Previous in Forum: Dry Gas/Wet Gas   Next in Forum: Flow Meter for Liquid Fuel
11 comments
CONVERT FOR ME 3.145 METERS OF H2O TO CUBIC METERS PER HOUR
05/30/2008 2:40 AM
Re: CONVERT FOR ME 3.145 METERS OF H2O TO CUBIC METERS PER HOUR
05/30/2008 2:51 AM
Those units do not convert - is something missing?
05/30/2008 3:34 AM
05/30/2008 5:13 AM
Google 'convert' followed by the units..
You need units which are vaguely compatible tho' .
You can't convert centimetres to degrees centigrade...(or, for the more argumentitive amongs us...can you?)
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
05/30/2008 5:43 AM
Jeez, everyone knows that 1 degree centimetres = 3.14 retrograde Fahrenheit units, so multiply that times 6.7126, then add 32, then divide by the cosmological constant, and you have your answer.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
05/30/2008 6:56 AM
That post contains traces of nut, too.
05/30/2008 1:11 PM
Dear Frnds,
The question seems interesting,
For DP installations,we r calibrating DP ( mm H20) in terms volumetric liquid flow( m3/hr), so in a way measuring dp v r getting flow (m3/hr)
regards
Jose John
05/30/2008 1:21 PM
Using a differential pressure measurement as an indicator of flow rate is certainly workable, but there will be an unseen "fudge factor" or conversion constant that will take into account the specific flow conditions (pipe size, fluid properties, temperature, flow losses, etc...) for the application.
From a strict dimensional analysis standpoint, the units given in the question as worded are not compatible. There is either quite a lot of information missing or the OP is very confused.
Good Answers: 18
06/02/2008 9:58 AM
Regardless of what the value of the conversion factor coefficient is, it must have units of meters2/hr.
I'll bet you can figure it out all by yourself now.
Good Answers: 101
06/02/2008 9:06 PM
Impossible: insufficient data. What is 3.145 meters supposed to be? Depth, width, length? What's your velocity or cross-sectional area?
Good Answers: 18
06/03/2008 8:59 AM
Impossible? Please use your imagination . . .
With a conversion factor of 9.76 square meters per hour, the calculation yields roughly 30.7 cubic meters per hour!
I'm in a quandry . . . I love and hate being a smart-ass, but I think I love it more than I hate it!
06/05/2008 10:59 PM
If 3.145 meters H2O is the differential pressure for a system to meter the flow, you
should go online or to the nearest library and study fluid dynamics, particularly
Bernoulli's principle. This is the system used to meter the flow of natural gas all over
America and the world - You could probably also just google fluid measurement,
meter tubes (actual term for the apparatus used in application above,) gas
measurement, American Gas Association, and the like.
Register to Reply 11 comments
Anonymous Poster (4); Bill (2); Bricktop (1); DVader1000 (1); josej (1); PWSlack (1); user-deleted-1105 (1)
You might be interested in: Utility Meters, Flow Meters, Lux Meters (Light Meters)
