Previous in Forum: Bobby   Next in Forum: Volcanic Rock Quarrying
8 comments
Roof Design
04/22/2008 1:35 PM
I am constructing a hall of size 35 m by 30 m I need the design guide for a roof that is supported at two ends only.
Good Answers: 74
Re: Roof Design
04/22/2008 3:47 PM
Retain a structural engineer! That is what he is paid to do.
Bruce
Re: Roof Design
04/22/2008 6:35 PM
It seems like most building agencies would require that the roof be designed and stamped by at minimum a civil engineer, and possibly even a structural engineer, especially some area of public use.
Technical Fields - Architecture - New Member Popular Science - Weaponology - New Member
Re: Roof Design
04/23/2008 7:28 AM
...like most posts from first time users, this one leaves so many unstated conditions to the question that it is virtually unanswerable by anyone who does want to give a constructive answer. Ba/ael and RCE are correct... as long as you are somewhere where there actually is a governing agency that regulates, reviews and approves the construction process. The only clue one has regarding where you intend to do this roof, is that you give your dimensions in metric... which leads one to suspect that you ain't anywhere in the jurisdictions of the US.
There are many "guides" to designing structure components. Most of them are used by architects and engineers that have endured years of education to understand all of the forces that any particular structure or component of a structure will be subjected to, such as earthquake, hurricanes and tornadoes to name a few.
Where you are located would give one some clues as to which of these events your roof might have to resist.
In the end, one would have to caution you that if this is something that you and your family will utilize, most jurisdictions would let you do this on your own (on your own head be it... literally) within limits. If this is intended to be used for public occupancy, you would be required to have a licensed professional (architect or engineer) design, sign and seal, and supervise the construction of.
Re: Roof Design
04/23/2008 7:33 AM
Yes. I ignored this thread when I noticed that no location was indicated. Good answer! Also, the roof is extremely large for the DIY approach. Mommy, I'm scared!
Re: Roof Design
04/24/2008 12:43 PM
As indicated earlier, if it is a structural component contact you local building official. He will likely tell you that you need a engineer to stamp any structural components, and in some cases, there may be nonstructural aesthetics components that require an architect's stamp in your jurisdiction. On some projects that involve structures you just need and engineers stamp.
Re: Roof Design
04/23/2008 8:44 AM
Roll Form Group www.rollformgroup.com Edmonton facility produce structure component as of standing seam Roof, why not contact them and see that is what you are looking for?
Re: Roof Design
04/24/2008 12:17 PM
Go to the 'HALF POINT' design used in mideaval europe if you can afford it because it will stay and be around for several centuries.... or just build a 'hangar' like structure and insulate it..... good luck
Good Answers: 74
Re: Roof Design
04/24/2008 1:10 PM
Hello cool moody,
One possibility is to use open web steel joists spaced at, say 2.0m (6.5') centers with a 0.76mm x 38mm (22 Ga. x 1.5") steel deck spanning between the joists.
If the joists span side to side (30m), the joist depth likely would be about 2.2m (7.2') provided the snow load does not exceed, say 2.0kPa (40 psf) and you don't clutter the roof up with too much mechanical equipment.
If the joists span end to end (35m), the joist depth would be about 2.6m (8.5 feet) with the same provisos as above.
In any event, you will need to retain a structural engineer to provide a sealed Roof Framing plan which will be required by the authority having jurisdiction in your area for an assembly occupancy such as a hall.
Bruce
Register to Reply 8 comments
Anonymous Poster (1); Architect3451 (1); ba/ael (2); CALIXMEUS (1); RCE (2); user-deleted-9 (1)
You might be interested in: Hall Effect Position Sensors, Roof Curbs
