Can any body please let me know how the rated Cv is calculated for any control valve ..While calculating it what is the test fluid taken by manufacturer .whether it is air or water is taken as test fluid?
The Cv can not be calculated. It is to me derived from the measurements.
You pass the flow of water through the control valve opened to required degree, control the flow using another valve, so that the delta P across the control valve is 1 psig. The flow passing is the Cv at the set opening of the control valve.
Or you can derive Cv by just passing the flow without any control. Measuring the deplta P across the valve and the flow rate. using the equations find out what will be the flow rate at 1 psig delta P.
The flow coefficient-Cv required for a specific application can be estimated by using specific formulas for the different fluids or gases. With the estimated Cv value - the correct valve can be selected from the manufacturers catalogues.
