Hi. I have been reading through website after website about the cause to this problem that started up a couple months ago. When I think I've narrowed it down something else seems to be the cause.
My 2001 Hyundai Santa Fe has 105,000 miles on it, 2.6 cylinder 4WD.
While driving (seems to happen at different speeds, usually 45+) the SUV will "jerk" once hard then continue to drive just fine. I can slow down and accelerate just fine but once I come to a complete stop and try to accelerate it is very slow and needs to hit about 15mph to get back to normal. Of course then I can't feel it switch gears but instead it just seems to accelerate through them. The Check Engine light would come on and off sporadically although it has been on now for a while.
I took it to Autozone and had them check the OBD-II and came up with a couple of codes: P0715 and P0420.
I have a crushing feeling its the transmission slipping so I took it into AAMCO (which I know will tell me what they want to hear most of the time - $2200 fix) and they said the fluid wasn't necessarily bad but that it had a "varnished" look/smell to it. Also, that the vehicle's transmission is getting too hot and then going into "fail safe" mode thus causing the tranny to slip. I wouldn't even ask around even more if I hadn't heard of AAMCO ripping people off by saying the tranny is the problem and that other voices have said it seems like a fuel problem. I believe one of the oxygen sensors is bad as well so I have no idea what I'm looking at.
Sorry about the long post but I could really use some help ASAP. Thanks everyone!
-Todd
