Previous in Forum: Refurbishing the economy...   Next in Forum: Ithaca Found? A Diversion for Fans of Homer
47 comments
New technology that cuts appliances power consumption upto 30 percent
09/08/2008 3:21 PM
I have found a technology that cuts the power consumption on refrigerator, freezers, air conditioner, heat pumps, pool pumps and most other appliances that use a motor or compressor in them.
This device states that it is a motor controller That monitors the voltage and amperage and slip of the motor and then adjust the power needed to run the motor or compessor at a reduced level of power. So far I have found out that it seems to work and reduces the heat on the motor or compressor and the speed stays the same. Now when the load changes the device adjust the power to the load demand and it still operates at a lower power level.
Have any of you run across this type of device and before you say it is a capicitor type I opened it and in it there is a circuit board and no major capicitors it is using a micro Chip to control the motor.
It really seems to work do you have any input about this.
The Microman
The Microman
Pathfinder Tags: energy saver
Re: NEW TECHNOLOGY That cuts appliances power consumption upto 30 percent
09/08/2008 3:34 PM
Could you provide a link so we can have a look.
09/08/2008 3:36 PM
The link is www.sentienteci.com
09/08/2008 11:58 PM
joat: this sounds like the device N.A.S.A. developed 20 years ago! power saver, it just ok nothing special, if it saves power, what are you losing? perry
Good Answers: 128
09/11/2008 1:42 AM
I agree. It was called a power factor controller, among other names. These devices received considerable marketing, but were almost exclusively for 1-phase motors. Generally they did what they claimed to do, with power savings depending on the % load on the motor. Since typical engineering design has the motor a little over-sized, there usually is room for savings. The original patent was owned by NASA (if I recall correctly) and then licensed to the various manufacturers.
--JMM
09/08/2008 4:36 PM
I read a report of something similar in an electronics magazine a while back...possibly the same thing (the link says sod all about how it works.)
The article I read said it basically turned down the volts to the minimum supply rating which may be say 10% lower than what is coming down the wires...It might have had some load sensing that let through full power if the load appeared to need it.
Hardly rocket science but it did save power ..so may be it counts as pocket science.
Still probably saves less than just turning off the compu
09/08/2008 5:35 PM
I've long held that the best power-saving device for electrical gear is the OFF swi
Re: New technology that cuts appliances power consumption upto 30 percent
09/08/2008 8:51 PM
It looks interesting but I am having difficulty finding the US patents they state on their website (US60/959,364 and US60/959,365). A search thru http://www.patentstorm.us/ and a web search turned up nothing.
Can anyone find a link to the patent so we can actually see what the device does (the marketing info on the site is not very helpful).
Is there another US patent database that I am not aware of?
I will reserve my judgment until I can see some more details, but it sounds like a single phase motor start switch I designed and commercialised a few years back using a Triac or SCR electronic switch as the switching element.
09/08/2008 8:55 PM
patents applied for but not yet granted often won't show in the data bases...
Good Answers: 123
09/08/2008 10:07 PM
Could the circuit chop the power off for short periods of time. If it could shut off the power to the motor for very short periods of time, very fast, the average voltage would still read correct. Less off time when under full loads. More off time when light loads.
How could the circuit tell the difference between a 1 hp motor at half load, and a 1/2 hp motor at full load though?
Bob
09/08/2008 10:17 PM
This is going to require a bit more investigation but, at first sniff, it smells a little funny.
Because they give no details about their product, I can only judge based on what I observe on the website. Here is what I notice:
They present four "testimonials". The first two--despite being reportedly submitted by two different people--have the same format and use many of the same terms within a given context. This gives me the impression they were written by the same person.
The third "testimonial" is from a company called GPX2 (http://gpx2inc.com/). Among the products offered by GPX2 is a device similar to the one in question. There are some things on this site that are suspicious as well but, again, will require more investigation.
The fourth is from a company called Articmaster. I haven't looked that one up yet, but I noticed a product on the GPX2 site named Articmaster.
I don't know yet whether any of this stuff works or not, but I've been left feeling very suspicious given the way it is presented. When I have more time, I will probably look into it a little more.
ALL "electrical" failures are mechanical in nature.
09/08/2008 10:44 PM
Once more into the breach, and inless there is a process other than the voltage change going on I have a problem. I watched the video, I would much rather see the demonstration done with a loaded motor.
I would say it might be possible to reduce the energy use of a unloaded motor. A unloaded motor pulls a surprisingly high percentage of the full load rating of the motor . I normally do not check amp draw of a motor with nothing attached to it, but I would guess it's about 70% of rated load amps. It wouldn't be any big trick to reduce the voltage significantly to an unloaded motor and see a reduction in power usage, basically there's nothing to slow it down, so there's no reason for the amp draw to go up.
I mostly work with three phase motors it has been my experience that the motor will draw the energy it needs to do its work or die trying. If the supplied voltage is on the low of specs for the motor, the amp draw goes up, blowers , and compressors don't slow down in low-voltage situations, they may fry but there is no appreciable change in rpm.
It seems some others have been doing the same thing I have, looking for information on this device and nobody's had any luck.
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
09/08/2008 11:09 PM
A motor running unloaded will draw about 20 to 30% full load amps. No-load current is for magnetization and to overcome friction and windage.
You are correct about lowering voltage. As voltage decreases, torque decreases therefore current increases. In the case of this product it is difficult to know for sure at this point, but I think they are saying that this device reduces voltage with decreasing mechanical load on the motor. This is what I gather from the GPX2 testimonial.
Incidentally, I just noticed that the guys over at GPX2 have a motor running at unity power factor (based on their "collected" data). Damn, I want one of those. That is what they need to be selling.
09/09/2008 12:02 AM
You may be right, I am a little addled but but I swear the last one I checked was pulling in excess of 50%.however I will concede the point, it's that or I have to go pull the belt off the air compressor. I think were in agreement that this certainly requires further investigation, and I don't believe that is the sweet smell of success that you alluded to in a previous post, I have a feeling I better find my hightop rubber boots.
PS: I will have to check in to the over unity electric motors, unfortunately I will not have time tomorrow. I recently installed an HHO, firestorm sparkplugs, and weighted hubcaps on my wife's car, so I'm sure I'll be busy removing gas from her tank tomorrow , so that it does not go stale.
09/09/2008 12:51 AM
Hello YWROADRUNNER,
You very well could have measured no-load current around 50% FLA (older machine maybe). Depending on the construction of the motor (i.e. low permeability steel, large air gap) the amount of magnetizing current it draws could be huge.
The 20-30% that I mention is based on power factor of about 0.7 to about 0.8 for typical single phase motors around the house. I am assuming that the bulk of the no-load current goes to magnetization. To be honest, I don't know that I have ever measured the current on an unloaded machine--unless it was in college (and who the hell remembers anything from college?)
By the way; definitely better to outfit the wife's car with all that garbage rather than try it on that old bird.
09/09/2008 1:19 AM
Hello Mark:
Old, shes not even middle-aged, just 38. How dare you call my high school sweetheart old. It's funny but while I was posting before I was thinking about the JC Whitney catalogs of that era. The same devices they're selling on the Internet today were available from the JC Whitney catalogs, they did not work then and they don't work now.
I remember something from college! Drive straight out the back parking lot half a mile, and there was a t..less bar, where I took a extra credit course Budweiser 101.
09/09/2008 1:27 AM
" ... there was a t..less bar"
I've heard of a T-bar, and a tea bar, but ... ?
09/09/2008 1:51 AM
Hello John:
If I'm remembering correctly one of the barmaids was from the UK. She must've been a foreign exchange student majoring in astrophysics. She said she had worked with the Sun, and that she was published on page 3 of the Daily Mirror.
09/09/2008 6:33 AM
Per chance, is their motor a synchronous motor? They can run at unity or better.
09/09/2008 8:21 AM
No, not a synchronous machine. At least I've never seen a 240V, single phase synchronous motor used in a residential air conditioner. I could be mistaken though; been known to happen.
My point in mentioning it in a previous comment was that the "collected data" appears to be fabricated by someone with at least knowledge enough to know that P=VI. He just forgot the cosθ.
Not sure I like the "unity or better". I know what you mean; assuming the "or better" part equals "leading".
09/08/2008 10:46 PM
are u talking about inverters.. pls write more details...
09/09/2008 3:12 AM
09/09/2008 4:24 AM
Hi Kris,
Do you use one of these power savers, or do you know/think that they would do as they say on the tin?
Regards
09/09/2008 5:34 AM
Hi HydroScot,
I came by a gadget very similar to the plug I mentioned. It's like a normal 3-way adaptor, but one of the holes is for a master plug. My system box is plugged into the master hole. When I turn off windows, the gadget notices the drop in current draw and turns off power to the other 2 outlets. It saves me turning off individual peripherals, and hasn't caused me any grief. It has some surge-protection built in, and can be used with a socket distribution board. Presumably it wastes some current (the device in my link was quoted as .4 watts), but that's better than a multitude of glowing standby lights. Payback time on such a thing is debatable (depends what you have plugged in), but that's not really the point - saving electricity is good in itself. Hitting the off switch/s on the wall is clearly better, but I often dash out at short notice so the thing is handy. I'm not sure where the one I have came from (it has "e-on" as a logo and came as a freebie under one of those Govt. energy saving things, but I think I've seen them in Homebase or similar approx 18 - 20 quid) but I'm tempted to find another for the TV/Video etc. In summary I'd say "thumbs up, good gadget" from my experience. Chat up an elderly neighbour and you could probably sort out some low-energy light bulbs for them and said socket for you.
Kris
09/09/2008 5:51 AM
Good Answers: 230
10/10/2008 4:35 PM
Hello Kris
At least some of that stuff advertised on that link is useless, except at parting the credulous with their hard-earned wallet contents.
<"....The EPS 128 Fuel Saver is a fuel economiser and pollution reduction device which utilises magnetic hydrodynamic technology to improve the combustion of hydrocarbon fuels. Mostly, engine combustion is incomplete due to the molecular clusters of hydrocarbon fuel. In normal cases, only about 70% of the total burnt fuel provides the real power, with 30% of the fuel wasted and carbonised.
The EPS fuel saver is the solution to this problem. When the fuel is passed through the fuel saver, the hydrocarbon molecules are temporarily ionised and create positively aligned molecules (P.A.M). The ionised hydrocarbon fuel results in a complete combustion when in contact with the negative oxygen (air-fuel mixture).
The growing population of motor vehicles contributes to air pollution worldwide. Our field trials clearly indicate that the Fuel Saver can help in reducing up to 30% of carbon and other toxic emissions.....">
So if they advertise that product, they didn't bother checking it out beforehand.
Kind Regards....
09/09/2008 4:42 AM
Hallo Microman,
This sounds interesting. If you do find anything more about it, please pass it to me at nach_sam@yahoo.com. In the meantime, I shall be on the look out for more details.
Thanks,
Nachi
Good Answers: 247
09/09/2008 9:20 AM
Here, you write that you "have found a technology." In another posting, you write that this technology was developed by "a couple guys you know" and complain that no one is willing to test it. What exactly is your connection with the company promoting the device?
I am willing to test it. Have these guys send me one, and I'll test it and report upon it. Just email me through CR4.
09/09/2008 2:39 PM
I don't know about this system but it seems a lot like a unit I have tucked away in the shed. It was given to me by a guy who tried o commercialise it here in Mallorca but as he didn't speak Spanish he didn't really stand a chance!
It works not unlike a normal soft start (not a VFD) but it actually detects the pf of the load and reduces the input power by pwm methods to bring the pf up to close on one. This will have a power saving function but more importantly it will reduce peak currents as the total load on a site will likely be from under loaded motors with the consequent low pf.
I did test this at the time with my own meters and scope and it seemed to do pretty much what it said on the box. A coincidental benefit was that it acted as a soft start anyway as it needed this to "learn" the motor characteristics (from their blurb)
I'll try to fish it out and see if any web info is available.
Chas
09/11/2008 10:29 AM
The Microman
To whom ever would like to evaluate this product please go to www.sentienteci.com and submit a request with your info and then put that this is in reference to the CR4 discussion. They agree to send out a limited quantaty of samples. All they request is that you submit a formal evaluation back to them .
So if you are serious and want to try it out please send in a request thru their website and as I said before make sure you mention CR4 discussion.
And thank you for all of your reply's.
The Microman
Popular Science - Weaponology - New Member India - Member - New Member
09/12/2008 2:48 AM
I also come across gadget like this. The salesman told me that, i have to just put this gadget in any plug of my house, i will get @30% savings.
When i asked to prove it technically, he told me that it is due to power factor correction.
He also showed some Electricity bills of customer who instaaled the stuff. Cost of it is INR 1200/-. Also,he is promoting the product through chain marketting.So it is useless to keep faith.
09/12/2008 10:13 AM
From The Microman
The Micro Plug is not a power factor correction device and you need one for each appliance because it will only work on the motor .If it senses aresistive load then it pass full power thru because if you cut the load on a resistive load you drop the effectiveness of the circuit.
As i said if you would like to evaluate it please go to thier website and say that you are from the CR4 discussion .
09/15/2008 12:08 PM
From The Microman
Hey guy's I thought you wanted to evaluate this device but they say no one has requested a sample.
Whats up no taker's?
They will not charge you for the sample all they wish from you is a formal reply of what you think.
09/16/2008 2:14 AM
I was waiting to hear your evaluation.
09/16/2008 5:18 PM
Hello Microman:
A look at a previous post will show that I'm on record as being skeptical. However I would be interested in testing the device. My only problem with setting up a test is that I have found no explanation on how the device works. To do a scientifically valid and impartial test will require some equipment I do not currently possess, and therefore some capital outlay. It would be helpful if you could provide specific details on how the device is reducing energy consumption. This would not only help me in determining the practicality and costs of the experiment, it also might encourage others to investigate the claimed energy savings.
A valid test is going to require a lot more than just plugging a refrigerator into the device. Without a valid explanation of what the device is actually doing I'm sure there are many others thinking the same thing I am, why should I spend time and money just to prove something doesn't work.
09/16/2008 7:13 PM
A problem I have is that the power consumption of a fridge would be very difficult to isolate from the gross meter reading, given variations in temperature affecting both fridge consumption and use of heating appliances. There is also the (relatively) random use of an electric oven and other high-wattage appliances to be considered, the consumption of which would, in the short term, swamp any observable savings from the DUT.
A meter of some sort would be needed to assess the fridge usage, and the test would have to be made over a long time period (to allow for ambient temperature variations), with the DUT switched in and out of circuit, and results recorded.
10/01/2008 1:29 PM
Hello John:
I thought I'd just get your opinion on the potential to experiment to test the device. I was thinking of using the motor to drive a car alternator connected to resistive the load. I could use a watt meter to check the actual power usage of the motor, while holding the output load constant. I'm sure a 30% difference we show up without difficulty, I'm concerned however that the apparatus would still have too many variables such as belt slippage, and the effects of temperature variation on the alternator performance to be accurate enough to consistently show smaller changes in efficiency. Any ideas or opinions would be helpful.
10/02/2008 10:33 AM
Sounds like a good idea. You should be able to eliminate belt slippage by using a toothed belt - but a V belt would probably be OK, as long as the load wasn't too high. Gears, or even direct drive, would (obviously) also get around the problem.
I wouldn't have thought a few degrees temperature difference either way would change the alternator performance that much - 'tho I haven't looked into it.
To be a realistic test, I guess you'd have to make the load seen by the motor about the same as a fridge pump motor sees - whatever that is!
If you could do a lash-up without too much hassle, you could just run it for a while, recording the input & output once an hour to see what sort of variation you get over a day, to see whether it's worth pursuing.
Good Answers: 247
10/03/2008 9:56 PM
I have a dehumidifier that is within the capability of the Micro Plug unit and also have a humidifier. So, in a phenomenal waste of energy, I plan to both humidify and dehumidify a room, recording the amount of water generated by the dehumidifier, as well as the watt, power factor, amp and voltage readings.
But first, I did a little experimenting with my lathe. In the process, I found that the wiring to my lathe (and probably other things in my shop) is reversed, with the hot (black) wire being energized when the switch is turned off. I traced the wiring to the switch box, where it is correctly color coded. Tomorrow, I'll have to probe further. These miswirings have the potential for being lethal, so if nothing else, just testing this device has helped keep me alive.
The device works as expected, in the sense that it reduces voltage to the motor when the motor is lightly loaded, and increases voltage when it is more heavily loaded. The motor on my lathe is rated 1/4 horsepower, but actually draws 5 amps under load, and 4 amps while just spinning and not cutting. When the motor is unloaded, the voltage drops (from 120) fairly quickly to 100 or so, and then drops more slowly to 90 or a little less. Loading the lathe (by a method I will not describe, but which was only slightly safer than grabbing the chuck with a gloved hand) brings the voltage and current up to about the same values (5 amps, 120 V) with or without the device.
Given that the voltage and current are the same with and without the device for a heavily loaded motor, it seems that we should expect no difference in power consumption, under that condition. Under the lightly-loaded condition we'll need to look at a watt meter to see the effects of reactive power.
My work does not usually require a watt meter, but it would be convenient to have one later in one of my current projects, so I ordered one. It will be interesting to see what it can reveal.
10/04/2008 4:40 AM
Looking forward to hearing results.
Good Answers: 247
10/04/2008 4:57 PM
It will be fun to see what the real power consumed by the motor is. It is very old and very heavy (explosion proof for some old piece of mining equipment, apparently) and it appears reasonably efficient by feel test -- it seems perpetually cool... but of course it takes a long time to heat up the frame. I can't imagine it is anywhere near as inefficient as the 600VA vs 186 watts output would seem to indicate at first glance. I assume the power factor is really low.
Good Answers: 247
Re: The results are in!!!
10/07/2008 12:56 AM
I had a great time playing with my new watt meter and the Micro Plug. They are fairly similar in size and weight, and when the Micro Plug is plugged into the front of the watt meter (a Kill A Watt by P3), the watt meter display remains clearly visible.
I tried the watt meter on my toaster: PF = 1.0, Watts = 750 VA = 750, Frequency = 59.9, Voltage 122.4. All expected values. I didn't try the Micro Plug with this load, mainly because I wouldn't expect it to have any effect at all, but also because it would slightly overload the unit.
Then I tried the unit on my dehumidifier. I didn't expect to see much difference with and without the unit, but was surprised to see that the VA went down slightly with the unit (676 to 650) but that the wattage increased slightly with the unit (450 to 464). I tried to take the reading during the same part of each running cycle, but it is possible that these differences in readings are just experimental error. If the unit causes the dehumidifier to consume more billable watts, the difference is very, very slight.
The dehumidifier is an Energy Star unit, and the documentation that came with the Micro Plug said to expect less improvement with recent appliances. The pamphlet says "up to 28%" savings with 2001 and newer appliances, and "up to 30%" with earlier appliances. The difference between 28% and 30% is probably too small for most people to measure with any reliability, but in any case, 28% is far more of an improvement than I was able to show. The device might not actually increase consumption with an efficient appliance, but it does not appear to reduce it either.
The oldest motor I use in the house drives my lathe. If there could be a measurable improvement, it would be with my lathe motor when it is unloaded. Both the power factor and efficiency would be expected to be low, so there is some room for improvement. PF with no load is .36, very low. Watts = 187, VA = 524. Under load (no device): PF = .65, Watts = 460, VA 660. With the device, no load: PF .37, Watts = 167, VA 420. (These don't calculate correctly, because I waited a while after reading the VA for the Watts to drop and stabilize.) Loaded: PF = .65, Watts = 440, VA = 670.
So, under no load, the watt consumption dropped by 11% when using the device. Under load, the drop was 4%. For my 440 or 460 watts in, I am getting 186 watts (1/4 hp) of mechanical work out: about 41% efficiency. Most of the time, my lathe motor is under load, but we could call it 50-50, and average the percentage savings: maybe 7%. In 100 hours (a year's worth) of lathe use, I'd use on the order of 30 kWh, so I'd save perhaps 2.1 kWh -- about $.21 worth. I don't know what they charge for this unit, but if it is $20, then it would take 100 years to pay for itself, if used on my lathe.
So for my least efficient motor, (for which these devices work best) this device would not save anywhere near enough to justify its cost. For a modern appliance, like my dehumidifier, the device does nothing beneficial. I can't think of anywhere to use one of these in my house or shop. If I had a really old appliance, where such a device might work, then I'd probably be better off updating to an energy star appliance.
I can't imagine what sort of motor could show anything close to the 28% or 30% savings claimed: it would have to be running without any load whatsoever -- a condition not seen in any appliance.
Good Answers: 123
10/07/2008 8:37 AM
Thank you for your effort. Perhaps it would work better controlling the power used when generating hydrogen.
Bob
10/07/2008 10:16 AM
Hello Ken:
Thanks for doing the test you saved me from getting a watt meter. From the looks of the results it isn't a complete scam, however not too practical. The lathe when unloaded should've demonstrated the maximum potential savings in the real world.
I was initially thinking that the device might be useful for refrigerators and AC units as their load varies with temperature, however if you only got 7% on an unloaded antique lathe , without a doubt the savings would be smaller on newer refrigeration equipment.
PS: A long long time ago I did a little driving for Watkins motor lines. Two things that come to mind. 1. The Atlantic terminal was a major pain to get in and out of.
2. Owning a humidifier in Atlanta , brings doubts about your sanity, are you sure it's not a bilge pump, when I was there there was no shortage of humidity.
Good Answers: 123
10/02/2008 12:26 PM
Dual V belts and a cooling fan. You should be able to use the alternator output to power the cooling fan. Just take that load into your calculations.
Bob
Good Answers: 247
09/16/2008 8:29 PM
Hi Microman,
I just ordered one to test. I'll let you know how it turns out.
Good Answers: 804
09/18/2008 1:42 PM
These things are scams, no way around it.
1 phase motors DO run at higher amps than 3 phase motors do when unloaded. So when you reduce the voltage to these 1 phase unloaded motors, the magnetic iron losses are reduced. But that is UN-loaded, as in open shaft. Here is the big flaw in all these scams. Why are you running your motor at all if it is not connected to anything?!
When you put a load on a motor, even a 1 phase motor, the efficiency, defined as input power divided by output power, goes up significantly. Modern motors are as much as 90-95% efficient. How can you POSSIBLY save 50% or 40% or 30% or even 25% energy on something that only wastes 10%? Someone explain that to me in REAL engineering terms! If you reduce the work that the motor does, but it has to run longer to accomplish the task, the kWH remains the same, or in fact maybe even higher because of continuous losses to heat, friction, windage etc. Remember, there is no free lunch.
The examples they choose to show are very carefully picked. There are a FEW legitimate applications where this works, but they are so few as to not be worthy of consideration, and almost NONE of them are on common household appliances. Don't you think that, given the power of marketing energy efficiency nowadays, every refrigerator manufacturer is doing everything they can to maximize their products' energy use? You bet they are! Refrigeration compressors do NOT run unloaded for long periods of time; that has not been the case for over 20 years. The same is true for air conditioners and heat pumps. If these things worked, EVERY AC and Heat Pump Mfr would have them built-in to their products. The PC boards and SCRs necessary to do this cost about $5 US for something like an AC compressor, less for a regrigerator. That is peanuts in the overall value of the appliance and if it worked, the mfrs would be all over it so that they could claim higher efficiency ratings.
Watch their videos carefully. The examples that all of these scam artists use show a reduction in kW when the motor is open shafted, but when they show it hooked up to a load, they show you a reduction in current. That is a trick of power factor, it does NOT reduce the kWH the appliance uses. They are also using very old motors. It's hard to tell that on a video, but I have seen some of these demos up close and personal.
All the rest of the stuff these guys spew out is just clap-trap designed to fool the uninitiated or the woefully hopeful, yet avoid the scrutiny of the Federal Trade Commission looking for false advertising claims. And if the products are sold over the internet from foreign sources, the FTC has no jurisdiction at all! Do NOT buy into it, it is crap and intended to separate fools from their money.
Also be wary of posts in forums such as this. A common scam tactic is for the scammers to make semi-anonymous posts "asking" questions, then having their cohorts "reply" with positive comments to add legitimacy. It's all part of the scam folks.
The definite treatise on these things is here (click here) in my opinion, although I think the author is a little more generous than I am in giving the benefit of the doubt. But the crux of the matter can be found by reading his final statement at the bottom of the page:
Only energy that is being wasted, can be saved.
09/18/2008 1:55 PM
You said,Why are you running your motor at all if it is not connected to anything?!
I'm surprised you would get so picky about this point, the answer is obvious, unloaded motors make excellent space heaters.
Register to Reply 47 comments
Anonymous Poster (3); Blink (5); bob c (3); HydroScot (1); jack of all trades (2); jmueller (1); JohnDG (5); JRaef (1); Kris (4); Mark684 (4); Nachi (1); perry (1); sanjaykangralkar (1); Sparkstation (1); Steve S. (1); The Microman (4); user-deleted-1105 (1); YWROADRUNNER (8)
