 PSIA or 0.02 in Hg. At this deep of a vacuum it is very difficult to remove enough volume to compensate for evaporation and sublimation from the very small amounts of heat added from radiation and conduction. Most vacuum pumps can not maintain a good seal and pump this low pressure.
2. Ice sublimes or turns to a gas similar to water turning to gas by evaporation. It is a function of the real humidity of the air (?) and the temperature. It starts at absolute zero and increases from there. except at 32 degrees the surface is liquid and evaporates.
To change to ice, the latent heat of freezing is around 40 BTU per pound.
The heat of vaporization is around 1,000 BTU/pound.
In a perfectly insulated container with a perfect vacuum pump, to get one pound of ice from 60 deg F water you need to remove 60 BTU (to go from 60 deg water to 32 deg water) for the sensible heat and 40 BTU for the latent heat to go from 1 pound of water at 32 deg F to one pound of ice at 32 deg F.
this would be about (theoretical) 100/10000 or .1 pounds of water evaporated to make a pound of ice .
I hope it is not confusing.
04/17/2008 1:46 PM
"I hope it is not confusing."
Well, if it is, it's not your fault...it's the Law of Confusion of Energy...
Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Automotive Engineering - ChemE in a ME world
04/17/2008 2:30 PM
Isn't there a graph in "Perry's" (Mollier Diagram?) that charts vapor pressure as a function of temperature and pressure. The rate of sublimation or evaporation is a function of the vapor pressure of the substance (water, which changes with temp and/or pressure ) and the difference in the environment pressure.
No matter how far you have gone down the wrong path....Turn around!
Good Answers: 84
01/24/2013 7:33 AM
Under vacuum conditions a cup of room temperature water will boil until it freezes. Around 1/2 to 2/3 boils away before it reaches this point. Not only, but a styrofoam cup filled with liquid nitrogen does exactly the same thing. I've made nitrogen ice this way using a home-brew vacuum chamber.
Register to Reply 33 comments
agua_doc (1); Anonymous Poster (1); Butcher (1); Cardio07 (1); case491 (1); DVader1000 (1); Emjay4119 (2); EnviroMan (5); europium (1); HarryBurt (1); jmart23 (1); JMSK (1); jmueller (2); nesubra (2); Paddler (1); Ron (2); Techart (1); vermin (7); Yani (1)
