I don't have all the variables, but we have a real serious problem with electrolysis on the mild steel in our aluminum kilns and would appreciate any insight into resolving it. I opened the main feed vault (12,470V/480V) and landed a 10 AWG wire to the ground rod at the source and proceeded to take measurements and ended up with more questions than answers.
General consensus with those involved, is insufficient grounding. I think that there is more to it than that.
Is there a chance that running the current to ground, from aluminum into the steel and into ground could be problematic?
If you ground the connected dissimilar metals separately, will they dissipate to ground and not interact?
Impressed potential difference is interesting.
Do any of you have any real life experience in this area?--Someone mentioned the process of putting saw logs into saltwater using a regular procedure, mentioned in a thread about preserving wood/PEG?boat. Saltwater logs could be a portion of our problem.
I apologize about the lack of specific info, but I have to go read to my children for bed--Thanks in advance
