Previous in Forum: Changing the Coolant in a Villager 96   Next in Forum: Di Methyl Ether: Fuel From Coal
39 comments
Anyone know about burning gas/water mix car
07/01/2008 11:04 PM
I have seen several ads about products lately that promise, based on cheap alterations, cars can burn water,gas mix and improve mileage significantly. Does anyone out there have any knowledge or experience on this?
Pathfinder Tags: burn water mileage
Re: Anyone know about burning gas/water mix car
07/02/2008 12:16 AM
Yes, most of them are scams or hopelessly wrong due to poor lab work and understanding of electricity/physics/chemistry, etc. See previous threads here regarding HAFC, water powered cars, on-board water electrolysis, gas additives, miracle millage increasing magnets around the fuel line, etc.
Some work a little, others can cause damage to your vehicle and most use far more gas than if you just left the stupid device on your garage floor. The general point is that if the product claims huge savings, doubling your millage or running your car on water and doing away with petrol all together, etc then it is most certainly a scam. The truth of the matter is small millage increases are possible but really significant ones are not due to the very nature and principle of the internal combustion engine.
I expect there to be an increase of these enquiry's and advertising of these devices as gas prices climb and scammers try to cash in more from increasingly desperate people who truly want to believe in an easy fix to the current fuel crisis (bearing in mind that many of these devices have been around in one form or another for decades. They didn't work then either).
You are better off selling your gas guzzler and buying a more economical vehicle. Also see previous threads here on ways of increasing you gas millage (careful driving, reducing weight, driving habits, etc).
http://cr4.globalspec.com/thread/17581/REAL-MPG-GAINS
These will give you a far larger increase in gas savings than some pseudoscience device, and best of all its free! Now that's sticking it to the oil companies.
07/02/2008 1:20 AM
Long ago and far away when automobiles used natural aspiration adding a metered spray of water to the intake could help performance.
Good Answers: 137
07/02/2008 4:18 AM
That's right, it did it by cooling the charge so getting more fuel into the cylinders. You got more power out but had to put more fuel in, it didn't improve efficiency.
Cheers......Codey
07/03/2008 11:07 AM
That was during the days when automobiles were inherentltly less efficient for many other reasons.
07/03/2008 5:14 AM
There are several forms of this scam. One is adding water to your fuel tank and a pill (usually camphor) and then paying a bunch to a mechanic to fix your screwed up engine. Another one is using the car's electrical system to break down water into Hydrogen and Oxygen. Then modify your car to run on hydrogen fuel. This could actually work except you would have to expend more energy (gasoline) breaking down the water than you would get energy to run your car. I love the ones where you put magnets on your fuel lines to "break down" the gasoline to make it burn better. Of course, gasoline is nonmagnetic and would be compertely unaffected by magnets,
Hobbies - Musician - New Member Hobbies - Car Customizing - New Member Hobbies - Target Shooting - New Member Engineering Fields - Power Engineering - New Member
07/03/2008 6:42 AM
"I love the ones where you put magnets on your fuel lines to "break down" the gasoline to make it burn better"
I thought the magnets were to orient the gas molecules in the same direction so they would burn more completely.
Good Answers: 18
07/03/2008 1:36 PM
I keep wondering why with all the scams on the subject that the FCC and others havent come down on these clowns and shut down their operations.
Good Answers: 123
07/03/2008 11:55 PM
Now you tell me. I put the magnets on in the wrong direction. Now the molecules are so scattered that the gas will not burn.
Bob
07/04/2008 12:33 AM
I thought that fuel molecules were non-polar
Good Answers: 458
07/03/2008 10:39 AM
Hey, don't forget about the turbinator (sp ?) that pre-swirls the air going into your intake !!
07/03/2008 7:23 AM
Hi All
Many moons ago we experimented with steam injection as an alternative anti knock device to lead, we found in highly tuned aero engines (Merlin) it was very effective and did indeed boost fuel consumption on the test bed. Real life however soon assured us that the no free lunch principle was and is firmly established, the extra weight of the kit meant that we carried less fuel and wasted any exra performance hauling it all around.
The best way to get more miles from your litre is actually how you use your right foot "Be Gentle" and minimise brake use as you can end up wasting fuel you have already burnt
Life is terminal, No One Gets Out Alive, It is therefore better to travel than arrive
07/03/2008 7:41 AM
Ecat,
You can run your car on water. Simply change your engine to Steam Engine..Suresh Sharma
07/03/2008 7:43 AM
Ecat
That bit is easy the real problem is persuading the wife to keep the boiler stoked
07/03/2008 8:10 AM
A metered spray of water does effectively increased the octane of the fuel for whatever physics are involved. We did it on a street racer back in the early 80's with a 12.5:1 compression ratio and it helped significantly. I have no idea what affect it had on gas mileage. Nobody gave a damn about mileage back then. Course, that was on a 4 barrel carb. I imagine it would do the same thing with fuel injection.
Emergency night landings...as you approach the ground, turn on your landing lights. If you like what you see, leave 'em on. If not...turn 'em off.
Engineering Fields - Automotive Engineering - New Member APIX Pilot Plant Design Project - Member - New Member
07/03/2008 11:26 AM
igor sekorsky wrote a book on caburation and mentions this. It has the effect of controlling the rate of burn as to avoid spark knock ( an explosion) and break the molecules into smaller more uniform size
the combination allows a more efficient pressure profile and energy conversion in the cylinder was my understanding --- ie a screen in the carb throat... or as was pointed out - fuel injection
perpetual motion, unified field theory, etc... as humans we hope --- we are all bugs attracted to the light!
Duct tape is like 'The Force'. It has a light side and a dark side and holds the world together.
Good Answers: 204
07/03/2008 9:04 AM
Once upon a time, I blew my head gasket.. and for about 5 minutes, there were large clouds of white smoke coming out the tailpipe.. I guess you could say the car was running on a water/gas mix.. just not for long... ha ha ha
07/03/2008 10:03 AM
MYTHBUSTERS evaluated this and built it from the plans
...........B U S T E D.............................................
07/05/2008 6:32 PM
can I find that somewhere on their webiste, when did it air?
07/03/2008 12:23 PM
I have com accross hundreds of postings here in CR4 asking the same question. The views are highly polarized but most people in this forum agree that its mostly a scam.
However.. lets look at the way its supposed to work:
- The system claims that a car can produce H2 by electrolysis by using current made by the alternator...
- Then the H2 is fed back into the fuel mix.
- The advocates of these devises claim that this increases a car's mileage.
Most engineers say that it would take more energy to produce the H2 than you would get out by burning it. This due to the second law of thermodynamics..
----- > And this is true ! However, lets see where that extra energy is coming from .. It comes from the electricity produced by the alternator ... which arises another question: Does the car consume more fuel energy when there is an additional electrical load ? Lets think for a moment: Does a car use more fuel when one drives with the high beams on? Or the car is always producing a constant surplus of electrical energy ( More than the car usually consumes) and the device is just redirecting some of that to making H2? ( I personally don't know and I leave the door open for a car expert to jump in)
- The other question is if the system would make enough H2 to make a difference..
I am usually a skeptic but I think that the answer here would be to test it and measure it ... Like any experiment you would have to do it many, many, many times and honestly record the findings in a quantitative way.
It will be difficult to find someone that actually bought one of these kits and admit that it does not work... Its a pride thing... I guess.. They would not be able to admit that they gave money to one of these "scams" and it didn't work ... So you would have to find a large group of objective people willing to try the experiment...
07/03/2008 12:43 PM
I don't believe so, becoz the car engine is not designed for that function. Besides using Steam Engine to power the car, better we re-design and super up-grade the existing internal combustion engine for it to be very much more fuel efficient. The existing car engine is deemed as out of date as less that 30% of the gas are utilised.
07/03/2008 12:52 PM
I guess that with todays fuel prices .. people don't care anymore what something is designed to do but rather what it can do ... ( sounds familiar? )
Location: vadodara, Gujarat state, India (400km from Bombay)
07/03/2008 2:11 PM
Be carefull. You may have to first change the following parts. Silencer to be changed to stainless steel silencer. SS304 or higher grade. Replace existing valves with stainless steel valve. Lining of cylinder using ceramic coating.
Due to presence of water these items are effected.
Rest up to you to decide.
Rohinton Panthaki
07/03/2008 2:18 PM
I thought that the question was about a devise to split H2O into H2 and O2 and then feed into the fuel mix...
I didn't think that they were actually thinking of feeding straight H2O into the engine ....
That would be senseless
07/03/2008 2:22 PM
This should be enough to make your head
Do You Want To Know RIGHT NOW How You Can Drive Around Using WATER as FUEL and Laugh At Rising Gas Costs, While Reducing Emissions and Preventing Global Warming?
My truck that I currently drive is a 1999 Kenworth T-2000 with a Series 60 Detroit Diesel with 1,026,578 miles on it today and it is running better than ever with the six-pack system. I have more pulling power, take-off torque, a smoother & quieter motor, and most important a 20% to 25% increase in fuel mileage (5.5 - 6 mpg to 7 - 7.5 mpg)
http://www.auto-facts.org/water4gas-scam.html After reading the three books, it's hard to call the water4gas system a scam. So much effort was put into testing the systems and providing information about it that it's hard to consider it anything but valuable. I believe that some people are calling water for gas a scam because they expect more than a book. Visitors to the website more than likely quickly look at the pictures and expect a ready to go package to be delivered. This is not the case; the books provide pictures and part numbers and places to buy the items needed to build your own system and instructions on how to install it. After doing some research on the basic part of the system I have found that it operates very similar to alcohol injection kits that have been available for racecars for many years--MasterTech Mark
http://www.certifiedmastertech.com/wordpress/ I have some results to share with you about the recent install of the water4gas fuel heater in my 04 Chevrolet Blazer. The results were not spectacular. After having the water for gas fuel heater design, installed on my truck for the last two weeks, and doing mostly city driving, a gain of only 1 to 2 miles per gallon was observed. This may seem like a very small gain and it is, but to me it is huge. The reason being is my 4.3 L engine has never received more than 15 miles per gallon in its three years of operation. For the first time, this truck has seen 16 and 17 miles per gallon with just the fuel heater installed--MasterTech Mark.
http://www.coasttocoastam.com/shows/2008/05/08.html Water as Fuel Supplement
During the middle two hours, Ari Cohen & Fred Gutierrez of water4gas spoke about the technology for converting water into hydrogen, which can be used as a supplement for gasoline or diesel in order to boost performance and increase gas mileage. The conversion device installed in a car or truck, allows the engine to burn water as well as gasoline. This "hydrogen on demand" system was actually invented 100 years ago, but has been more recently popularized by Ozzie Freedom, who authored two e-books on the subject, said Cohen.
According to Cohen & Gutierrez, the device, which includes a couple vacuum hoses and wires, is fairly simple to install. It uses a little electricity from the car battery to separate water into a gas called HHO (2 parts Hydrogen + 1 Oxygen) which helps the engine run a little cooler and burn fuel more efficiently. Cohen compared the system to a person taking a diet pill, which tells your brain you're not hungry.
The ionization process of the electrolysis pulls and separates the oxygen from the hydrogen, explained Gutierrez, who has installed some five hundred systems in vehicles. Finally, there's a useable technology that allows people to do something to counteract the high price of gas, as well as get a tax break for using a hybrid system, they noted. [Oooh--it was on Coast to Coast so it must be true, yes?]
I have no idea if it works or not, but I tend to agree, if it seems to good to be true, raise the BS flag...
Ready--Set--EVOLVE!
New Zealand - Member - Kiwi
Good Answers: 29
07/03/2008 5:25 PM
Yes, there is a whole forest of astroturf out there in the form of endorsements for this scheme, but this all falls a long way short of providing convincing proof that it is anything but a scam.
I, for one, remain unconvinced.
Why is it that not one of the people who are either selling this scheme or who have installed it and claim that it gives better fuel economy ever subjected it to proper, controlled testing? Despite looking, I have yet to see the results of such a test published anywhere. There are plenty of dynomometers out there, and if the savings were as great as claimed then it should be dead easy to demonstrate.
Why is there no reasonable explanation for the mechanism by which it works? We can quite easily show that the electrolysis of water is a lossy process which draws its energy from the engine via the alternator (and no, the alternator only produces enough electric energy to match demand - more energy drawn equals more load on the engine) and hence from the fuel being burnt. There do not appear to be any published research that demonstrates that replacing ~0.1% of the air/fuel mix entering a car engine with a stoichiometric mix of oxygen and hydrogen will have any significant effect at all on engine efficiency, performance or fuel consumption.
So perhaps some of the proponents of this scheme could stop rabbiting on about how well they think it works, and address these concerns which I am sure are shared by many, many other engineers.
paulusgnome
07/03/2008 6:13 PM
Paulusgnome:
Thank you for addressing my question about the alternator. So... following what you say ... an engine uses more fuel when one drives with the lights on than when driving with the lights off ?
Good Answers: 29
07/03/2008 6:30 PM
Yes, your car uses more fuel with the lights on than off. Only a little, since your car engine probably produces ~100KW, and the lights draw ~100W or so. Would you notice a 0.1% increase in fuel consumption? Even a 1% increase? I reckon most people would not be able to tell any difference.
Nevertheless, if you were to measure the torque demand of the alternator, you would find that there is a very clear and obvious relationship between the torque demand and electrical load.
paulusgnome
Good Answers: 458
07/03/2008 6:36 PM
But many motorcycles have permanent magnetic alternators so their output is fixed. The voltage regulator (usually with aluminum fins for cooling) just 'burns off' the excess energy. Crude, but it simplifies and shrinks the construction (also improves reliability as there are no slip ring brushes to wear out or get contaminated).
Good Answers: 29
07/03/2008 6:47 PM
Yes, you are right about the motorcycle alternators. GS1000 and GSX1100 Suzukis were famous for frying their alternators because of this. Not all motorcycle manufacturers use this method though - I have seen others which use the same type of alternator, but use a switchmode regulator instead of the (old-school) linear type, and these do vary the load drawn from the alternator to match demand.
paulusgnome
Good Answers: 458
07/03/2008 6:52 PM
Soooooooooo . . . if we used an electrolysis machine to regulate the output of the alternator, then we really might see some improvement in the efficieny.
Just have to remember to fill the water bottle when you fill up for gas.
Good Answers: 137
07/04/2008 4:23 AM
Hello Paulusgnome
That's quite right. I only wish it were more widely known, it might deter the idiots who as soon as they start the engine switch all their lights on, irrespective of daylight, weather or anything else. Quite a few switch on their foglights and any others they have as well. This is UK, I believe headlamps at all times is mandatory in some European countries. Crazy, at a time we're supposed to be trying to reduce emissions. That's my rant, I could go on....
I'd just add to your post - I think you've understated the case. 100kW is a respectable maximum engine output (at least in UK). Average power much lower - I just did a quick estimate for my Mondeo. Taking 36 mpg (UK gal, petrol) at 60mph, petrol SG 0.85, CV 44 MJ/kg and engine efficiency 30% (generous) comes to 22 kW.
Also headlamp bulbs are often 80 watt each (some are 100 watt) and with side and tail lamps 5 watt that's 180 watt. With alternator and V-drive efficiciency say 80%, 225 watt from engine. That's 1%, and as you say, most people would not be able to tell any difference. But that doesn't mean it's not there, and 1% difference in all car fuel used is a lot!
Cheers.....Codey
07/03/2008 5:37 PM
My only direct knowledge of using water injection as a fuel enhancement is in the D-model of the T-29 (Convair 440) that was used as a navigator training aircraft out of Harlngen, (TX) AFB back in the 1950's and '60's. You haven't lived until you have ridden with some of those hotshot pilots who liked to see who could be at the highest altitude at the end of the runway. Rev it up hard against locked brakes, release the brakes, hit the water injection, suck the wheels, pull the flaps, and rotate vertical. One of the guys could consistently hit 10,000 feet. I have seen some in-cylinder water injection systems advertised that are probably modifications of what was used on those aircraft.
08/02/2008 2:49 PM
The most I could see the water injection doing was to give some water to 'flash boil' generating steam.
07/15/2008 6:37 PM
YES
COMBINATION OF AIR+ FUEL+ WATER IN AUTOMOTIVE
LEADS TO ALL FUEL ENGINE [ SOLIDS, LIQUIDS, GAS ]
ONLY A HOT GAS OUTPUT IS REQUIRED FOR
ANDY ENGINE TO GET 150 HP / 1000 CC Nasp
CONSUMES3.5 Lit/HOUR
OR
LEADS TO ALL TERRAIN VEHICLE - LAND , WATER
09/03/2008 9:52 PM
Well I would say if anyone really knows about burning water for gas this is the guy! I have been reading his research and trying to understand his complicated equations.
http://waterpoweredcar.com/stanmeyer.html
See it for yourself!!! Water powered car!! nothing but regular tap water!!
Semper Fi
09/03/2008 10:10 PM
Oh boy.
Stan Meyer's is (or shall I say was) the Rolls Royce of modern-day free energy and over-unity scammers. Please look at previous threads mentioning Stan Meyers and his scams over the years (much of which is just a rehash of previous over-unity energy scams concocted by others that date back decades). He even has his own Wikipedia page.
http://en.wikipedia.org/wiki/Stanley_Meyer
I have personally researched into his work and developments and found nothing but fraud and pseudoscience. Many have been suckered in by misleading and faked video and demonstrations along with pesudoscientific explanations that look good to the average person lacking a science or engineering qualification. Bald-faced lies also helped.
Many have tried to further build on his research and development but have not had any luck (for obvious reasons).
09/04/2008 1:52 AM
How can you say he is a scammer with all of his patents? Do you know how hard it was for him to convince the patent office to actually patent his material? If it didn't work he would not of gotten his patents. My Uncle is an engineer and his Hydrogen generator works great. He is getting 6 mpg better fuel mileage out of a tiny cell. A gentleman across the street gets 8 mpg better fuel mileage from his vehicle also with a tiny cell. Mine I fried my pwm, but on the bench it was putting out roughly 2 to 3 times what theirs is producing.About 2.5 liters/min. But it was also drawing 30amps plus at 12 volts. My pwm is only a 15 amp max.
Semper Fi
09/04/2008 11:40 AM
Hi KirkP :
Thanks for your post. I don't know alot about this topic but I would like to hear more about what you said in your post. Care to share any more?
09/04/2008 3:38 PM
No, no, no this is totally wrong. As a patent holder I can tell you that patenting an idea does not prove that it works! Patenting is merely registering an idea. I have seen many a number of patent ideas that are total impractical garbage or physically impossible (such as an electronic circuit connected to the positive of the battery but leaving the negative of the battery disconnected). Now-days they are getting more stringent regarding patenting, and less perpetual motion, over-unity and free energy devices are being given patents. Do an internet search on free energy, zero-point, over-unity magnet motors and other miracle devices. You will find that many patents for these exist, patents for devices with claimed efficiencies that allow near-infinite amounts of free energy to be produced from these self-powered devices.
See previous posts on CR4 regarding patents.
With regard to Stanley Meyer, see previous posts on CR4, Wikipedia, posts on automotive water electrolysis and millage increasing scams and hoaxes, posts on explanations on the difference between real science and pseudoscience, etc. Seriously, this subject has been done to death here.
With regard to water electrolysis results, how are you obtaining them. If you are using a standard multimeter to measure PWM currents or trying to compare a car's range by driving it and comparing how far it traveled, then you are not going to get a meaningful result. Too many variables, uncertainty errors and measurement errors.
See previous posts on CR4 with respect to automotive application water electrolysis regarding performing proper tests and obtaining accurate results (or as accurate as can be obtained outside a fully-controlled and monitored testing lab).
Register to Reply 39 comments
agua_doc (1); Anonymous Poster (7); bob c (1); Brave Sir Robin (3); cbs (2); chrisg288 (1); Codemaster (2); Comrade Col. Clamrod (1); ECAT (1); exemmet (2); Flying boots (1); IanR (1); jack of all trades (3); jfmart (5); Kirk P (2); mike90247 (1); Paulusgnome (3); rohinton (1); servant74 (1)
