Previous in Forum: Eye Sight Glass   Next in Forum: Earthquake in China
26 comments
Washing Machine Balance...Walking and Banging...
05/16/2008 2:43 PM
My wife has informed me the washing machine bangs loudly and shuts off in spin cycles.
I went home after a long day and confirmed this. She explains she has dealt with un-level "walking" washers before- never bothered me about this- she went as far as leveling it on several occasions herself (bless her heart). She has never been able to keep it from walking around and banging. Now the banging is strong and the problem has bloomed. My investigation found my 06 build of home...1906 build I should say...has a warped and weak floor in the laundry/mud room. This is my root problem I suupose- and I am looking for both help in finding out what to do now for my ailing machine (what breaks down inside) and what to do as a precaution for going forward. My wife mentions put "wood" under it. Something from her childhood memory...
Good Answers: 97
Re: Washing machine balance...walking and banging...
05/16/2008 2:58 PM
Top or front loader?
A washing machine (front loader at least) is usually suspended on springs with a damper cylinders. have a look there.
My sister in law forgot to remove all the transport clamps and it was jumping badly.
Have a look at your main shaft and bearings. they may need replacement.
Finally close the door before it walks away.
05/16/2008 3:07 PM
Top loader...and it just seems to be a poor floor that prevents this thing from being "happy".
Location: "Springwood", North Tamborine Mountain. Qld. OZ.
05/17/2008 3:29 AM
The "banging" is the sound of the bowl assembly colliding with the inside of the cabinet. Some machines have a 'self compensating' leveler device coupling two feet together, usually the rear two. Is it siezed? Do you have height adjustable feet? Some machines do, usually just the one tho', to compensate for uneven floors.
You may be also able to check and re-tension the bowl 'suspension' springs. Three, usually. Grab the centre post of the agitator and push it laterally in all directions. Does it move VERY easily so that the bowl strikes the inside of the cabinet? Take off the rear panel (early Hoovers allow the removal of the front panel so you can see the thing working---great) and tension the adjusters so that the centre post is, in fact, in the centre of the machine. Without being there I can not offer you the 'seat of the pants' feel one needs, and I don't know the specific make, but use your logic. Do the adjustments in small increments so that you don't run the risk of overtightening.
And don't turn the thing on with you hands in there. Make sure it's unplugged before beginning the work.
Cheers,
Stu.
"Nothing, is as it seems." Dr Wally.
05/18/2008 12:09 PM
Stu,
Although I was troubled with initial dissambly- I have now determined that the machine is in need of adjustment. One tensioner is very lax...another moderately. The tub moves one direction very easily and I am set to correct this. I am simlutaneously adding some 2 by framework and 3/4 plywood decking construction to help get this thing a little more stabilized- thanks to additional comments on that by others.
Aside from swearing my toolbox and that "one" wrench that always seems to be needed and missing- I will conquer this. The washer is relatively new- and I have not found any broken parts yet.
Thanks to all for the tips- from everyone that spent a minute or two for responses...
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
05/19/2008 10:09 AM
Hi, GroundedinScience!
Be careful about tightening up the tensioners, as the shimmy in a tightly tensioned drum will carry more efficiently to the body of the machine. Some degree of laxity between the tensioners and the body is a good thing. I would experiment by tensioning to the mean of what's there already.
I've now read descriptions of how to deal with the walking problem in both top loaders and side loaders; and I'm curious as to which type you're dealing with.
Mark
Re: Washing Machine Balance...Walking and Banging...
05/16/2008 3:25 PM
I have a similar problem from time to time and it is usually a result of a very heavy (wet) item that isn't spread out evenly or just too much in the machine. My machine is also on a '88 (1888) floor. A heavy sheet of plywood, or two sheets screwed together, shimmed to level, up off the floor with an edging around it in which the washer sits works for me.
In my many years I have come to a conclusion that one useless man is a shame, two is a law firm, and three or more is a congress. - John Adams
Good Answers: 918
05/16/2008 3:40 PM
First, fix the floor. If that is not practical, just build a platform for the machine to sit on using 2X4 and plywood. Start with a 2X4 frame on the floor. Essentially you are building a sub floor that will distribute the weight of the washing machine over a larger area. Level the platform with shims and nail or screw it into place.
Next, sheath the 2X4 frame with 3/4" plywood and nail and screw that on.
Mark the feet of the washer where you want it to sit on the plywood. Get 4 furniture coasters that are the cup type and screw each into the plywood where the marks for the feet are.
Lift and place the washer onto the four coasters so that the washer will not walk when activated.
Level the washers using the washer's adjustable feet and test run a load.
Washers can also go out of balance when clothing gathers at one side of the rotating drum. The trick is to evenly distribute it when you first put it in.
However, get the floor fixed first, then see if the washer works correctly and go from there.
Good Answers: 230
05/16/2008 9:32 PM
Hello GroundedinScience
Some washing machines are designed to auto-balance the load by a shaking action.
This is quite OK, providing the machine is level in both directions, and is on a "non-bouncy" floor.
Your best long-term solution is to remove that faulty floor, re-pile as needed, install new flooring.
Easy fix which I have often used, is to fit a concrete paver of suitable size under the machine, ensure it is level, and level the washing machine so all four feet are placed firmly against the concrete.
The inertia of the concrete slab will allow the washing machine to auto-balance the load, without the walking problem.
Of course you could always go back to an earlier more eco-friendly version
kind Regards....
05/16/2008 11:45 PM
Dear Worried Husband,
As one of the laundry experts has pointed out (but did not go all the way) the problem is due to : eccentrical forces (mechanical term. nothing to do with the :farcical one). It is only marginally connected to your floor or indeed: its age. What happens is that on commencing the spinning cycle - when the weight is unevenly spread in the washing machine drum - that weight spinning at increased speed has a lot of energy. That energy is the force which displaces the whole machine (and load).Newer machines have electric switches which give impulses or kickstart the spin , this has the effect of reducing the weight of the un-balanced piece or clump of clothing by shedding its water content more rapidly (and limit the very powerful knocks that result in the whole machine " walking" ) . These kick/start are sometime repeated by two or three cycles. The result is very positive . They are absolutely needed for newer machines which now spin at + 1100 rpm.
(No I am not a washing salesman- but having had the same problem my suggestion is as follows) Try a thick (but properly water-proofed) slab of polystyrene foam) .This will aim at absorbing vibration . The main problem is :vibration. It has either to be dissipated or absorbed . The outer edges should have as elesewhere suggested a wooden frame which is itself anchored to your old floor .This is to totally and (finally) stop the vibration induced " walking " of your machine Can you use carriage bolts for the frame that keeps the machine steady ? These should, if possible, be sunk into the under side members of your flooring ? Variations to the above are :
1.A piece of rubber from a used conveyor belt. Itself placed flat on the polystyrene or thick foam underlay. Remember anything that may absorb vibration and as well contain the horizontal movements , is the answer.
Good luck and hope your Wife will stop sending you to the "dog house " to sleep because you are too tired to fix the problem. (Also that you do not have to change your floor-Obviously if it supports : your machine + the clothes + the water = quite passable strenght )
Labot Omnia Vincit
05/17/2008 3:26 AM
All of these guys that have answered have missed the point- this is what happens: in a frontloader, the bearing goes- resulting in excessive movement of the drum & bang etc- in toploader the base plate if alloy disintegrates- resulting in same- this prob in both cases is brought on by excessive use of soap/detergent/hot water- use cold water & will last far longer(as will your clothes!). Certainly the floor needs to be level to start with. The probs are not helped by manufacturers cutting quality to compete with cheap imports.
05/17/2008 6:56 AM
The inertial forces set up by the spin cycle can translate into 'walking' if they are off-center. The banging is caused by the barrel twisting up and down as it spins off-center.
Stop the machine, rearrange the load to balance the 'weight' of the enclosed clothing evenly around the barrel of the washing machine.
This will stop the walking and the banging. No amount of 'levelling' will help.
Mark
05/17/2008 7:33 AM
Mark,
You're absolutely right. After your comment, I re-read mine and realised that I'd made the cardinal mistake of 'assuming' (that the machine was loaded correctly in the first place). My Mrs. does it all the time. Puts a single bath sheet in with the smalls. In the spin cycles,poor bloody machine flails around some until it attains speed enough to partially overcome the imbalance. It must be said that the thing has soldiered on for the past eight years and I've only had to adjust the bowl springs once on this machine. US built. I've always had the experience that people kill machines.
So, with all of the info thus far, GroundedinScience should now have about enough to go into business repairing washing machines. No?
Cheers,
Stu.
Good Answers: 246
05/17/2008 8:34 PM
I generally agree -- although I think that the switch for imbalance shut down is on one side, so if the machine is not level, the switch can trip more frequently than it otherwise would.
My vertical spindle washer is old (1985 vintage, I'd guess) and will walk around and bang if the load gets out of kilter. Even if you start with the load apparently well-distributed and make a few mental calculations to compensate for those items that hold a lot of water versus those which hold less, it is easy to end up with the load being out of whack when the spin cycle starts. (I don't know, but suspect you could start the machine with all the clothes on one side, and that during the wash cycle, they would become randomly distributed before the spin cycle starts. I'm sure this would be the case if a butterfly beats its wings in Brazil at the right time.)
My machine has little or no damping, with the whole basket just hanging on rods, so if the floor is flexible and also not well-damped, it can reinforce the oscillation of the washer. It happens that this same washer was installed on a floor (in an earlier house) that had weakened, and fixing the floor reduced the amount of walking and frequency of imbalance trips. Now the washer is on a slab, but still trips occasionally.
I suspect a new washer would help, but mine is only 23 years old, so it seems a shame to get rid of it so soon.
Hobbies - DIY Welding - New Member Hobbies - Car Customizing - New Member
05/17/2008 7:43 AM
After moving in with my ailing mother-in-law, I noticed her washer doing a combination tango/twist type dance to a rhythmic banging sound. I first checked the flooring and replaced some faulty joists and plywood(the washer was just about ready to visit the crawl space below). The dance/music continued. I pulled the front cover off the washer and found the drum/tub was supported by four rubber bungee type things. One of those was broke, so I ordered four and replaced them all. Now it has a slight shimmy, but it doesn't dance.
05/17/2008 8:03 AM
I Had this problem with my my top loading Whirlpool Automatic Washining machine. I called mfr's service man and he told me that in vertical spin machine we should load fabric in balanced way. It means that clothes should be loaded so that they encircle the vertical spinner. This way while spinning at high speed the load is well balanced at tumbler does not hit the casing due to unbalanced centrifugal load. I found this noise problem disappeared after proper loading of clothes.
Suresh Sharma.
08/19/2009 8:22 PM
We just moved into a new house and now find our 9mo old top loader seriously imbalances in spin cycle -- even when empty! After reading above I am going to go check the front/back/side tension of the drum. Thanks to all for the comments!
08/21/2009 5:13 AM
Hi, Guest!
Judging by some of the comments made in here during the time of the discussion, adjusting the spring tensions around the drum might be a dangerous thing to do, since the balance is pre-set at the factory, and difficult to re-establish once off.
Before going to such extremes, check to see if the machine is on the level before it starts up. If it isn't, then adjust the feet until it is. Even if that is not a 100% fix, you may consider changing the wet load distribution during the spin cycles to effect an artificial balance.
Mark
05/19/2008 3:22 AM
Why are washing machines in the States invariably top loaders whereas in the UK they are invariably front loaders? What are they in other parts of the world?
Good Answers: 230
05/19/2008 7:07 AM
Hello Randall
Historically we used "coppers", which were wood-fired, and used to boil the clothes in that copper cauldron, later we used wringer type washing machines in New Zealand, all top loaders, of course.
Then when the first locally designed and assembled automatic washing machines were made here, they were top loaders.
Top loaders have the advantage, that the user does not have to stoop, to insert/remove the laundry, a distinct advantage for the senior users, or the expectant mothers.
Kind Regards....
05/19/2008 8:10 AM
Are not the front loaders designed for minimal water use as well- and completely taking over in the US now? I believe the top loading equipment is on the way out mostly...
05/19/2008 10:08 AM
Yes, here too in Aus (OZ). The current water shortage has seen a huge throw-out of top loaders in favour of front loaders. Front loaders were for the early years looked upon with suspicion due to the water level being visible through the glass. Folks thought that they would be prone to leakage. Worrying thought when the service people might be days away (due to the distances here). The indigenous industry grew much the same way as it did in NZ, with th same result.
Stu.
03/31/2009 6:10 AM
Firstly let us classify the two types of washing machines:
They are Vertical Axis (Top Loader) and Horizontal Axis (Front Loader), even though I have seen a GE horizontal Axis machine which was a top loader. The horizontal axis drum would position itself where you could lift the lid and put the clothes in.
A German uncharitably told me that the Americans are too fat to bend so they use top loaders, though I have not seen many thin Germans.
The Horizontal Axis (Front Loader) is a true washing machine and is generally twice as expensive as the Vertical Axis (Top Loader), which is an apology and can be looked at as a blender.
An innovative supplier of "Lassi", a drink made of whipped curds or whey in large quantities did this by using a Vertical Axis (Top Loader), Whirlpool
The fundamental difference is that in a Vertical Axis (Top Loader) the clothes have a relative motion with respect to the drum and rubs against the drum. In the long run this damages the clothes especially knit-wear. It is a fact that socks disappear in these washers. They get un-knit and get flushed down the drain.
Washing here is done by some form of impellor that churns the soap, water and clothes against a stationary drum and hopes to get it clean. Clothes that are delicate will soon fray due to rubbing
In contrast, in a Horizontal Axis (Front Loader), there is no relative motion between drum and the clothes and is a gentle tumble wash. As the drum turns, the clothes go up with it and then fall down. As they go up they get twisted as if wrung and then land back in the water. The rotation is often reversed in the wash cycle. If you remember in the old days when washing was done manually the person would soak the clothes in soap water and bang the clothes on a stone. The force of the bang depends on the quality and how soiled it is. This bang forces the soap and dirt to come out. This is the principle of tumble wash though the bang is gentle.
In this washing cycle there are no vibrations and all is well and if you are willing to take the soaking clothes out wring them and put them in a dryer, your machines will last indefinitely.
Well not many want to do this so you spin.
In a Horizontal Axis (Front Loader), the drum has to be floating on springs and dampers. If you try to fix it, the loads are so uneven (being Horizontal Axis the load will always be eccentric and on the bottom side), that the machine will come apart in spin.
In spinning this machine is very tricky and the springs and dampers have to be well designed. There is also a counter weight to balance the eccentric load of the floating rotating drum and is very critical. I have seen a wrongly designed machine walk the length of the cord and yank it off during trials. There is a lot of trial and error and computer simulation to arrive at the correct parameters. There is a problem with high spin speeds is that the clothes get pushed out of the holes and may cause damage. Miele circumvented this by having honeycomb interior for the drum
The spinning speed is critical and I have seen companies raising the speeds as some competitor raised it with disastrous results. Mediocre makes of Horizontal Axis (Front Loader), will certainly walk in its lifetime.
In contrast a Vertical Axis (Top Loader) the drum is fixed and the impellor rotates. If the rotating masses of the machine are dynamically balanced and the springs or dampers are properly chosen and if leveled correctly on a firm floor the machine will not walk or bang. All this is not difficult. The usual causes for problems are an indifferent make of washer. One thing of prime importance is in loading of the machine, either type. The load should be a complete mix of different types of clothes and avoid the same types. This helps to distribute the load evenly. Another cardinal rule is never overloading it with more clothes than recommended and this rule is generally broken. If you have a pile of clothes, you are going to put them all in and not wait for the next washing day. I know a stickler who puts his laundry bag on weighing scale and goes by the book.
Lastly I want to note that a washing machine is by far the most difficult to design, manufactured and maintained than any other appliance.
So when you buy one, buy the best Horizontal Axis (Front Loader), and do not compromise on this. Spend good money on it up front and save all the expenses and trouble of the future.
My parents have a Miele which is a family heirloom now and God alone knows how old it is and it is yet ticking away smoothly. Other ones came and went but this one goes on forever.
Also remember that though a person will buy a Vertical Axis (Top Loader) for cost considerations his second buy will be a Horizontal Axis (Front Loader)
There is a tide in the affairs of men. Which, taken at the flood, leads on to fortune; Omtted, all the voyage of their life is bound in shallows and in miseries
05/21/2008 12:10 AM
The washer MUST be level . There are adjustable feet on all washers to ensure that they are situated as level . If the floor under the washer is weak the washer will move around as it enters the spin mode . You have three options .
Ensure the floor under the washer is SOLID and SECURE .
Adjust the washer feet to ensure that the washer is LEVEL in all axis.
Do not overload the washer with too many clothes per load .
Note : Maytag top loading washers of the last ten years had minor spin cycle vibration troubles , they are covered by your warrenty if applicable .?
All said , i would check the floor and machine level .
What dosent kill you makes you stronger , lifes a trip so sit back and try to enjoy the nice scenery.
09/29/2008 3:59 PM
Go under the house and brace the floor. That is what we did with our 03 house...1903 house that is.
Good Answers: 230
09/29/2008 6:38 PM
Hello Guest,
I would have thought that a house built in the halcyon days of 1903 would have thicker timber and better bracing than any modern house.
Kind Regards....
09/30/2008 2:55 AM
Hi, Sparkstation!
Halcyon & well-built or not, 100 or more years would allow the timbers under a [single storey] above-ground home to sag a little. (Guest did say, "...under the house...")
Mark
Register to Reply 26 comments
Anonymous Hero (1); Anonymous Poster (4); Blink (1); Dedaelus (1); GroundedinScience (3); Hendrik (1); machine head (1); mareng (1); MarkTheHandyman (4); Neil Kwyrer (1); Randall (1); Sparkstation (3); Stueywright (3); Swellmel (1)
