Previous in Forum: CALCULATION OF RC AND BL HELICAL GEAR   Next in Forum: What is major hydraulic threat ?
Heat Exchanger Plat Type
09/18/2008 4:22 AM
Hi,
Need help. Can anybody tel me what the function of heat exchanger with plate type in the process plant.
What are difference between shell/tube type.
Now i'm facing with the problem how to clean that exchanger. Ofcourse easyley open up all the plate then use manual method. But my scenario is, i try to clean that without open or dismantle exchanger.
Good Answers: 230
Re: Heat Exchanger Plat Type
09/18/2008 4:41 AM
Hello "Guest"
You need to advise what liquid/s are passing on the inside also the outside of the flat plate heat exchanger/s.
There are generally ways to clean the heat exchanger, but advise the fluids and temperatures of those fluids.
Perhaps then, you may receive a proper answer.
Kind Regards....
09/18/2008 2:41 PM
Sparkstation is correct, is it fluid/fluid or air/air or air/fluid,
this all play a big part, as to the rhoeology, viscosity,...., ect.
