Previous in Forum: DIW WATER   Next in Forum: neutral & ground bus rating
why generation
06/02/2008 10:53 AM
why generation 1of electrical energy at such values like 11kv,66kv,6.6kv & transmission at 220kv,440kv my area of intrest generation is that values shown 11,22,33,44,6.6
kindly suggest ..............plz
Good Answers: 73
Re: why generation
06/02/2008 11:14 AM
The generation numbers are multiples of the basic excitation voltage for that design. Using series or parallel combinations you can obtain those voltages at various current levels.
Re: Transmission
The basic rule of thumb is that the larger the current, the larger the cable that is required. So if you send large amounts of power at much higher voltages you can use thinner wires (smaller cables). Also because power loss is primarily a function of I*I*R it makes sense to transmit at the highest reasonable voltage. Of course, special equipment becomes necessary to handle it.
Good Answers: 97
Re: why generation
06/02/2008 1:16 PM
For no reason at all.
The generation gap is however more serious.
Has anyone counted the number of 11kv steps questions per month?
United States - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: why generation
06/04/2008 4:13 PM
Are we talking about My Generation
No stutter needed
“There's a sucker born every minute, and I happen to be one of them”
Re: why generation
06/03/2008 4:17 AM
form factor
Technical Fields - Education - New Member Technical Fields - Technical Writing - New Member
Re: why generation
06/03/2008 3:58 PM
Everything started (over 100 years ago) with 100 V
Than engineers found: we need extra 10% for voltage drop > got 110 V
Then another 5% > 120V
Now to generate power over MW and have fair size of conductor (higher current -kiloAmperes => & higher kA > thicker conductors!) so 10-11 kV came for generator insulation. And because of this insulation limitation generated voltage of 11 kV w/ transformer ratio 10:1 transmission lines becomes 110 kV. > 220 kV etc for transmission linesw - long distances, drop voltage more significant. Three phase in EU moved 220 * 1.73 (sq root of 3) to 380 or 400 kV with extra 5%.
USA did not care what was going on in EU and have popular 13.8 kV 138 kV etc, for their transmission lines. This is a very simplified explanation. Maybe too simple.
Anonymous Poster (1); Hendrik (1); NotUrOrdinaryJoe (1); southern123 (1); T Man (1)
