Previous in Forum: question   Next in Forum: Mechanical Drawing Symbols
Calculation for sizing hoist
07/10/2008 11:40 AM
Could you suggest a formula for calculating the hp requirement for the sizing of a rope hoist to lift a load of 500Kg at 16 m/min over a height of 27m.
Thank you for your help
Re: Calculation for sizing hoist
07/10/2008 11:10 PM
Dear friend,
pls. refere the DESIGN DATA BOOK By: PSG COLLAGE OF TECH. INDIA.
Regards,
Mitul Patel
Hobbies - CNC - New Member
07/11/2008 1:28 AM
The power you need is:
P = M g v/n
M = mass in Kg
g = gravity accelleration 9.81 m/s/s
v = velocity in m/s
n = effeciency of hoist.
If the hoist is one that does not drop the weight when stoppe the efficiency is less than 50%.
You will need P = (500 x 9.81 x 16/60) / 0.5
= 2.616 KW or 3 KW to allow for safety.
Johan van Niekerk
07/11/2008 10:09 AM
Thank you Johan, this has been helpful. In my further research, I have seen where most manufacturers of this type of electric winch recommend 1.5-2 KW for lifting a 500 Kg load. This would result in efficiencies of approx 60 to 80% (based on your formula). Is this reasonable?
07/14/2008 1:14 AM
If the efficiency is higher than 50% then the hoist will reverse when stopped. For this type of hoist you need a braking mechanism which is usually only done on larger hoist motors.
Johan van Niekerk
Register to Reply 4 comments
Anonymous Poster (1); Johan van Niekerk (2); Locksley Robinson (1)
