Previous in Forum: 1959 Saab   Next in Forum: FREAK OUT! TV ON THE FRITZ.
Insulating steam and condensate lines
06/24/2008 8:45 AM
Has anybody heard of a paint that can be painted onto steam or condensate lines and be cool to the touch? It is supposed to be used in place of mineral wool insulation.
Is there such a thing and has anybody tried it?
Thanks
Steam
Well, I've got to get back to work. When I stop rowing, the slave ship just goes in circles
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
Re: Insulating steam and condensate lines
06/24/2008 4:01 PM
I'm not sure if it's available outside the US, but see if the paint stores or companies in your area carry cinder or concrete block sealer. Blocks have very porous surfaces that will absorb lots of regular paint. Block sealer is a primer with fiber added to help fill up those pores. It is best applied by brush or roller because it is too thick for most sprayers.
If you can find some, buy just enough to do some tests to see if it will stand up to normal operating conditions.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
Location: South East of Las Vegas just far enough to see the lights but far enough to not hear the coins falling
06/25/2008 12:05 AM
A simple answer is no. You really need the "AIR" in the insulation. Even if it worked it the cost for multi coats would be very expensive. Coatings are great for protections but low on insulation.
Rule number one; Never ask a question unless you are prepared for an answer that you may not like.
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
06/25/2008 2:30 AM
Hi, The JMAN!
Let me be the first to help you move towards GA#12.
Thanks for the link!
Mark
Hobbies - DIY Welding - pipewelder
06/25/2008 8:44 AM
We tried some of these coatings in the paper mill I work at and although they work pretty good on tanks that are in the 200 degree F range we never did get a steam line cool enough that you could put your hand on after coating. We coated the bottom half of a large stainless steel tank and it seems to work well when checked with a heat gun. The cost of the product installed we tried was higher than insulating the traditional way for the benefit it gave on steam lines though. I use a ceramic type coating in my glass furnaces called ITC and this stuff is amazing. It is supposed to reflect 95% of the heat from itself and it really prolongs the life of the furnaces. The other good thing is that it puts a very hard coating on the fire brick surfaces that protect them from molten glass etc. I think the coating you talk about is a ceramic type paint that cures much lower than the ITC (2000 F) that I use.
pipewelder
pipewelder
06/25/2008 8:56 AM
And another GA vote from me. Hadn't heard of this stuff. Closest I've encountered is an intumescent coating that forms a foam around sparks and hot objects to snuff out fires. We use it on floors in welding test booths. Works well for that, but it isn't an insulation.
3Doug (1); EnviroMan (1); MarkTheHandyman (1); miketheboilerguy (1); pipewelder (1)
