Previous in Forum: Recovery of Energy loss   Next in Forum: CNC METAL SPINNING
10 comments
Inconel cylinder
09/08/2008 1:18 AM
Hi,
We have to make cyliner of 800 mm Dia and 1000 mm Height from 1.6 mm thk inconel 800 material with +/- 1.00 mm Dia Tolerance. I think rolling is the best way to fabricate this part. Please let me know what are the factors to be considered in the rooling process to fabricate this part with in this tolerance.
Other than rooling is there any othere process to fabricate this parts with close toleracne?
Waiting for your valuable reply.
thanks
-Nava
The best way to escape from a problem is to solve it ; The full use of today is the best preparation for tomorrow:
Italy - Member - Founding Member Technical Fields - Marketing/Advertising - Founding Member Engineering Fields - Manufacturing Engineering - New Member
Re: Inconel cylinder
09/08/2008 3:36 AM
Try to contact Special Metals, maybe they will be able to help you.
I don't know what country you come from but they have plants all over the world.
Rosy
“Being a woman is a terribly difficult task, since it consists principally in dealing with men.” Joseph Conrad
09/08/2008 6:42 AM
Hi Rosy,
Thanks for your reply. Please let me know what are the factors to be considered in the rooling process to achieve this close toleracne.
thanks
-Nava
Good Answers: 109
09/09/2008 3:22 AM
Hi,
how many?,
how is the welding done?,
any stress relieve after welding?,
thickness variation of metal sheet?
How to suport on measurement that little distortion by weight?
I would like to reject the project if in your position.
Then argue hard to get minimum 4 mm thickness.
Ask the experienced users of sophisticated rolling equipment (flat or tube) what they are able to do (with respect of thickness/length and tolerance). Flat: SANDVIK, Sweden, tube : may be nobody.
If your customer is willing to pay a heavy extra bunch of $$ then think about an expandable ceramic mechanism to stretch the nearly ready cylinder while annealing.
Have success and please report here.
RHABE
09/09/2008 5:15 AM
Inexpensive and accurate method would be to opt for progressive press brake forming using ID or OD contour check template. Polyurethane assisted die will give remarkably accurate results. You need to fabricate two half shells with extra material at edges for controlled post forming trimming and will need two weld joints. Spring back calculations and set up to attain the exact cylinder and for a perfect edge weld joint will be a challenge during roll forming of Inconnel sheet. The above suggestion is for limited quantity production.
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
09/09/2008 7:20 AM
We use Inconel in several critical applications in the nuclear industry. Most of it is in piping. This piping is usually fabricated thru mandrel drawn dies (i.e. seamless). Since your tolerance is about .040 over 3' (1m), I would say you would be fine using a rolling process. Inconel is a little more stiffer than stainless steel to form so get a shop that can handle Inconel and has worked with it before. You must also weld similar to stainless steel. Not sure of the type of rod or wire to use but call Hypertherm or Praxair if you are in Europe.
UFG
Dirt is for vegetables. Pavement is for racing.
Location: USA Soviet Socialist Dictatorship of Cook County& Illinois
Good Answers: 15
09/09/2008 7:32 AM
The only way to acheive this tolerance is by sheer luck. This material, or any material shrinks when welded and the shrinkage can vary along the length, so to acheive this tolerance is nearly impossible. You are asking for 1 part in 800. Keep in mind that 1mm in diameter is only 3 mm length variation in the length of the sheet material you begin with. There will be a cost associated with this fabrication. Inconel 800 is a very expensive material so cut and try is probably not an option. If your customer's budget would allow, I would suggest that you start by determinimg how much the material shrinks for your given material, thickness, weld prep and welding procedure. To do that I suggest that you seamweld the material using the GTAW process. Determine the grain direction of the material and make several weld coupons. Tack blocks on each side of the weld so you can measure the shrinkage of the weld. Tack your coupon, measure the distance between the blocks before the weld and again after. make several coupons and average the shrinkage. Make sure the grain direction is the same as the final cylinder.
Cut your material to the length with enough excess to accomodate the shrinkage. Seamweld the cylinder and be prepared to resize the welded cylinder by forcing a plug through it. (not an easy task as I'm sure you're aware) I would planish the weld joint afterward.
Make sure your customer realizes that your cylinder will not be round to within 1mm but that it will be within 1mm when it is measured with a PI tape..... if you do your job right. Good luck.
09/09/2008 8:49 AM
I concur with Morgan 23. By proper cutting, you can get this cylinder the right diameter (as measured by a PI tape), but it will not be round. 800mm dia. by 1.6 mm thick is extremely flimsey. Do not lay it on its side - it will become egg / oval shaped.
09/09/2008 9:28 AM
the extreme thinness relative to length and diameter precludes boring to ID. I suggest making a inside form of mild steel plate-say 1/2" thick (sectioned with angle iron runners bolted together for easy removal) The assembled form can then be mounted in a lathe and machined very easily to the precise OD (800 mm) needed to within 0.1 mm. Uniform and constant temperature will be needed to control thermal expansion, and the 'specification' must also have a reference temperature for the measurement. Then it is a relatively simple matter to wrap the the cut to size sheet around the form with a thin but finite seam gap and then fill weld the seam.
This vessel is not a low cost fabrication effort. Rolling will not result in a round vessel.
once pruchaesd 950 MT reactors 12' ID, 14" wall thickness, 110' T-T-- 1/4" thick 347 SS weld overlay, MACHINED ID to within 1 MM entire length!! JSW does fantastic work.
Keith E Bowers, PMP
09/09/2008 10:28 AM
Once the form is removed, the 1.6 mm cylinder will become any shape that it wants to or as the wind blows it. I think this is the wrong direction to think in - accommodating the (lack of) roundness is a better way. Since it requires a precise diameter, I would guess that the cylinder in question fits into / around something that provides shape stability.
09/09/2008 12:14 PM
My company used to be able to fuse quartz tubes in this diameter. Quartz would save you money over inconel, and is a good alternative for high temp applications, and you can precision grind for close tolerances.
My process was in a rotary arc furnace, but the equipment was old and had to be retired.
You may be able to find a company in China willing to slip cast a tube to the dimes you need. With a high temperature furnace (gas) you can get a very good consolidation of the glass. The resulting opaque/semi-translucent material will also be a very excellent insulator.
Register to Reply 10 comments
Anonymous Poster (2); Keith E Bowers (1); Lawrence (2); Morgan 23 (1); nava (1); RHABE (1); Rosy (1); unclefastguy (1)
