Previous in Forum: Kevlar Bag source   Next in Forum: Video on Condensate Power Pumps
14 comments
Vessel Design
09/14/2008 7:20 PM
Is it possible to design a vessel to work under vaccuum and high internal pressure, I mean for sealing design?
Pathfinder Tags: vessel design reactors
Good Answers: 230
Re: vessel design
09/14/2008 9:14 PM
Hello Kyehia
I presume you mean the vessel is under high internal pressure, yet the entire vessel is "immersed in a vacuum".
The word "vessel" can refer to a ship, and also a container.
If you mean a ship with high internal pressures moving through a vacuum, please advise.
Sealing may mean:
  1. Closure of otherwise open surfaces to prevent leakage.
  2. harvesting of stream-lined sea-going mammals, for skins, fur, food.
Advise further with
Kind Regards....
Good Answers: 137
Re: vessel design
09/15/2008 4:16 AM
Unless it's a pretty unusual application, I assume you mean a pressure vessel, with high internal pressure or internal vacuum, normal atmosphere outside both cases. The answer's Yes. It's also Yes for more unusual situations e.g. pressure inside, vacuum outside, as long as you put appropriate figures in the formulas.
But as Sparky says, more information would help. and "sealing" could mean various things.
Cheers......Codey
Re: vessel design
09/16/2008 3:31 PM
Thanks for your answer. I meant a pressure vessel; i.e. container where the undergoig process, requires high internal pressure and after a while vacuum. I thought this is difficult to be achieved because in the first case the gasket is designed to prevent leakage from inside the vessel to outside. While in the other case the gasket is required to prevent air from outside to enter into the vessel. Is it difficult, limited, or normal? if not impossible?
Thanks
K.Yehia
Location: USA Soviet Socialist Dictatorship of Cook County& Illinois
Good Answers: 15
Re: vessel design
09/16/2008 3:55 PM
This is a relatively simple problem assuming the temperatures are reasonable more difficult if the temperatures are high. To fully answer the question, the temperature, internal pressure, the media, the material of construction are required. Virtually any gasket will suffice within reason assuming it is compatible with the fluids, process and materials. The leak tightness is another factor, just what do you consider to be a tight joint?
You mention reactors and that is usually something operating above ambient temperatures. Give more particulars and we'll help you if you do.
Re: vessel design
09/17/2008 12:04 AM
Thanks for your help; temperature not too high (up to 250 ºC) pressure 9 bar down to vacuum (-0.95 bar gauge). Material is some kind of polymer. I would like to advice some student to buy or make a small container for his experiment the container in the range of 50 cm diameter 60 cm height
Thanks
Re: Vessel Design
09/15/2008 11:42 PM
I think you mean, Gland sealing / Mech sealing?
Yes it is possible to design and use such vessels. You will have to choose glands accordingly which can withstand such duty conditions.
Your gland follower should be good to hold them together. We did similar applications in India with Macstar gland packings.
regards;
Devendra
Good Answers: 15
Re: Vessel Design
09/16/2008 7:42 AM
Yes, it doesn't matter what you mean, whether you mean a pressure vessel inside a vacuum vessel or a pressure vessel capable of being evacuated.
I build cryogenic vessels which are always vacuum insulated. There are sealing issues, especially at the cryogenic temperatures I build at and, what you call vacuum and what I call vacuum, may be quite different but "my" vacuum is measured in 10-6 torr range or better or lower and pressures up to 20,000 psi.
Anything, given enough money, can be done.
Good Answers: 19
Re: Vessel Design
09/16/2008 9:24 AM
"Anything, given enough money, can be done."
CORRECTION:
Anything, given enough money AND TIME, can be done.
Re: Vessel Design
09/16/2008 3:21 PM
Thanks Morgan.
Re: Vessel Design
09/16/2008 10:26 AM
What you call "high internal pressure"
A multi-funtional mechanical seal for vacuum and also for internal pressure up to
10 Barg is not real a problem.
If your are working with a toxic fluid you need a special sealing system, for instance API 53 or API 54 , to keep the toxic fluid inside the vessel or the system.
Your main problem is the temperature, higher temperature are more complicated to select an adequate seal.
Re: Vessel Design
09/17/2008 12:16 AM
The pressure vessels are designed with ASME -Section 8 Codes.
the general empirical relations for thikness calculations is :
t= P * R / (Sm - 0.6 P)
Where P= Internal pressure in Psi
R- radius of vessel in inches
Sm- Allowable stress intensity in Psi
eg internal pressure as 10 bar or 145 psi
radius of Vessel as 14"
material of Cosn. SS 316 for which Sm- 20000 psi
Thickness T= 145x14 / ( 20000- 0.6X145)
= 2030 / 19623 = 0.1034 IN or 2.62 MM
this can be rounded as 3 mm.
this is a simple procedure . For vacuum vessel design tht thickness is calculated with external pressure taken as 10 times the internal pressure .
thanks
p.d. gawali.
BE mech- Unieversity of pune.
Re: Vessel Design
09/17/2008 11:53 PM
Thanks for everybody, I am greatfull to all the comments I got.
K.Yehia
Good Answers: 230
Re: Vessel Design
09/19/2008 7:39 PM
Hello Kyehia
from me
I give you the GA Point, because you have replied several times and thanked others.
Often a Question is asked, no feedback response ever received from the question asker.
Kind Regards....
Re: Vessel Design
09/20/2008 1:41 AM
Yes, you can. Just calculate the thickness due to internal pressure, then make a check for external pressure. Please refer to the following CR4 Threads:
How can i be using ASME codes on the internet to do my design?
HOW TO CALCULATE PIPE THICKNESS FOR EXTERNAL PRESSURE.
Register to Reply 14 comments
Abdel Halim Galala (1); Anonymous Poster (2); Codemaster (1); Kyehia (4); Morgan 23 (2); Peter (1); Ried (1); Sparkstation (2)
