Previous in Forum: perpetual motion yes or no   Next in Forum: Pneumatic "WANKEL" Motor Concept Idea Here...
45 comments
Constructing a thermal referigerator for home use.
05/03/2008 11:07 PM
I live in Mysore South India. I have fabricated a parabolic cooker which I use 300 days in a year to cook, meals, fry and bake my daily meals and also to make hot water. I would like to make a thermal referigerator. I have been hunting for practical design to help in its construction but have not been successful. Ideas,leads and suggestion will be thankfully accepted and appreciated.
Good Answers: 93
Re: Constructing a thermal refrigerator for home use.
05/04/2008 10:49 PM
Dear Chandu,
You need some batteries, and a Stirling engine to run from your steam (pressure cooker). Solartron, has low draw machines like refrigerators. (Iceboxes) Just an Engineer in Australia may be able to help.
You don't get wise because you got old, you get old because you were wise.
05/04/2008 11:09 PM
The referigerator I want to make does not require electricity. It uses heat and to vaporise liquid ammonia which then brings about cooling by means of a condenser. When I was a small kid in the late 1940,s we had an elecrolux which operated on heat produced by a kersene heater at the bottom.
Can you give me more information about the Australian Engineer so that I can contact him. Thaks
05/05/2008 12:07 AM
Those Electrolux refrigerators worked on what is known as a absorption refregeration cycle. The principle is well known, but I don't know if you can build it yourself. Though it has the advantage of having no moving parts it is not efficient. Of course with solar energy that may not be an issue. I am very interested in what you are doing, and would like to visit you at Mysore if possible. I am at Trivandrum, Kerala.
05/05/2008 12:32 AM
You are most welcome. If you send me your email I can send you more information on what I am doing and why on harnessing solar energy . My email is ckusbd@gmail.com
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
05/05/2008 1:25 AM
You can experiment with the available electro lux refrigerator which works on Vapour Absorption principle by replacing electrical heater provided with either hot water or steam you can have a look at the electro lux refrigerator at most of the five star hotel rooms to keep a bottle of water and soft drinks chilled good luck
crm
Run silent run deep
05/05/2008 1:36 AM
Thank you for the tip and suggestion. Will follow it up.
Re: Constructing a thermal referigerator for home use.
05/05/2008 8:17 AM
How about some pictures of the solar cooker please?
05/05/2008 10:26 AM
Sure with pleasure. Let me have your email. Mine is ckusbd@gmail.com.
05/05/2008 11:43 AM
Please place the pictures in the blog, if you do not know how to do this then send me them via email and I will do it for you. Its very easy, you need to have the pictures in .jpg form in a folder on your PC, then you click on the camera in the tool bar above and tell it where each picture is separately.
If you are unable to do this for any reason, the just send me an email first via CR4 email service and then I will send my private email address separately to you personally, please do not publish in any way!!
05/05/2008 12:22 PM
05/05/2008 12:32 PM
Simple and it works!
I guess for longer cooking periods you turn it to face the sun from time to time too....
Thanks for the picture.
05/05/2008 12:40 PM
I have developed a tracker with a small car wiper motor which follows the sun with a timer in the circuit. This overcomes constant manual ajustments which in the tropics is quite a sweaty job.
05/05/2008 6:22 PM
Pretty good. You may have something you can in India there....I am sure many people would like to not have to buy bottled gas all the time....or search for something to burn....
Good Answers: 109
05/05/2008 8:24 AM
Hi,
There are many refrigerators that operate on heat energy, do not build by yourself.
Most have a household gas-bottle and a burner as heat generator and this you can replace by some solar concentrator - should be only a small problem for you.
And: as A.G. asked for: please fotos and drawing of your cooke!
RHABE
05/05/2008 10:30 AM
Sure. Please send me your email id. Mine is ckusbd@gmail.com
Good Answers: 15
05/05/2008 8:33 AM
Most RVs and Motor homes have a refrig that works off the propane tank. You could start there and replace the flame with your solar cooker.
scotchdrnkr
05/05/2008 10:36 AM
India does not manufacture frig working on gas and the imported ones are very expensive. Here it is more economical to fabricate one.
05/07/2008 12:18 AM
Sree Krishnamurthi, you have got me thinking about this problem for some time now. Why not have a go at developing a solar refrigerator for India? The DST might be persuaded to fund the project. I would love to try.
05/07/2008 12:43 AM
I am with you. How about a plan? Any ideas and suggestion?
05/08/2008 3:13 AM
Mr.krishnamurthy&Yantram
if you send me your mailing address and email id i can send you basic working of absorption chillers i have tons of it.its lithium bromide and water mixture used extensively in todays world NH3 has its own practical problems.
crm
Run silent run deep
05/09/2008 12:03 AM
Dear crm. Looking forward to your information. Thank you. My email id: ckusbd@gmail.com
05/26/2008 1:14 PM
Dear crm
my e.mail : lebanonmushroom@hotmail.com
H. KASHANI
RESEARCHER ENGINEER , AGRO - INDUSTRY FIELD , EXCUTIVE MANAGER - CONSULTANT
Hobbies - CNC - New Member Canada - Member - Finaly got around to it.
Good Answers: 12
05/06/2008 7:45 PM
The adsorption refrigerator mentioned above works on a precise mixture of water, ammonia and hydrogen. They have no moving parts and last a long time. They consist of a generator (where the heat is applied), a condenser (where the energy is rejected), a evaporator (where energy from the product is picked up), and an absorber where the mixture comes back together. As long as you can boil water this system will work for you. The technology for this is fairly old and there should be more information out there somewhere. A redesign will probably be required as the generators used in the small refrigerator's require an intense heat source; such as a gas flame or electric element. There are thousands of this applications world wide. Where I am at the University of Toronto (Mississauga Campus), we are using waste heat from four gas turbine generators to operate a 250 Ton adsorption chiller for air Conditioning.
Good luck on your thinking outside of the box.
05/09/2008 11:15 AM
I think the word "250 Ton adsorption chiller " is an error and should be "250 Ton vapour absorption chiller ".
- S. Saran
05/24/2008 9:57 AM
Dear ICARUS
MY QUESTIONIS : CAN WE USE HEAT OR HOT WATER OR STEAM TO COOL WATER DOWN TO 5 DEGREE CETIGRADE ? for industrial purpose only .
HASAN KASHANI
E.MAIL : lebanonmushroom@hotmail.com
05/25/2008 9:47 AM
Yes we can easily do so.
05/26/2008 12:07 AM
Dear CHABDU
I AM STILL LOOKING FOR SUCH SYSTEM AND MACHINERIES RQUIRED , I THINK THE BEST PLACE TO FIND SUCH SYSTEM IS iNDIA , I WILL SEE IF I ACN GET ANY SUPPLIER OF THE SYSTEM ALL .
H. kashani
05/26/2008 7:06 AM
in India M/s Thermex india is the manufacturer based in Pune Maharashtra near Mumbi.and Brod chillers USA is another manafacturer i know and has used the machine.How ever if you have lot of waste heat its worth going for these chillers even though these chillers doesn't use electrical power you need to provide some amount of electrical energy to operate auxiliary equipment and needs lot of maintenance as the metallurgy used is cheaper and corrosion of internal parts is expensive in terms of downtime.Only trane USA manufactures the entire machine with Titanium and cost of chiller makes it unusable you need to be careful while choosing the VAM chillers.
crm
Run silent run deep
05/26/2008 1:10 PM
Dear crm
we dont have waste heat , but we have dry straw , and some used oils , so these can be used as fuel to produce hot water and or steam , and electricity cost in here is very high , particulary when the consumption is for industrial plant , so i believe it worth it provided that the cost of the system producing cold water " chiller " and electric power, as whole is reasonable .
please advice
for further details please contact .
05/08/2008 1:05 AM
One of the earliest refrigerators to be manufactured was the famous "Electrolux" refrigerator , also nicknamed as the ' flame which freezes". Our family had one imported from U.K. in the 1950s. It had a kerosene tank with a wick which burnt continuously creating cold. Its principle of operation was based on the partial vapour pressure of H2 and NH3.In my college days (1964) I was knowing the theory thoroughly.But now, I am not able to explain it in detail.However, this is well described in the book on Heat Engines , then published by the ELBS(english language book society).
Another type of refrigerators which are now widely used in industry is the vapour absorption chillers , which use thermal heat (waste heat)to produce cold. Hitachi chillers in industry are very common.
I hope, from these leads, you may be able to make a working prototype refrigerator utilising the solar energy as the source of heat energy input to create cold.
- S. Saran
industry work on this principle , and use wast heat effectively for refrigeration.
05/09/2008 12:07 AM
Thank you for the inputs and information. Will act and follow up on your suggestion of vapour absorption chillers.
05/25/2008 1:54 AM
Dear Mr SARAN 369
I WOULD LIKE TO HAVE YOUR ADVICE IF POSSIBLE REGARDING CREATING COOLING FROM HEAT . WHAT I NEED ACTUALY IS TO COOL DOWN WATER ( 8 CUBIC METER ISOLATED TANK ) TO 4 - 6 DEGREE CENTIGRADE all aroud the year , FOR INDUSTRIAL PURPOSE . PLEASE ADVICE .
M. R. I. / LEBANON
Hasan kashani
05/25/2008 9:50 AM
Technically it is quite easy and simple to do so for your requirement.
05/26/2008 12:10 AM
Dear chandu
but practically can we get supplier for such machines ? so at moment looking for suppliers in particular in india .
H. kashani
05/26/2008 3:38 AM
There are a number of manufacturers for industrial requirements in India.Once your requirements both technically and financially are worked out the appropriate manufacturer can be selected to fit your needs. If you need further assistance or information please contact me on this email id: ckusbd@gmail.com
05/26/2008 4:06 AM
There are a number of manufacturers in India who can supply the equipment for your need.But more information is required from your side to short list the manufacturers who will be suitable for you. Is it required for an industry or an individual ?. What will be the source of heat to be generated to use for cooling process like oil, electricity, solar etc. What is to be cooled and the quantity? Storage facilities of the cooled material? Appropriate Investment budget to be taken into consideration. Against these information a suitable supplier can be short listed for negotiation and finalisation. Let me know if you need more information or suggestion to help you in taking a decision for Indian equipment of high quality standards. Please contact me on this email id: ckusbd@gmail.com
05/26/2008 1:36 AM
Dear Mr Hasan Kashani,
The refrigeration system has to be designed taking into account the kind , quantity and source of heat. Please contact any supplier of vapour absorption chillers in your country or HITACHI, Japan.
Please let me know after you have successfully installed one!
- S. Saran
05/26/2008 1:30 PM
Dear saran 369
in reply to your question
the quantity and kind of heat . : the heat is heat , we can produce hot water , steam of any pressure , so we cool water and run the turbine . it is not for home cooling or home refregeration , it is for industrial purpose
Hasan kashani
05/24/2008 4:39 PM
If indeed Heat could be used to cool the home, could not the same idea apply to moving vehicles - Cars, et.al.? Could Water as coolant for Internal Combustion Engines likewise be used to cool the inside of Cars, et.al?
Mortal LIFE is all about Time Management in the Service-for-Others for the glory of GOD here on Earth.
05/26/2008 7:12 AM
Answer is NO VAM chillers cant be used for mobile application considering the size and weight of VAM chillers.
crm
Run silent run deep
06/02/2008 4:04 PM
I don't know if you've seen this but I found it in another thread.
http://lionheart.net/fridge/descript.htm
I haven't tried it but it seems reasonable.
CR4 Admin: removed broken link
06/17/2008 12:24 AM
Dear James.
Got the link. Both the ice maker and my parabola can easily be coupled. This is a very useful information.Thank you.
Chandu
06/22/2008 2:46 PM
Synopsis: use Stirling engines 'back to back' - some to collect energy, and fewer to
'chill' a well insulated ice box/refrigerator/freezer.
When I first read this thread, I was thinking that the small scale refrigerators like my parents used in the 1920/30's in west Texas where they grew up would be best. Others suggested similar situations. Commercial Ice houses have used amonia absorbtion cycle freesers for years. But the small scale ones have fallen out of favor, probably due to the toxicity of amonia and litigation costs (in the USA anyway). It is more efficent cycle than most others.
But if you can build 'a few' 'medium size' Stirling engines (not the low delta-T variety), and use one or two to generate power to 'drive' a 'cooling engine'. The cooling engine is just another Stirling engine. But if you DRIVE a Stirling Engine you can get SIGNIFICANT cooling from it. I have seen video on the internet (sorry, no URL) of it cooling and getting liquid nitrogen from air (it was dripping from what would otherwise be the 'hot end'). You don't have to drive it that hard, but you could generate a freezer/refrigerator with it.
I just purchased a book on generating a 5HP Stirling Engine (done mainly in Pakastan I think) that was pretty impressive. Evidently people have tried to go 'commercial' with it, but economics seems to happen to this venture as well as many others.
You don't need that much power. Especially if your cooler is WELL INSULATED.
In the USA, many coolers/refrigerators have under 1" of expanded polystyrene / styrofoam type insulation. Put in 4 or 5" (10 to 15CM) sealed well, and you don't need 'much' cooling. Also, in any 'freezing' area, keep a block of ice in there to give a 'cool mass' to help moderate the thermal changes and make it easier to keep the entire system cooler.
Old Ice Houses in the USA even those that used Amonia Cycle coolers eventually got the ground below them frozen for several feet. (many were effectively large insulated warehouses with the insulation going down several feet into the ground, so the ground underneath froze) I heard of some where it took a year or so after the Ice House was removed for the gound to un freeze. ... That was a LARGE thermal mass.
Best of luck. ... Jack
06/22/2008 9:43 PM
Thank you for the interesting and informative information . Could you let me know the title,author and publisher of the book on sterling engine as I would like to have a copy of it. I am also working on sterling engines for some application for rural Indian requirements for storing vaccines. Krishnamurthi
06/23/2008 7:44 AM
"How I Built a 5 Hp Stirling Engine" by L. Merrick Lockwood
Published by American Stirling in their Engines and Energy Series, copyright 2007
ISBN:0-97139181-1-5
And can be purchased direct online at:
http://www.stirlingengine.com/ecommerce/product.tcl?usca_p=t&product_id=84
US$39.95 retail. Phone:(USA)760-742-2727 Fax:(USA)858-777-3459
email: brent@stirlingengine.com for additional information.
This is where I purchased mine recently. Paperback. I could not find it on Amazon.com
No affiliation other than happy customer. -- This book is a 'technical story' of the design, problems and development of this engine. The drawings in the book are NOT the last ones done, but apparently the last ones available to the author. The 'story' is the first 2/3 of the book, and the last third are drawings of parts and the assembled mechanism. Do not expect the drawings to be enough to 'just build it', but with some work and understanding it is quite doable.
The engine suggested is a gamma type (displacer and power piston in the same piston sleeve. The initial design was not a Rhombic drive, but the author suggests this as a 'good thing', where the simplification of some things overcomes the additonal mechanical complexity.
Please let us know if you construct one! (or more!)
This engine (or a similar 'cousin') was marketed as the ST-5 in the USA with some minor success, but is no longer available.
IMHO, the market several years ago may not have supported this product, but the market today might. Especially if it could be built from more off the shelf components and reduced/minimal custom component construction.
Register to Reply 45 comments
andrew82_72422 (1); Andy Germany (4); Anonymous Poster (1); chandu krishnamurthi (16); crm (4); HASAN KASHANI (7); Icarus (1); manilaman (1); RHABE (1); saran369 (3); scotchdrnkr (1); servant74 (2); Transcendian (1); Yanthram (2)
