Previous in Forum: When do you use the terms Duct and Pipe   Next in Forum: [CAM] pressure angle vs beamlength
How to calculate Blind flange thickness ?
05/10/2008 5:13 AM
Hallo Sir I need a formula to calculate Blind flange thickness for DN 700 , 150#, carbon steel pipe
Good Answers: 61
Re: How to calculate Blind flange thickness ?
05/10/2008 4:06 PM
Just a question.
Why do you need to calculate the thickness for a standard piping item that already exists?
The thickness of a 28" (DN 700) 150# RF Blind Flange is 2.81" (71.374mm). This information is available from Flange makers and Flange Suppliers.
If you have a Blind Flange custom made to a different dimension then it will cost much, much more and unless the maker is qualified to the proper Codes then you may be in violation of the applicable Piping Code (i.e.: ASME B31.3, etc.).
Do it once and do it right
05/10/2008 11:14 PM
I agree PennPiper,
If you have a standard flange (or blind) size and its class (rating), you can obtain all its dimensions from the standard/code you follow up.
Whatever, if you like to calculate the blind flange thickness, please refer to the following CR4 Thread : can you tell me thickness calcu........
05/11/2008 2:31 AM
Dear Guest,
Also, you can see the CR4 Thread Hydro Testing and Calculating Blind Thickness
07/22/2009 5:14 PM
• For design of Non-Standard Flanges (integral & blind), see CR4 Thread Flange Hydro Pressure Analysis and you can download the following samples of design calculations: Flange_Design_Calculations.PDF & Blind_Flange_Design_Calculations.PDF.
