Hello All,
I have a 2002 Grand Prix with a 3.8 V6. The car seems to stutter badly, intermittantly. It has 130K miles so first I changed the fuel filter (original) then the plugs and wires (also original)
Along the way, my wife noticed that it seems to do a lot worse when you first fill it up, so I thought, water or sediment in the fuel tank getting stirred up. I started adding fuel treatment to deal with any water, but that has had no effect.
Here's the rub... I drove the car this weekend and noticed that at least part of the time, the problem seems to be that the transmission is hunting. Watching the tach, it seems to be shifting erratically through the gears, like driving a steady 45 mph, not accelerating, it will shift several times in a couple of seconds, all over the place.
I pulled a MAF sensor code last week, but haven't replaced it yet, because it seems to be pristine and the cost is crazy.
Here's the question... Could a faulty MAF sensor be responsible for the erratic shifting?
Not to confuse the issue... When I changed the fuel filter, I expected to see significant pressure as I bled the fuel rail. There was only a quick spurt, just a couple drops. I was surprised by this.
Any suggestions would be greatly appreciated.
BA
