Hello Folks,
While some will laugh, I am quite serious. I am trying to find a method to combine the power of a few hundred rubber bands for an airplane model project. While one or two rubber bands would work with a small model, I am looking at a model capable of carrying a hundred pounds or more for several minutes. Since rubber bands are cheap, this is were I am looking. It is not possible to bunch a wad of bands together and try to twist them. I am searching for an idea to have mutiple groups of bands and have a mechanism to combine the power outputs together. I would also like some idea as how to control or meter the power. I can use a small motor to wind them up and it doesn't matter if it takes a couple of hours to wind. The trick is how to combine a few hundred seperate rubber bands into one combined output. I have considering several gearing and lead screw ideas but none seem up to the task. I am hoping for a few good ideas from the group.
Thank You.
