Previous in Forum: Projectworks Titles   Next in Forum: Gear Boxes: Specifications and Applications
11 comments
Location: Globaly - very close to the southern most point of Canada
Good Answers: 12
Sealing NPT Ports
08/20/2008 11:05 AM
My current project requires testing an assembly that has 1/8 and 1/4 NPT open ports. I need to plug these ports. However I do not want to tighten an NPT fitting into the ports.
I would rather use a seal for better results.
Does anyone know of a method using the NPT threads and oring face seal or other seal to close up these ports that does not require torquing the threads?
Test to hold 150 PSI. Port body Zinc AG40A (Zn, AL, Mg)
-why bother doing it wrong when it will be anyway.......
Good Answers: 123
Re: Seal NPT port for testing
08/20/2008 11:18 AM
Aeroquip sells a special quick disconnect designed for reading pressures on equipment. Look for FD90-1045-02-04 (1/8-27 MALE PIPE). And FD90-1012-04-04 (1/4-18 MALE PIPE). Good luck.
Bob
Re: Sealing NPT Ports
08/21/2008 12:07 AM
Last time I did this I built a clamping device with plastic dust plugs installed the clamp held the pressure in for testing. No change of cross threading or getting dirt in the product.
08/21/2008 1:33 AM
use M-seal . Or else clear whether you want to close it permanently or wants to spare the option of NPT plug .
08/21/2008 2:52 AM
Normally the nipple have flat side under the hexagon you must put downthere or a common aluminum washer or some kind of washer some people calls tredoring and others bond-seal,those are common washer with an internal ruber lip but normally those conectors for measures are rubered on its flat side.If you are using your stocked fittings try with the washers.-
08/21/2008 4:02 AM
NPT tapping is based on a conical shape. It is thought, the fitting of NPT becomes self-locking and self-sealing without any need for a qualified spot surface machined at housing. First aim does work - but to condition the fittings position in depth can't be determined exactly, and therefore flat seals can't be used with NPT!
Self-sealing of NPT usually doesn't work. Therefore the tapping itself need to be sealed by liquid sealing fluid (e.g. LOCTITE products) or using the old fashion hemp fibres or PTFE-tape. All recommendations given before in this discussion do not work with sufficient reliabilty because of the conical shapes of NPT.
In case you need a temporary and quick connection the advise for an quick-relase fitting is the right one. Most makers of hydraulic fitting components will provide those connections, not Aeroquip only.
As an alternative you may install an inverter-fitting, connecting the housing with male NPT, but providing female G-tapping (cylindrical tapping and sealing spot face) for fitting plugs or other things with flat sealing elements (sealing shoulder).
Good Answers: 93
08/21/2008 4:28 AM
Are you worried about damaging the zinc body?
You could have some plugs made in a rigid plastic like Delrin or Noryl so they would still seal on the thread but not cause any damage.
Alternatively, make a blanking plate with face seals incorporated & clamp it in place.
08/21/2008 9:17 AM
Nylon pipe plugs are readily available with hex, square or Allen (flush fitting) heads. Silicone plugs might be available through a powder coat supplier.
Nothing exceeds like excess.
Good Answers: 12
08/21/2008 8:28 AM
I want to minimally affect the threads.
I've heard of using BSP oring seal lightly threaded into NPT but I still believe it will affect the threads.
It looks like a fixture will be required to clamp plug the ports.
Thanks all for the input.
Location: USA Soviet Socialist Dictatorship of Cook County& Illinois
Good Answers: 15
08/21/2008 9:00 AM
Reply 6 is a good solution, just use a PVC pipe plug. It won't harm the female threads and should hold 150 psi. There is an item called a tru-seal that would also work. It is a threaded ring with a teflon face seal that is threaded onto the male fitting before it is installed and then tightened onto the face after the plug is in place but not torqued.
Good Answers: 12
08/21/2008 9:17 AM
Very nice! I think this will work very well.
Thank you Morgan 23.
Good Answers: 12
08/21/2008 9:31 AM
Another great option.
Thanks!
Register to Reply 11 comments
Albert Caspers (GER) (1); Anonymous Poster (1); bob c (1); dadw5boys (1); ferquiza (1); gdevine (3); Jaguar (1); Morgan 23 (1); Nigh (1)
