Previous in Forum: Manufacturing Process of Submersible Motor   Next in Forum: VFD Control and Inlet Vane Control for ID Fan
Three Useful Inventions for the Environment
09/30/2006 7:21 AM
Dear assistant
I would like to inform you that I have an Australian Patents : an Australian patent # 2005100020 for an invention provide us an electricity and this innovation depends on the sea
waves and /or tidal motion to provide power we use it for desalination of the sea water so we can get freshwater from the sea .
All of that with a very simple idea makes a waterfall by the nature resources , with very cheap cost and without much technology needed. By my invention which depends upon resources you can operate the pressure pumps to push the water into the reverse osmosis unit so we use it for desalination in the sea water and else.
And I got the Australian Patent #2006100565 which is about transportation system moves by using the balloon fly by an electric fans provided with power from a bars lay on the ground get power from resources energy translate it by (wheels rolls on bearings) and wires to the electrical fans.
And An Australian patent # 2006100615 about a transportation system depends on water to be run and a little bit of power from photocells (very less than normal photocells car) and depends on many resources energy to be operated like the waste of plants and would be made in cheap cost.
For more details please log on : http://pericles.ipaustralia.gov.au/ols/auspat/quickSearch.do
and I would like to deal with you for developing the ideas and providing a licensing and I wish you give me your advice and if you are interested with them, or if you study to fund them, also if you like to have a license to manufacture them, or Please guide me to someone who helps for all of that.
I wish you give me good favor,
Please I need you to give me a websites for the companies or the
organizations or universities in your country or any country who could take care about my ideas.
please tell me about a company who do industrial design, products samples, virtual reality presentation packaging and research
I need some advices from you so please keep in touch because I have more useful inventions for the environment..
With best wishes …yours Aladdin
Doha -Qatar Po box 23616
my agent in Australia :
Alun Thomas
I am Ala'a Aldeen Salim Younes Mohammad , I am from Jordan and I live in Qatar.
please help my useful three inventions for the environment .
Re: Three Useful Inventions for the Environment
10/01/2006 3:21 PM
Now this is nice to see. Someone posting something other than a homework question.
I have had a look.
patent # 2005100020 - I am not a mechanical engineer and have not fully read the patent, but from what I can see it shows some promise.
BUT
Patent #2006100565 - Interesting idea but will use up far more resources than it will save, compared to other fixed transport means (ie- trains). For example - the cost of copper at the moment is so high it requires a telescope to see! The infrastructure required is going to be the biggest problem. Requiring it to be powered from roller tracks on the ground is just not viable at all. I have included an example dirigible under development which does show promise below.
http://www.popsci.com/popsci/whatsnew/18ac893302839010vgnvcm1000004eecbccdrcrd.html
Patent # 2006100615 - Cannot see any way of getting this to work. The heating effect of the sun is negligible (for a start), and the huge mass of the engine is going to further weigh down any (if any) performance. Analysis of resources used compared to other transport means is abysmal. Miniaturization of the process is not possible to counter this. This effectively boils down to a free energy device. Enough said.
These two show major problems that would clearly present themselves when you tried to build a prototype or model the system.
Someone more experienced in wave energy theory and hydraulics may want to comment on patent # 2005100020.
Good Answers: 37
10/03/2006 11:29 AM
The numbers indicate patent applications, not patents. #2005100020 is useless, and "guest's" lawyers are ripping him off if they're being paid even to file this nonsense. The sole advantage over more direct means to convert wave, current, or wind energy to electricity is use of a storage tank to permit a time difference between harvesting mechanical energy, and generating electrical. RESERVOIRS for this purpose already exist, and are far larger and cheaper (cost per volume stored). Unfunny Rube Goldberg design elements dominate the pictures and descriptions. Example #8: float on sea surface operates lever, driving first hydraulic sytem, which pushes connecting rod to turn first pulley. It drives a scond pulley via a rope, and that drives a third the same way; the third moves another connecting rod to drive a second hydraulic system (!), the output of which is yet another connecting rod / pulley / belt ("rope") / pulley / connecting rod sytem to move the piston in the cylidrical storage tank "like the syringe" to suck in water through pipes which are thin "like needles" so as to take advantage of capillary action, but with one-way valves. Water released from the tank makes a waterfall [sic] which drives the electric generator. Despite the use of seawater, most components are to be made of aluminum or steel. No, no, no.
" Ignorance and arrogance have more in common than their last four letters. "
